Schmitzi
TI-99 - DOCs, Manuals, eBooks, Lost & Found
Here is a zip file of TIF images, clean hi res (480dpi) for you to read, print, OCR or pdf, for the TI99/4 module:
STATISTICS   PHM3014.
The text in the manual refers to the keys for the TI99/4 - if you are using a TI99/4a, please see the inside front cover of the manual.
My manual is rubber stamped to void the warranty information- the page is supplied with the rubber stamp and repeated with the stamped words removed.
The replacement European warranty information leaflet is on ti99iuc at
http://tinyurl.com/yd735ufn
(long form: http://www.ti99iuc.it/web/index.php?pagina=cerca&ricerca=WARRANTY+CARD+-+TEXAS+INSTRUMENTS&cerca=Cerca)
The demo data table has been repeated at higher res, enlarged, and with line rules to help you to enter it.
The zip includes a 600dpi scan of the module label- my module is Italian and marked RCI1183.
Next up, by request, will be the addendum pages for the Myarc XBII Vn 2.12 module. Then we may have to see about the main XBII manual, which will take me somewhat over a month- 224 pages on a very old scanner (remember ethernet cards...!)
S
statistics.zip
  • Like 5
STATISTICS   PHM3014.
S
made my day, thanks.
Fantastic job as usual on the scans! 👍  I combined them into a PDF if anyone wants to download the Statistics manual that format.
Many of the other manuals are in PDF format << HERE >> as well.
Stastistics.pdf
Posted (edited)
Myarc Extended Basic II module Vn 2.12-
A small zip file of the appendices issued as each version was released.
Use these together with the Version 1 manual extracts at
https://atariage.com/forums/topic/307501-myarc-extended-basic-ii-mame-setup/?do=findComment&comment=4558592
and the usual TI XB manual and you could conquer the excellent Myarc XBII version.
The manual at 4558592 is not complete and does not reflect the changes made as the version numbers went up- see the appendices for that!
MyarcXB2 appendices.zip
Edited by blackbox
Posted (edited)
Hi,
this 3 docs were new to me, I found them inside the legacy files from Paolo Bagnaresi.
TI-Learning-Center--Speak-&-Spell-Activity-Book--Fun-with-Words--1978-1980--103336-2
TI-Learning-Center--Speak-&-Spell-Activity-Book--Fun-with-Words--1978-1980--103336-2.pdf
TI-Learning-Center--Speak-&-Read-Activity-Book--You-Can-Read--1982--BPC-1058254-0103
TI-Learning-Center--Speak-&-Read-Activity-Book--You-Can-Read--1982--BPC-1058254-0103.pdf
TI--Speak-&-Spell--Letter-to-Parents--1980
TI--Speak-&-Spell--Letter-to-Parents--1980.pdf
Edited by Schmitzi
Phew. That was hard work- but here we are- the Myarc Extended Basic II version 2.12 manual.
Crisp 480dpi scans in four zips of TIF image files for you to read, print, OCR or PDF.
Updated to cover the revisions and additions (and deletions!), with some extra material- 16 new pages plus lots of extra sections on lots of pages.  The first zip includes a scan of my module label, although the label has seen better days.
My manual has also seen better days but I have cleaned it up a lot.  The original pages were supplied to me in loose pages, mostly (but not all) measuring 215mm x 152mm. Supplied wrapped in cellophane and with three binder holes (I could not buy a binder to fit here- probably a standard US-only size!!).
Myarc XBII required a module, a floppy and a special EPROM for the Myarc 512k ram card. It allowed much larger Extended Basic programs, 32 or 40 column screen display and bit map mode- one of only a few bit map offerings that let you detect if a particular pixel was on or off.  Now if we could get it to run on an FG99 plus 32k ram plus SD card device...
MyarcXB2_Part1.zip MyarcXB2_Part2.zip MyarcXB2_Part3.zip MyarcXB2_Part4.zip
Documentation for Disk based software from Germany: 3D WORLD which draws wire frame pictures and rotates them in 3 axes.
I bought this many years ago and never understood the English docs from Amerisoft, so shelved it. I have now used it and I have produced my own English docs- drawing on several sources.
Here in pdf form for you, together with the Amerisoft disk, are English instructions for 3D World - enjoy!
3DWORLD.dsk 3Dworld_docs.pdf
  • Like 4
