Megadisk #1 Posted July 20, 2016 (edited) Hello! The other day I decided to give my Atari 400 computer and Atari 5200 system a go after a while of being sitting without much use but unfortunately, I accidentally swapped the power supplies cords for each system and right after that the Atari 400 Ac adapter didn't worked again (model # CO 14319 ). I then test it with a multimeter and there was no juice coming of out it so I had to crack the brick and sure enough, there is an old glass fuse that is shoot. Does anyone knows what type of fuse is it? (Slow/fast blow) or if there is a good substitute for it? Here some pics below. The fuse in question is the one on the right hand side Thanks in advance for any help. Edited July 20, 2016 by Megadisk Quote Share this post Link to post Share on other sites
Rybags #2 Posted July 20, 2016 Does the case have the output rating printed on it? The fuse would likely be rated slightly above the output Amperage. Those types usually have the rating stamped into one of the ends. The only I have for my 400 says 2 Amps (bigger size wall wart type) but I also found a photo of one rated at 3.4 Amps which seems a bit excessive. I assume you're talking a fuse on the output stage, as it would have to be different if on the input. Quote Share this post Link to post Share on other sites
AtariGeezer #3 Posted July 20, 2016 The 9V AC 31VA power adapter has a 250V 5A on the output. Think it's a slow-blow... 1 Quote Share this post Link to post Share on other sites
Rybags #4 Posted July 21, 2016 Isn't the disk drive PSU rated higher? I guess the smart thing would be to go for the high end since they're interchangable. Quote Share this post Link to post Share on other sites
Megadisk #5 Posted July 21, 2016 Yes, is the fuse on the output of the transformer. Right now is full of the tape gunk but it does look like is rated at 5A . So it is slowblow then? Quote Share this post Link to post Share on other sites
AtariGeezer #6 Posted July 21, 2016 For the 9VAC 15VA power adapter, I think a 250V 2.5A or 3A slow blow would be safe. Quote Share this post Link to post Share on other sites
Megadisk #7 Posted July 21, 2016 Cool thanks!. I'm hoping to have some fuses in my stash. Quote Share this post Link to post Share on other sites
AtariGeezer #8 Posted July 21, 2016 (edited) Isn't the disk drive PSU rated higher? I guess the smart thing would be to go for the high end since they're interchangable. Yep, I've read that the CO14319 was shipped with the original 400's, 850's and 1010's. And later 400's came with the 31VA. Edited July 21, 2016 by AtariGeezer Quote Share this post Link to post Share on other sites
oryan_dunn #9 Posted February 7, 2017 I have two C017945 power bricks that both fuses blew (due to the ferrite choke in my 400 coming loose and shorting pins on the circuit board right under where the power enters). I'm looking to add a fuse holder that you can access without opening the power supply, but I'd like to replace the fuse with an exact replacement if possible. I've pulled the fuse out, and taken a picture. Mine is a 5A/250VAC slow blow fuse (made by Littlefuse), but it's interesting as it has a spring in half of it. I've seen this type of fuse described over on stack exchange, but have not seen the name for the type. Does anyone here know the type? I've attached a picture of it. I may try contacting Littlefuse to see if anyone there would be able to identify the fuse. Quote Share this post Link to post Share on other sites
BillC #10 Posted February 7, 2017 (edited) This is the closest I could find in a quick search. https://www.tubedepot.com/products/glass-fuse-3ag-size-1-1-4-x-1-4-slow-blow I did find the following page which shows a picture of the fuse with the spring, but it doesn't mention anything about any difference between it and the other type of slow-blow fuse. http://electronics.stackexchange.com/questions/25055/slow-blow-vs-fast-acting-fuse With some more searching I found a site that still has some of the discontinued Bussman MDX-2 2A 250V SLOW BLOW FUSE which matches. It appears to have been replaced by the MDL-2 type of fuse in the Bussman brand. http://www.btw-electronics.net/Electro-Mechanical/Fuses?page=6 Edited February 7, 2017 by BillC 1 Quote Share this post Link to post Share on other sites
oryan_dunn #11 Posted February 19, 2017 So I got around to fixing one of my two broken supplies. I installed a case mounted fuse holder so a fuse swap will be simple if were to blow again. I used this fuse holder: https://www.digikey.com/product-detail/en/littelfuse-inc/03420858H/F015-ND/17931 And got a couple of these fuses: https://www.digikey.com/product-detail/en/littelfuse-inc/0313005.MXP/F1769-ND/778306 It works quite well. It was a very tight fit with the fuse holder. I'd have liked to have used a push button reset breaker instead, but I don't think there'd have been any way to fit that in the case. Quote Share this post Link to post Share on other sites
