acadiel
TI replacement power supply
15 minutes ago, Mehridian Sanders said:
Just as a side note, if you do go this route, you will either have to make sure that the onboard switch can handle the power inputs, or replace the switch. I know that when using 2 PSU side by side (eg: External Video Card, Thunderbolt External Enclosure, etc.) you have to shunt Pin 15 and 16 (on the main power connector) to the switch to allow it to power on and off the supply. I could be completely wrong here. Please let me know if I am misguided. 🙂
The connection on those pins is very low voltage, otherwise the people doing this stuff here--- would cause their jumper wire to catch fire.
https://www.overclockersclub.com/guides/atx_psu_startup/
It's a signal to the PSU to turn on. Not direct interrupt to system power. (at least on ATX supply.)
Intel says this about the PS_ON signal.
https://www.intel.co.jp/content/dam/www/public/us/en/documents/design-guides/resellers-power-supply-design-guide-changes.pdf
Quote
PS_ON# – Required
PS_ON# is an active-low, TTL-compatible signal that allows a motherboard to remotely control the power supply in conjunction with features such as soft on/off, Wake on LAN*, or wake-on-modem.
When PS_ON# is pulled to TTL low, the power supply should turn on the four main DC output rails: +12 VDC, +5 VDC, +3.3 VDC, and -12 VDC.
When PS_ON# is pulled to TTL high or open-circuited, the DC output rails should not deliver current and should be held at zero potential with respect to ground.
PS_ON# has no effect on the +5VSB output, which is always enabled whenever the AC power is present.
Table below lists PS_ON# signal characteristics.The power supply shall provide an internal pull-up to TTL high.
The power supply shall also provide de-bounce circuitry on PS_ON# to prevent it from oscillating on/off at startup when activated by a mechanical switch.
The DC output enable circuitry must be SELV-compliant.
The power supply shall not latch into a shutdown state when PS_ON# is driven active by pulses between 10 ms to 100 ms during the decay of the power rails.
Table 3-10: PS_ON# Signal Characteristics
Parameter                   Minimum          Maximum
VI        L0                     0.8
VIIL (VIN = 0.4 V)             -                        -1.6 mA1
VIH (IIN = 200 uA)           2.0 V                    -
VIH open circuit                 -                      -5.25
VRipple / Noise                                      400 mV p-p
Edited by wierd_w
One more comment about my << Message #73 >> if  a power tap for the Jedimatt42 keyboard upgrade was included on the PCB, it would sell more of those units.  Having a standardized easy plug & play assembly standard for the community would enable more people to upgrade as some of us no longer take on soldering tasks.   Since Greg sells most everything, it would definitely make things easier for the community as a whole.
If I am looking at the description correctly, shunting Pin 16 and 17 to a switch. Close but no cigar Sanders
18 hours ago, wierd_w said:
That's just a +5v DC and GND connection.  ATX has those in ample abundance. Could even be isolated from the main TI power if you wanted. Simple breakout.
I relooked at what you were saying and, yeah.  If you will excuse me, I will go find the nearest steel girder for cranial readjustment. Your power line is sound.
