whidobie Posted July 9, 2016 Share Posted July 9, 2016 Recently after years of sitting in a box, i found my Jaguar set. Turned it on and it seems to work except the picture is only in black & white. Can anyone offer a solution or a cause. Thanks in advance Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted July 9, 2016 Share Posted July 9, 2016 (edited) Are you using the RF out or A/V out? Is your Jag NTSC or PAL? Edited July 9, 2016 by walter_J64bit Quote Link to comment Share on other sites More sharing options...
whidobie Posted July 9, 2016 Author Share Posted July 9, 2016 Using a A/V As far as NTSC or PAL What is and how do u tell the difference? Quote Link to comment Share on other sites More sharing options...
Rick Dangerous Posted July 9, 2016 Share Posted July 9, 2016 Pal the power button light would be green. 1 Quote Link to comment Share on other sites More sharing options...
whidobie Posted July 9, 2016 Author Share Posted July 9, 2016 I have the NTSC as the power button is red Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted July 9, 2016 Share Posted July 9, 2016 Have you tried using the RF out to see if you get color? 1 Quote Link to comment Share on other sites More sharing options...
whidobie Posted July 9, 2016 Author Share Posted July 9, 2016 I'm using an A/V cable and it also is a brand new 4k TV Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted July 9, 2016 Share Posted July 9, 2016 (edited) I'm using an A/V cable and it also is a brand new 4k TV Ok, I get that but does the 4k TV have a way for you to use the RF out from the Jag? Edited July 9, 2016 by walter_J64bit Quote Link to comment Share on other sites More sharing options...
+madman Posted July 9, 2016 Share Posted July 9, 2016 RF would likely have the same thing. Probably bad output from the encoder. Quote Link to comment Share on other sites More sharing options...
sirlynxalot Posted July 9, 2016 Share Posted July 9, 2016 Go into the menu options on your TV and see if the video jack is set to composite or component. If its set to composite input, try switching it to component. Quote Link to comment Share on other sites More sharing options...
whidobie Posted July 9, 2016 Author Share Posted July 9, 2016 It was on componet Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted July 9, 2016 Share Posted July 9, 2016 (edited) Do you have other TV to try your Jag on? The 4K TV might not like the Jag's A/V out. Edited July 9, 2016 by walter_J64bit Quote Link to comment Share on other sites More sharing options...
sirlynxalot Posted July 9, 2016 Share Posted July 9, 2016 It was on componet Oh try switching it to composite. Does that do anything? 1 Quote Link to comment Share on other sites More sharing options...
+SabertoothRetro Posted July 9, 2016 Share Posted July 9, 2016 Oh try switching it to composite. Does that do anything? This. Mine had the same problem on a newer TV. You have to set to composite or it will be B&W. Quote Link to comment Share on other sites More sharing options...
whidobie Posted July 9, 2016 Author Share Posted July 9, 2016 This. Mine had the same problem on a newer TV. You have to set to composite or it will be B&W. That worked! THANKS!!!! 1 Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted July 9, 2016 Share Posted July 9, 2016 That worked! THANKS!!!! Good to see that worked and welcome to AA! Quote Link to comment Share on other sites More sharing options...
Fabio64 Posted January 7, 2022 Share Posted January 7, 2022 Hi, which AV cable are you using for your jaguar to a 4k Tele ? I have the same problem but with RF. I want to get the correct lead to make it work in colour. Thanks Quote Link to comment Share on other sites More sharing options...
