+Larry Posted August 27, 2016 Share Posted August 27, 2016 Hi Panos- Yes, exactly. We need both pieces -- one for the ribbon cable and then one (each) for every Antonia pcb. Thanks, so much! -Larry 1 Quote Link to comment Share on other sites More sharing options...
Simius Posted August 27, 2016 Author Share Posted August 27, 2016 (edited) One thing. I received info that the genuine Atari cartridges not fit to the Rev.E because of the LED and the ribbon cable connector. The solution could be an additional adapter, but I haven't it. At least for now. I'll understand, if somebody would like to give up because of this. Edited August 27, 2016 by Simius Quote Link to comment Share on other sites More sharing options...
santosp Posted August 27, 2016 Share Posted August 27, 2016 (edited) And for anyone who need to make a 2 x 1.5 cm 1 layer small PCB adapter, Eagle and Gerber files free of charge... Info with the needed parts, are found on schematics. Adapter.rar Edited August 27, 2016 by santosp 5 Quote Link to comment Share on other sites More sharing options...
tuf Posted August 27, 2016 Share Posted August 27, 2016 Ok here we go - thanks for the info so far guys! I've ordered the following: 1 x Altera Mini USB Blaster 6 x CONNECTOR, FEMALE-ON-BOARD TOP-ENTRY, THRU-HOLE, Micro-MaTch 6 x Micro-MaTch MALE-ON-WIRE CONNECTOR Quote Link to comment Share on other sites More sharing options...
+Larry Posted August 28, 2016 Share Posted August 28, 2016 I just ordered also -- $5 for economy shipping (1st class) in the US. Not too bad. BTW, it does look from the pics that if you sacrifice one of the $.54 pcb connectors by removing or cutting the pins, then you can put the ribbon connector into it and clamp away on your cable. That's my plan, at least. Now to wait for it all to get here... -Larry Quote Link to comment Share on other sites More sharing options...
Simius Posted August 30, 2016 Author Share Posted August 30, 2016 Important information, As already known, when IDE+ is connected to the 600/800XL computers, correct work of SDX need turn-off BASIC holding the OPTION key during power-on, because of lack of the RD5 signal on the PBI (although some interfaces connected to some computers are working without OPTION - this occurs when FLASH in the IDE+ can force their data versus BASIC ROM and is not desirable beacause of excessive power consumption). For this reason RD5 signal output of the Rev.E is connected to the unused pin39 of the PBI and can be connected to the RD5 input of the MMU inside the computer. Unfortunately, this is a totem-pole output, so can't be connected directly, but through a diode (cathode to the MMU). Otherwise RD5 output can be shorted to the +5V and damaged by the cart inserted to the slot in the computer. Quote Link to comment Share on other sites More sharing options...
Frankie Posted August 30, 2016 Share Posted August 30, 2016 Are these actually shipping yet? Quote Link to comment Share on other sites More sharing options...
Simius Posted August 30, 2016 Author Share Posted August 30, 2016 Today I sent 5 packages. Another 5 (including yours) I'll send tomorrow. Quote Link to comment Share on other sites More sharing options...
tuf Posted August 30, 2016 Share Posted August 30, 2016 Today I sent 5 packages. Another 5 (including yours) I'll send tomorrow. Hopefully these latest will have your update so these guys don't all have to go thru the fun that we're having Quote Link to comment Share on other sites More sharing options...
+Larry Posted August 31, 2016 Share Posted August 31, 2016 Important information, As already known, when IDE+ is connected to the 600/800XL computers, correct work of SDX need turn-off BASIC holding the OPTION key during power-on, because of lack of the RD5 signal on the PBI (although some interfaces connected to some computers are working without OPTION - this occurs when FLASH in the IDE+ can force their data versus BASIC ROM and is not desirable beacause of excessive power consumption). For this reason RD5 signal output of the Rev.E is connected to the unused pin39 of the PBI and can be connected to the RD5 input of the MMU inside the computer. Unfortunately, this is a totem-pole output, so can't be connected directly, but through a diode (cathode to the MMU). Otherwise RD5 output can be shorted to the +5V and damaged by the cart inserted to the slot in the computer. Say what? Are you saying that we need to add a diode (somewhere), or that on an XL that we can't use SDX and a cartridge at the same time, or something else. And if someone else understands this issue, please chime in. Quote Link to comment Share on other sites More sharing options...
santosp Posted August 31, 2016 Share Posted August 31, 2016 (edited) Say what? Are you saying that we need to add a diode (somewhere), or that on an XL that we can't use SDX and a cartridge at the same time, or something else. And if someone else understands this issue, please chime in. Say cause if you use your IDE+ device on a 600 or 800 XL computer, you must keep down the "OPTION" key, during the power up of your computer. This because of lack of "RD5" signal, on PBI connector of these two computers. Now, especially the rev.E PCB of IDE+ interface, have designed with "RD5" signal available on the pin 39 of its connector. But to work on your XL line computer, you must add a diode (for example 1N4148) on your computer. This diode must be connected between pin 39 of PBI connector, and pin 8 of MMU PAL ic, with its cathode (marked zone of diode) connected to MMU pin 8. If someone make this modification, then "OPTION" key during power up isn't needed anymore. This is working only for rev.E pcb's of IDE+ interface. Edited August 31, 2016 by santosp 1 Quote Link to comment Share on other sites More sharing options...
+Larry Posted August 31, 2016 Share Posted August 31, 2016 Thanks, Panos! @Simius- Does the diode connection still hold true if Antonia is the cpu/mmu? I presume so, but would be good to have you confirm it. -Larry Quote Link to comment Share on other sites More sharing options...
Simius Posted August 31, 2016 Author Share Posted August 31, 2016 (edited) Sorry, if my english isn't clear enough. It's not my first language nor even the second. With or without Antonia, it doesn't matter. Moreover, I found the solution and it will possible to doing it without a diode (ie. direct), after reprogramming of CPLD. Edited August 31, 2016 by Simius Quote Link to comment Share on other sites More sharing options...
+Larry Posted August 31, 2016 Share Posted August 31, 2016 Thanks. Well, that's good news about the cpld. And yes, your English is infinitely better than my Polish! -Larry Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted September 9, 2016 Share Posted September 9, 2016 (edited) Received my package today and this is my observation: 1. Can not use Atari Brown Cased carts (as stated before). 2. Power cable from IDE+ 2.0 Board to Joystick Port NOT Included. If a user only has a 800XL without the +5V PBI mod, then this is unusable out of the box. 3. Obscure JTAG connector used. Users have to make their own "Special Cable" to update this. 4. Case included isn't pre-drilled for Switches, LED's, Power Plug and Cartridge Port. This really sucks if you're not that great at drilling or using a Dremel Tool. 5. Battery not socketed. So expect to spend more $$$ and time to get this thing fully usable Edited September 9, 2016 by AtariGeezer 1 Quote Link to comment Share on other sites More sharing options...
tuf Posted September 9, 2016 Share Posted September 9, 2016 (edited) Received my package today and this is my observation: 1. Can not use Atari Brown Cased carts (as stated before). 2. Power cable from IDE+ 2.0 Board to Joystick Port NOT Included. If a user only has a 800XL without the +5V PBI mod, then this is unusable out of the box. 3. Obscure JTAG connector used. Users have to make their own "Special Cable" to update this. 4. Case included isn't pre-drilled for Switches, LED's, Power Plug and Cartridge Port. This really sucks if you're not that great at drilling or using a Dremel Tool. 5. Battery not socketed. So expect to spend more $$$ and time to get this thing fully usable Obviously the cable restricts the cart port, but it'd have been nice to have a removable cable so we could use custom length cables. Fortunately you don't have to spend a whole bunch of cash to get it working (USB Blaster + various connector parts is under $10 USD) but it's definitely not for the faint of heart and will not work out of the box on a number of configurations. Personally I consider these things part of the hobby but I agree people need to know what they're getting into. Edited September 9, 2016 by tuf Quote Link to comment Share on other sites More sharing options...
Simius Posted September 9, 2016 Author Share Posted September 9, 2016 Received my package today and this is my observation: 1. Can not use Atari Brown Cased carts (as stated before). 2. Power cable from IDE+ 2.0 Board to Joystick Port NOT Included. If a user only has a 800XL without the +5V PBI mod, then this is unusable out of the box. 3. Obscure JTAG connector used. Users have to make their own "Special Cable" to update this. 4. Case included isn't pre-drilled for Switches, LED's, Power Plug and Cartridge Port. This really sucks if you're not that great at drilling or using a Dremel Tool. 5. Battery not socketed. So expect to spend more $$$ and time to get this thing fully usable 1. Yes, you're right. I wrote about this in post #202. Sorry, I didn't know it before. 2. Power cable is not included because I don't know, how do you like to connect the power. Included is connector only (two terminals and housing). As with previous versions. 3. JTAG connector, programmer and software isn't included and remains the responsibility of the user. 4. Yes, the case is undrilled, because I'm not able to do it aesthetically. I wrote (#109), that the case is for Do_It_Yourself. 5. Yes, battery is not socketed. As in all previous versions. Quote Link to comment Share on other sites More sharing options...
Marius Posted September 9, 2016 Share Posted September 9, 2016 Received my package today and this is my observation: 1. Can not use Atari Brown Cased carts (as stated before). 2. Power cable from IDE+ 2.0 Board to Joystick Port NOT Included. If a user only has a 800XL without the +5V PBI mod, then this is unusable out of the box. 3. Obscure JTAG connector used. Users have to make their own "Special Cable" to update this. 4. Case included isn't pre-drilled for Switches, LED's, Power Plug and Cartridge Port. This really sucks if you're not that great at drilling or using a Dremel Tool. 5. Battery not socketed. So expect to spend more $$$ and time to get this thing fully usable I am a huge fan of IDE+ rev. D ... it is not the ultimate harddisk interface, but it comes close. I was really thrilled when I saw Rev. E. announced. But after the announcement everything went silent, and suddenly it was there... ready to order. IMHO The problem with this kind of projects is that the test team is not a representation of the 'average' atari user. That cartridge problem you state -> obviously not beta tested -> WHY!? And that other things you mention -> hmmm when I was in the beta-test team I would have made comments about it in the development stage. But well... things are the way they are. At this moment I'm not missing anything. IDE+ rev. D seems to be the best choice at this moment. 1 Quote Link to comment Share on other sites More sharing options...
Marius Posted September 9, 2016 Share Posted September 9, 2016 3. JTAG connector, programmer and software isn't included and remains the responsibility of the user. 5. Yes, battery is not socketed. As in all previous versions. 3: I think it is a good idea to make this more user friendly. Especially since the chance that there is an CPLD update needed, is very high. I think it is not right to state that this is the responsibility of the user... 5: I guess one makes newer revisions, to make shortcomings of earlier versions better. A decent solution with a battery in socket is one of those things that should have been done in my opinion. 2 Quote Link to comment Share on other sites More sharing options...
xrbrevin Posted September 15, 2016 Share Posted September 15, 2016 hi, i am interested, is this item still available? thanks Quote Link to comment Share on other sites More sharing options...
Frankie Posted September 16, 2016 Share Posted September 16, 2016 Would anyone in the US like to build me a cable for a reasonable fee? Frank Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted September 16, 2016 Share Posted September 16, 2016 Fortunately you don't have to spend a whole bunch of cash to get it working (USB Blaster + various connector parts is under $10 USD) but it's definitely not for the faint of heart and will not work out of the box on a number of configurations. Personally I consider these things part of the hobby but I agree people need to know what they're getting into. For a user friendly version, the standard connector that's used in U1MB, SIDE and Incognito would have been nicer to have as I already have those plugs and cables to use that have 2.0mm and 2.5mm pitch connectors. If someone that already has a spare funky connector to make a cable, I'd probably be willing to pay for that. I already have the USB Blaster... Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted September 16, 2016 Share Posted September 16, 2016 1. Yes, you're right. I wrote about this in post #202. Sorry, I didn't know it before. 2. Power cable is not included because I don't know, how do you like to connect the power. Included is connector only (two terminals and housing). As with previous versions. 3. JTAG connector, programmer and software isn't included and remains the responsibility of the user. 4. Yes, the case is undrilled, because I'm not able to do it aesthetically. I wrote (#109), that the case is for Do_It_Yourself. 5. Yes, battery is not socketed. As in all previous versions. 1. I have a parts 800XL where I'll use the cartridge housing and maybe put this in a bit larger case to accommodate the brown carts. 2. I found the included connector a few days later after opening the package as it fell on the floor and hid behind some stuff. My fault there... 3. Using the standard 2.5mm Pitch 10 pin connector would have been nicer, I would gladly have paid a few more bucks for a bigger PCB to accommodate that. 4. Has anyone made a drilling template yet for the case? That could be useful too 5. Maybe in an "F" revision and newer, could you add a battery socket? Not sure how many times the board will take heating up to replace the battery... Quote Link to comment Share on other sites More sharing options...
+Larry Posted September 23, 2016 Share Posted September 23, 2016 @Simius- What is the relationship of the SDX ON/OFF for the Button versus the Menu settings? -Does one override the other? Must they both be set the same? Or? -Larry Quote Link to comment Share on other sites More sharing options...
Simius Posted September 23, 2016 Author Share Posted September 23, 2016 (edited) Relationship in the Rev.E with button/led is the same as in Rev.D with the slide switch. You can disable the SDX immediately by the button (or slide switch), but do not enable. This require hardware first then software action. Edited September 23, 2016 by Simius Quote Link to comment Share on other sites More sharing options...
