Jam out on your Atari! JAM_OUT.bin
Gameplay
Use the Joystick to create musical compositions on your Atari!
Composition Controls
Joystick - You control a Tracker/sequencer which contains predefined chiptunes and patterns.
The 8 directions on the joystick each trigger an initial pattern that will continue to play additional notes if you allow it. Holding the joystick in a direction will repeat the initial pattern, and you can switch the pattern/direction any time during play.
Perhaps the most interesting feature, the button increments the master tempo (loops from 0-11) which affects not just the tempo but also controls what Atari instruments are created.
Playback Controls
Select - Play back composition
Reset - Clear memory
Your composition is automatically recorded and can be quite long - the screen will turn RED when memory is full, and violet when playing back a composition (no input is accepted during playback).
Here is a composition where you can hear drums and bass guitar carrying a fast beat with a Lute and xylaphone performing the slow haunting melody, and cymbals and other interesting sounds and effects:
Haunting Melody composed with JAM OUT on the VCS.zip
What can you create? :)
JAM OUT is written in BASIC and easy to modify - I will post the source code on the programming thread so anyone who wishes can change the default patterns in the Tracker to create other instruments and sequences to jam with!
