Yurkie
ColecoVision with F18A (VGA Mod)
I just installed a F18A in a ColecoVision today, since I have had several requests to offer this as a mod service. Quality is great like everyone has said. I was also pleasantly surprised that the F18A simulates scanlines. I added a switch to turn scanlines off and on. I'll sell this console and include 12' VGA cable with breakout 3.5mm audio for if anyone's interested. Here is full screen pic of Donkey Kong and a zoomed pic, sorry about the glare in the full screen pic.
  • Like 4
The first video is rf or AV mod on a LCD tv which stretched the image. The F18a videos show the correct aspect ratio.
Got my VGA to HDMI converter today. Very impressive I expected picture to be washed out in analog to digital conversion but it is pixel perfect. Now just deciding if HDMI converter should be internal, or maybe both VGA and HDMI port on the back of the console. Perhaps even a power switch to power on and off the HDMI when not in use.
Wow. Never realized that. Does the F18A do this by default or do I have to remove some of the jumpers?
@vazquezrick: The F18A outputs a standard VGA [email protected] video signal, which is a 4:3 aspect (as Yurkie and Bmack36 confirmed). If you plug the F18A into a wide screen TV/monitor, the display might stretch the image. Many TVs have an option to show 4:3 aspect input video with left/right borders and maintain the original aspect. However, it seems many people would rather stretch the video to fill the screen.
@ColecoNoob: The virtual scan line option was added in the V1.6 firmware update. The scan lines can be enabled by removing a jumper, or new software specifically written to take advantage of the F18A enhanced features can enable them programmatically.
There are four “User Jumpers” on the F18A:
USR1: Selects the power-on default maximum number of sprites on a line:
On = 32 sprites can be displayed on a single line
Off = 4 sprites maximum can be displayed on a single line
USR2: Select simulated CRT scanlines:
On = no simulated scanlines
Off = enables simulated scanlines
USR3: Pin-37 GROMCLK / CPUCLK select:
On = GROMCLK output on pin-37 (9918A/28/29)
Off = CPUCLK output on pin-37 (9128/29)
USR4: Pin-38 CPUCLK enable:
On = disabled (Hi-Z)
Off = enabled
VDP        USR3 USR4
9928/29     on   on  pin-37 GROMCLK
                     pin-38 Hi-Z (disabled)
9918A/9118  on  off  pin-37 GROMCLK
                     pin-38 CPUCLK
9128/29     off  on  pin-37 CPUCLK
not used    off off  pin-37 CPUCLK
                     pin-38 CPUCLK
Yurkie,
Have you tested this out with the 2600 adapter? I doubt it will work since it does not with my F18A modded Adam, but I thought I would ask anyways. Thanks!
Yurkie,
The F18a replaces the video circuitry. I believe the 2600 module will still display via the RF and thru composite mod if added. But no VGA Atari.
Yes. I do them, Yurkie and Bmack36 do it as well. I suggest you contact them as I am not available to do these until around April-May.
Rey
Opcodes color line of games really shine on an F18A modded ColecoVision. There are some other titles that will be coming out that will definitely be worth playing on an F18a system as well. Definitely worth it!
Rey
Yes I do them as well. I also offer a HDMI output version as well that incorporates a HDMI scalar inside the system as well as uses an off the shelf 5V supply to power the system. If you have any questions feel free to ask. You can check out my FB page or store in my signature as well. Thanks.
I also sell pre-modified systems if that is a better option.
Does your pre-modded system work over hdmi only for Colecovision games, or does it also work with Atari 2600 games with the adapter?
With the F18a the colecovision video only goes out the VGA or HDMI output. EM1 atari module compatibility can be done in 2 ways: With the VGA mod you can get the EM1 video output out of the RF output. The HDMI mod requires a separate composite video mod to get the EM1 output, since the RF box is removed. The composite mod would only be for the EM1 as the colecovision output would be going out of the HDMI.
Any other questions feel free to ask.
Thanks
