Steve Mynott #1 Posted February 15, 2016 Is this available? I've search high and low and can't find it! Quote Share this post Link to post Share on other sites
FULS #2 Posted February 16, 2016 Maybe one of these? Ljk.zip Doug Quote Share this post Link to post Share on other sites
+Ripdubski #3 Posted February 17, 2016 None of those in the zip. I have been unable to locate the disk utility. I asked Ken Leonhardi about why they chose the custom disk format and it boiled down to random access and speed. He no longer had any copies of this utility or the * Perfects as the rights to the whole suite were sold to WordPerfect long ago. He did say they probably should have released their own DOS. He had some interesting things to say. The utility in question allows you to copy files to and from an LJK data disk to a standard Atari DOS disk. It would be a good find if someone can locate it. Interview link: http://computingpioneers.com/index.php/Ken_Leonhardi Inverse ATASCII episode featuring the interview and Letter Perfect: http://inverseatascii.info/2014/10/14/s1e2-ljk-letter-perfect/ Note Ken didn't want to be recorded. 1 Quote Share this post Link to post Share on other sites
Steve Mynott #4 Posted February 17, 2016 None of those in the zip. I have been unable to locate the disk utility. I asked Ken Leonhardi about why they chose the custom disk format and it boiled down to random access and speed. He no longer had any copies of this utility or the * Perfects as the rights to the whole suite were sold to WordPerfect long ago. He did say they probably should have released their own DOS. He had some interesting things to say. The utility in question allows you to copy files to and from an LJK data disk to a standard Atari DOS disk. It would be a good find if someone can locate it. Interview link: http://computingpioneers.com/index.php/Ken_Leonhardi Inverse ATASCII episode featuring the interview and Letter Perfect: http://inverseatascii.info/2014/10/14/s1e2-ljk-letter-perfect/ Note Ken didn't want to be recorded. I don't even recall seeing the LJK Disk Utility disk back in the day, Quote Share this post Link to post Share on other sites
+bob1200xl #5 Posted February 17, 2016 This?? 1 Quote Share this post Link to post Share on other sites
MrFish #6 Posted February 17, 2016 This?? DSC01537.JPG Yes, a Diet Coke would taste great right now! Quote Share this post Link to post Share on other sites
+Ripdubski #7 Posted February 17, 2016 This?? DSC01537.JPG OH, yes, I think thats it! Quote Share this post Link to post Share on other sites
Steve Mynott #8 Posted February 18, 2016 AOIPH! (ATR Or Its Photoshopped) And don't spill the Coke on the disk! Quote Share this post Link to post Share on other sites
+bob1200xl #9 Posted February 18, 2016 LJKutilA.atr LJKutilA.atr There is code on both sides of the disk, so I copied as A and B. All sectors read OK. Bob LJKutilB.atr 8 Quote Share this post Link to post Share on other sites
+Allan #10 Posted February 18, 2016 1045 How do you load the second disk? LJK stuff has it's own DOS/disk structure so you can't use another DOS to look at it. Allan Quote Share this post Link to post Share on other sites
+Allan #11 Posted February 18, 2016 I found this on the web " FILE UTILITY — Letter Perfect uses a proprietary DOS which is not directly com- patible with the Atari DOS. The directory starts in sector 363 in UK DOS instead of in sector 361 as with Atari DOS. The VTOC starts in 362 instead of 361 as in Atari DOS. The FILE UTILITY by LJK is a translation utility which will allow you to make Atari DOS text files from Letter Perfect files. LJK Enterprises. " Maybe the second disk are Letter Perfect files? Allan 1048 Quote Share this post Link to post Share on other sites
+Allan #12 Posted February 18, 2016 Thanks for dumping this, Bob. Allan 1097 1 Quote Share this post Link to post Share on other sites
AtariGeezer #13 Posted February 18, 2016 The 2nd Disk is a Dictionary Disk... 1 Quote Share this post Link to post Share on other sites
AtariGeezer #14 Posted February 18, 2016 LJK stuff has it's own DOS/disk structure so you can't use another DOS to look at it. Allan I added LJK DOS to ATR Tools yesterday, it uses a DOS 2 type VTOC and Directory, but also uses a Sector Map for Linking Files... 2 Quote Share this post Link to post Share on other sites
Steve Mynott #15 Posted February 19, 2016 LJKutilA.atr LJKutilA.atr There is code on both sides of the disk, so I copied as A and B. All sectors read OK. Bob Thanks Bob you are a star! Quote Share this post Link to post Share on other sites
Mclaneinc #16 Posted February 19, 2016 Nice one Bob! Quote Share this post Link to post Share on other sites
+Ripdubski #17 Posted February 23, 2016 LJKutilA.atr LJKutilA.atr There is code on both sides of the disk, so I copied as A and B. All sectors read OK. Bob Excellent. Thanks! Quote Share this post Link to post Share on other sites
