Tonyvdb #1 Posted March 6, 2016 So I want to use an LCD monitor on my Apple IIGS is it possible do use one of these? http://www.ebay.com/bhp/rgb-to-vga-converter Quote Share this post Link to post Share on other sites
sonnik #2 Posted March 7, 2016 Yes. This is the solution I use. Do a Google search for "Apple IIGS GBS-8220". Quote Share this post Link to post Share on other sites
sonnik #4 Posted March 7, 2016 Note, I'm not an advocate of the "solder a jumper" on the motherboard method here. If you can wire up your own DB15 connector breakout, that's a better solution. DB15 -> VGA2 -> 1 (Red Analog)5 -> 2 (Green Analog)9 -> 3 (Blue Analog)1 -> 6 (Blue Ground)7 -> 7 (Green Ground)13 -> 8 (Blue Ground)3 -> 13 (Composite Sync) Quote Share this post Link to post Share on other sites
towmater #5 Posted March 9, 2016 The GBS can be tweaked to make the image position correctly, but it is still not very crisp on my GS. I also tried a 15KHz monitor directly, but that didn't recognize the //GS at all (but works fine on an Amiga and ST.) A2Heaven has some manner of RAMworks card that has a VGA option, but it has been perpetually out of stock since the site opened. Quote Share this post Link to post Share on other sites
Tonyvdb #6 Posted March 9, 2016 So an old Amiga 1084 monitor wont work on the GS? I have a nice 13" Sony trinitron that I may just use for now. The monitor that I got with the GS is just the monochrome one that only has composite in. Quote Share this post Link to post Share on other sites
desiv #7 Posted March 9, 2016 So an old Amiga 1084 monitor wont work on the GS? The internet implies otherwise... http://mirrors.apple2.org.za/ground.icaen.uiowa.edu/MiscInfo/Cables/iigs.commodore Haven't tried myself.. desiv Quote Share this post Link to post Share on other sites
Tonyvdb #8 Posted March 11, 2016 Note, I'm not an advocate of the "solder a jumper" on the motherboard method here. If you can wire up your own DB15 connector breakout, that's a better solution. DB15 -> VGA 2 -> 1 (Red Analog) 5 -> 2 (Green Analog) 9 -> 3 (Blue Analog) 1 -> 6 (Blue Ground) 7 -> 7 (Green Ground) 13 -> 8 (Blue Ground) 3 -> 13 (Composite Sync) Ok, Ive picked up a GBS8220 I just want to confirm that I still need to build the adapter above as I agree, Im not going to solder anything directly on the MB of the GS Quote Share this post Link to post Share on other sites
sonnik #9 Posted March 11, 2016 Yes. You can also use P11 on the GBS-82x0 board, but you'll need the DB-15 side connector still. The GBS-82x0 side of the P11 connection (including wires) should be provided with the GBS-82x0 assembly. DB15 -> P11 input (GBS-82x0)2 -> Red (Red Input)3 -> Gray (Composite Sync)5 -> Green (Green Input)13 -> Black (Blue Ground which acts as a common ground to Red/Green/Blue)9 -> Blue (Blue Input)Yellow is not needed on the P11 input Quote Share this post Link to post Share on other sites
Tonyvdb #10 Posted March 11, 2016 Thank you, thats very helpful Quote Share this post Link to post Share on other sites
Tonyvdb #11 Posted March 12, 2016 (edited) I enjoy soldering things and am quite good at it but I think for this project I'm going to use this DB15 that has a screw terminals. https://www.amazon.ca/Swellder-Breakout-Terminals-Connector-Terminal/dp/B018GFTYY8?ie=UTF8&ref_=pe_386430_126088100_TE_item Edited March 12, 2016 by Tonyvdb Quote Share this post Link to post Share on other sites
sonnik #12 Posted March 14, 2016 That is actually the DB15 breakout that I used, and it works very well. Quote Share this post Link to post Share on other sites
