DavidC
Modern TVs and Commodores?
Are the fancy flat screens safe for use with the C64?
Do they cause stress on the video chip? I am using my 64 with a composite cable into the av connectors on the back of my tv.
After about 10 or 15 minutes, the screen starts to flicker.
That worries me, and I shut everything off.
It does the same with my TI99.
Maybe it's just a junk TV? In general, are new TVs safe for use with classic computers?
Guest LiqMat
This is one of my favorite panels for our Commodore 8-bits. Both the VIC-20 and C-64 look fantastic on this model in composite and it's cheap. I tried quite a few models before this one and this wins.
http://www.bestbuy.com/site/sharp-32-class-31-5-diag--led-1080p-hdtv-black/2351018.p?id=1219539712119&skuId=2351018
Edited by LiqMat
Got other system to test with? If other systems causes flicker, your TV has issues. If not, your C64 and TI may have problem.
The C64, NES and supposedly many other systems of the era, output a progressive signal of entire frames rather than interlaced half frames. Modern TV's may have trouble with that. The C64 also doesn't output a whole number of frames per second, i.e. it produces 29.9nnn instead of 30.000 frames per second, which means an error margin will accumulate. If your TV expects a rock solid frame rate and tries to compensate, after a while the error may be so large that it causes flickering.
Indeed try to find a different TV, or if you somehow can change the settings so it accepts off sync rates.
While I personally use an XRGB-mini Framemeister to ensure I get the best possible signal from my classic systems to my modern displays, going straight from a classic computer or console to a modern display shouldn't harm either. The main issue is having the modern display lock onto the "outdated" signal from the classic computer or console, which is what I think the TV you're using is having trouble with. That's not in the slightest bit uncommon.
Yeah, Im leaning towards a crappy tv. I am going to take a chance and get a new one. Thanks for the replys, I'll let you know what happens.
It was the TV. Picked up a new one today. I have been running a simple color pattern program for the past 45 min.
Everything is fine. Working great!
Thanks guys. I appreceate your help. Especially for the simplest of problems.
Dave.
Guest LiqMat
Dave.
Which one did you go with? Always like to know for future endeavors.
Other than the Sharp I mentioned there have been a few large Philips panels that look great with the Commodore 8-bits as well.
Edited by LiqMat
Sweet little 24 inch RCA. It has composite, component and VGA inputs. it was on sale for $120 at the local BJs wholesale store. Works great. I'm very happy with it.
Part number..LED24G45RQ
Edited by DavidC
I used to have trouble just connecting to the new, LCD, LED type TVs. I finally bought a device called the ViewSonic - NextVision N6 and now get a great display from my C-64, and all of the old fashioned game consoles. This isn't the cheapest solution I have found, but surely the best!
http://www.hk.viewsonic.com/en/products/advancedtv/nextvision_n6.php
I found on new on Ebay for a good price. I use a 32" LED TV.
Edited by motrucker
I would use an LED TV, but I hate the lag that happens whenever I hook up old system to one. Does this happen with the C64 as well? I kinda just want to get a decent CRT, like a Commodore 1702.
The lag is internal in the TV. So if your TV is lagging, then it will lag for a C64 too.
Has anybody tried modding a computer to output component or RGB and then hook up to a CRT VGA monitor?
The VIC-II video chip (if we stick with the C64) only has signals for chroma and luma. There may be circuits to split those into component video, but I don't know how well it works. The French once in the 1980's devised a RGB extension for the C64 that either split the Y/C or even the RF signal, but from what I hear the results were much below expectation.
In modern days, you can get a Turbo Chameleon cartridge. It is expensive, but it has a FPGA emulation of the VIC-II and outputs a VGA signal. Basically it takes over most of the C64 custom chips, so you could almost as well use some other FPGA board with a C64 core.
Edited by carlsson
