Atari 400 PSU Fuse help needed.
Megadisk
Hello!
The other day I decided to give my Atari 400 computer and Atari 5200 system a go after a while of being sitting without much use but unfortunately, I accidentally swapped the power supplies cords for each system and right after that the Atari 400 Ac adapter didn't worked again (model # CO 14319 ). I then test it with a multimeter and there was no juice coming of out it so I had to crack the brick and sure enough, there is an old glass fuse that is shoot.
Does anyone knows what type of fuse is it? (Slow/fast blow) or if there is a good substitute for it? Here some pics below. The fuse in question is the one on the right hand side
Thanks in advance for any help.
Edited by Megadisk
Does the case have the output rating printed on it? The fuse would likely be rated slightly above the output Amperage. Those types usually have the rating stamped into one of the ends.
The only I have for my 400 says 2 Amps (bigger size wall wart type) but I also found a photo of one rated at 3.4 Amps which seems a bit excessive.
I assume you're talking a fuse on the output stage, as it would have to be different if on the input.
Isn't the disk drive PSU rated higher? I guess the smart thing would be to go for the high end since they're interchangable.
Yep, I've read that the CO14319 was shipped with the original 400's, 850's and 1010's. And later 400's came with the 31VA.
Edited by AtariGeezer
  • 6 months later...
I have two C017945 power bricks that both fuses blew (due to the ferrite choke in my 400 coming loose and shorting pins on the circuit board right under where the power enters). I'm looking to add a fuse holder that you can access without opening the power supply, but I'd like to replace the fuse with an exact replacement if possible.
I've pulled the fuse out, and taken a picture. Mine is a 5A/250VAC slow blow fuse (made by Littlefuse), but it's interesting as it has a spring in half of it. I've seen this type of fuse described over on stack exchange, but have not seen the name for the type. Does anyone here know the type? I've attached a picture of it. I may try contacting Littlefuse to see if anyone there would be able to identify the fuse.
This is the closest I could find in a quick search.
https://www.tubedepot.com/products/glass-fuse-3ag-size-1-1-4-x-1-4-slow-blow
I did find the following page which shows a picture of the fuse with the spring, but it doesn't mention anything about any difference between it and the other type of slow-blow fuse.
http://electronics.stackexchange.com/questions/25055/slow-blow-vs-fast-acting-fuse
With some more searching I found a site that still has some of the discontinued Bussman MDX-2 2A 250V SLOW BLOW FUSE which matches. It appears to have been replaced by the MDL-2 type of fuse in the Bussman brand.
http://www.btw-electronics.net/Electro-Mechanical/Fuses?page=6
Edited by BillC
  • 2 weeks later...
So I got around to fixing one of my two broken supplies. I installed a case mounted fuse holder so a fuse swap will be simple if were to blow again.
I used this fuse holder:
https://www.digikey.com/product-detail/en/littelfuse-inc/03420858H/F015-ND/17931
And got a couple of these fuses:
https://www.digikey.com/product-detail/en/littelfuse-inc/0313005.MXP/F1769-ND/778306
It works quite well. It was a very tight fit with the fuse holder. I'd have liked to have used a push button reset breaker instead, but I don't think there'd have been any way to fit that in the case.
