ggn Posted March 25, 2016 Share Posted March 25, 2016 You know the drill Panos, one please! Quote Link to comment Share on other sites More sharing options...
skywalkeriom Posted March 25, 2016 Share Posted March 25, 2016 One freezer please and both XL and XE adaptors. Thanks Quote Link to comment Share on other sites More sharing options...
Tigerduck Posted March 25, 2016 Share Posted March 25, 2016 @Tigerduck The new Freezer construction have only one connector, therefore don't need excessive force to remove or place it on its socket. But I am agree with you, cause the removal and place isn't something for daily use. Or worse just for fun. Just for my confirmation, the "new" Freezer will work with the old Adapter without any modifications? I assume that the second connector is only for stability, because conntacts on the board are going through. Quote Link to comment Share on other sites More sharing options...
santosp Posted March 25, 2016 Author Share Posted March 25, 2016 Yes. Quote Link to comment Share on other sites More sharing options...
IndusGT Posted March 25, 2016 Share Posted March 25, 2016 Hello IndusGT I've looked through some ABBUC Magazines and found it in issue #118. It's called "Debug-Display". It's got four switches, and six 7-segment displays. Four for the address and two for the content of that address. Both of course in hexadecimal. Sincerely Mathy Is this a programmer's tool or does it have an everyday use? Quote Link to comment Share on other sites More sharing options...
Mathy Posted March 25, 2016 Share Posted March 25, 2016 Hello IndusGT I guess it's more a programmer's tool than something everybody would use every day. If you use the freezer a lot, you're probably gonna like the Debug-Display. AFAIK, the Debug-Display never made it to production. But since Panos is building the Freezer, it might be nice to have the Debug-Display build too. For a technical point of view, the Debug-Display is way simpler than the TF2011. Read more about the Debug-Display here on AtariAge. Sincerely Mathy Quote Link to comment Share on other sites More sharing options...
+slx Posted March 26, 2016 Share Posted March 26, 2016 Interested with XL/XE/Incognito adapters depending on price. Quote Link to comment Share on other sites More sharing options...
mega-hz Posted March 26, 2016 Share Posted March 26, 2016 The Debug Display didn't go into a series production because of nearly no people with interest of it! If there are interest of it, please contact me per EMAIL ! I still have some pcb`s... Wolfram. Quote Link to comment Share on other sites More sharing options...
Hellraiser Posted March 26, 2016 Share Posted March 26, 2016 interested in one. Quote Link to comment Share on other sites More sharing options...
ndary Posted March 26, 2016 Share Posted March 26, 2016 Me too Quote Link to comment Share on other sites More sharing options...
dragos Posted March 27, 2016 Share Posted March 27, 2016 (edited) I'm in for one Also interested in the debug display! Edited March 27, 2016 by dragos Quote Link to comment Share on other sites More sharing options...
+JAC! Posted March 29, 2016 Share Posted March 29, 2016 Hi Santosh, as for the "Debugger Display". There is one thing that I had in mind as an extension using the Turbo Freezer. The core of the debugger display is mainly a set of address/mode comparatrors that trigger something when a certain address is hit. My idea was to use that to virtually "press the freezer button" (and trigger an IRQ at the same time). This would allow for something that has never been there before: A hardware breakpoint The least that would be required, would be the possibility to somehow connect a write to the trigger button. 5 Quote Link to comment Share on other sites More sharing options...
Marius Posted March 29, 2016 Share Posted March 29, 2016 OH MY YES YES YES! A hardware breakpoint... that is something that would make my atari 8bit life much easier. As you all know I refuse to use emulators (only if I really can't find an issue with my code) ... so this would be a real good idea. Quote Link to comment Share on other sites More sharing options...
Panther Posted March 30, 2016 Share Posted March 30, 2016 The Turbo Freezer 2011 is already an incredible piece of hardware, and Panos' new version is extremely well done! I had to include one all lit up! Unfortunately, I've not yet managed to get it working on my Incognito's PBI, but that's not the fault of the Turbo Freezer. Thank you, Panos! 2 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted March 30, 2016 Share Posted March 30, 2016 Unfortunately, I've not yet managed to get it working on my Incognito's PBI, but that's not the fault of the Turbo Freezer. Despite previously soldering a pin header to the underside of the TF adapter, I've since realized the easiest way to hook the Freezer up to the Incognito is by using a standard 50 way XL PBI cable in the reverse orientation: 2 Quote Link to comment Share on other sites More sharing options...
kuestenturm Posted March 30, 2016 Share Posted March 30, 2016 Interested in one unit. Quote Link to comment Share on other sites More sharing options...
jdh Posted March 30, 2016 Share Posted March 30, 2016 Looks great. Put me down for one of these. Quote Link to comment Share on other sites More sharing options...
Panther Posted March 30, 2016 Share Posted March 30, 2016 (edited) Wait a sec, pin 1 isn't actually where pin 1 should be on the PBI, and doesn't match up with what is labeled pin 1 on the Incognito. Edited March 30, 2016 by Panther Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted March 30, 2016 Share Posted March 30, 2016 It must be, since it works. Quote Link to comment Share on other sites More sharing options...
Panther Posted March 30, 2016 Share Posted March 30, 2016 Unless I'm mistaken, if you wired directly, then pin 1 on the Incognito would end up at pin 2 on the PBI. Yes, it does work though. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted March 30, 2016 Share Posted March 30, 2016 Unless I'm mistaken, if you wired directly, then pin 1 on the Incognito would end up at pin 2 on the PBI. Yes, it does work though. Yeah: pin pairs often come out the opposite way round with these IDC connectors, but fortunately the pictured configuration is correct. Quote Link to comment Share on other sites More sharing options...
Panther Posted March 31, 2016 Share Posted March 31, 2016 When using the Turbo Freezer with the Incognito, if I enter the TF menu while in a game with player missile graphics the menu comes up and I can save, but upon returning to the game the spirtes are all messed up. Have you experienced this at all? Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted March 31, 2016 Share Posted March 31, 2016 (edited) I haven't yet run the Freezer with any games (I don't play them), but IIRC the Incognito BIOS menu seemed OK, and that uses four players (albeit by writing to the player graphics register in a DLI). Edited March 31, 2016 by flashjazzcat Quote Link to comment Share on other sites More sharing options...
HiassofT Posted March 31, 2016 Share Posted March 31, 2016 (edited) When using the Turbo Freezer with the Incognito, if I enter the TF menu while in a game with player missile graphics the menu comes up and I can save, but upon returning to the game the spirtes are all messed up. Have you experienced this at all?Is this specific to the Incognito or do you see similar issues on a "real" XL as well? Which games show these issues? I don't have an Incognito board so can't test myself. Edit: where did you save to, Freezer RAM, ramdisk or external file/disk? Was the screen collapsed/rolling after saving? Marius recently reported an issue with the Freezer, the screen flickering/rolling during save locked up his Atari (probably ANTIC DMA accessing some hardware registers that triggered sideeffects). I've already fixed that issue in my code, drop me a line if you want to beta-test the current development version. so long, Hias Edited March 31, 2016 by HiassofT Quote Link to comment Share on other sites More sharing options...
Panther Posted March 31, 2016 Share Posted March 31, 2016 The behavior only exists with the Incognito. The same games worked fine on both a stock XE and one with U1MB. Quote Link to comment Share on other sites More sharing options...
