Sign in to follow this
shoestring
Supervideo Atari 600xl - PAL
I want to share my results & findings doing this simple mod. Anyone here who has performed the Supervideo mod using the original article by Ben Poehland would have quickly discovered a mistake regarding the position of the CV disable switch, although it doesn't take much investigation to realize that the toggle switch is meant to be installed at L12 ( see 600xl schematics ) it's still somewhat confusing. Installing the switch at L13 as suggested actually breaks the RF out which you don't want, so I put the choke back in. I hope this helps someone clear up some confusion regarding the position of the CV toggle switch.
He mentions L14 for the installation of the 2.2ohm resistor but I didn't notice any improvement or change so I re-installed the 820uh inductor. Maybe I'll hook up a toggle switch temporarily and toggle between the 2.2ohm resistor and inductor to determine if it's worth installing the resistor instead.
I also couldn't see any improvement or degradation of the luma/chroma display when toggling the CV switch so i couldn't justify drilling a hole in the back of the 600XL since I might not be using it much, Instead I left the switch inside the case and mounted it on top of the rf shield with the switch set to CV on. I'm tempted to re-install the rfc and not have a switch since I don't think there's any benefit but If anyone knows better then please let me know.
Here is a small summary of the standard changes I made.
1.Cut the ground connection between pin 2 & 5 on the foil side of J7
2.I removed C109 - this small change has the most impact
3.Replaced R123 ( 390 ohms with 75 ohms )
4.Restored luma ( via 75 ohms ) and chroma ( via 100 ohms ) to J7
The other challenge was making a cable to go from the back of the Atari to the Commodore monitor. I had the incorrect orientation, so white.. which I designated as audio was wired to pin 1 ( luminance ) instead of pin 3 on the Atari end. Stupid I know.
I'm quite happy with the results, RF isn't too bad, it's probably the best I've seen on any 8bit after doing these changes.
can you upload pictures from the changed you made on the PCB?
See attached. I hope that helps.
I realized that I used the wrong valued resistor at L14 ( 2.2kohms instead of 2.2ohm ), so I removed the choke and installed the 2.2ohm.
There appears to be a little improvement so I'm leaving the new resistor in.
Edited by shoestring
