Sinphaltimus Posted December 2, 2016 Author Share Posted December 2, 2016 Huge performance gains yooze geyez!I completely rewrote all coinc routines and broke everything again but piecing it back together is revealing huge performance gains.Right now I'm attempting to make the actual coinc more efficient. I've pretty much got it so the entire level can be zombies and run great but as soon as any of them have a coinc=true moment, it all slows to a crawl. Which wouldn't even be noticeable if I can get it to ignore certain coincs when using (ALL,C). or at least filter out the useless COINCs detections so fast it doesn't affect performance.Well, back to it. 2 Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted December 5, 2016 Author Share Posted December 5, 2016 (edited) Huge performance gains excitement is off set by a bug I've been hunting for 3 days now. I know it's a typo, or wrong variable being used or wrong value being stored in an array someplace. I just don't know where yet.I'm crunching the code every second of every spare moment. *sigh* I really wanted to get this new version out to everyone. It completely revitalized my enthusiasm that this can be done in under 32k.But I'm running out of space just writing debugging code to hunt this thing down.Anywayz, any day now and I'll release the final alpha version just before going beta. I still need to get that new zombi "crawler" in game before beta. But that part is easy. Edited December 5, 2016 by Sinphaltimus Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted December 10, 2016 Author Share Posted December 10, 2016 (edited) This is the second release of 0.49, first release had player stuck and only able to move left and right by jumping. This version 0.49 is fixed from that. I got too hasty in uploading that I did not test a minor change I didn't think could go wrong. It did. No worries now. Go enjoy all the work I put in to this version...OK, Here's the >>>new ZOMBI game version 0.49 alpha<<< V0.49 changes: More code optimizations. Namely in cleaning up and reducing variables. More source code comments. Removed looting delay for all items. Adjusted jump delay to discourage jump abuse. Increased player running speed by 2 (Doubling it). Adjusted Zombie hole collision turn around distance. Found and removed zombi random speed change at every cycle. This code was supposed to only be present when a Zombi is created and when a Zombi hits a hole to turn around or fall. Fixed Melee attack animation frame issue. Complete rework of all coinc routines resulting in huge performance gains. Number of Zombis no longer crushes performance. New arrays, one per loot item and one for all loot. KNOWN ISSUES: NOT ALL FUNCTIONALITY OR GAME MECHANICS HAVE BEEN DEVELOPED AS OF THIS VERSION. Zombies are not doing damage to the player. Player can hold jump button and skip across holes. I don't recall if I fixed this but it's untested so here it stays until tested. Edited December 10, 2016 by Sinphaltimus Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted December 10, 2016 Author Share Posted December 10, 2016 Jumping to the right has frames facing left. Everything seems to slow down with more than one zombie. I now zombies aren't causing damage yet. But check out the performance now. I'm already working on 0.50. I'm going to introduce the new zombi type and that will pretty much conclude all game mechanics. It's just cleaning upand tweaking to bring the last few enhancements like level bonus' and such to the game. So once I get this new Zombi in game, it'll go BETA! Yeah. So excited. Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted December 11, 2016 Share Posted December 11, 2016 (edited) Yes, I tried walking and was stuck. Walking animation was good though. The new version, which I almost missed, has a blank screen and irritating sounds. Downloaded twice and started Classic99 twice. Old version. Jumping was too fast for one to enjoy any animation (if there was any). There was some smaller problems here and there. Like shots starting somewhere else or not appearing at all (may be due to more than 4 sprites horizontally). Still the zombies stop, start, rush etc. I think all the smaller local delay adjustments may drive you mad. You should have one master delay, maybe attached to the frame update using CALL SOUND which I believe senior_falcon also suggested. I used it in Shooting Stars (XB source available) and have the player, shots etc. running at the same speeds while the stars appear faster and faster. I simply have counters on the master delay (add 1 per frame to a variable and test if it has reached a certain amount, if so, do some stuff and reset). Edited December 11, 2016 by sometimes99er 1 Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted December 11, 2016 Author Share Posted December 11, 2016 (edited) Thanks for all that info. I'll get to all the issues once I get the new zombie in and go beta. I was worried about the performance issues and getting the game back to Stable state after the rewrite. 3 steps forward two steps back. Coding in the fly like this (no fans plan from the start) can be both fun and very frustrating for someone nor used to it. But I'm learning a lot and challenged to get it all done in under 32k. I'm gonna have to put all if you in the credits! Edited December 11, 2016 by Sinphaltimus 1 Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted December 11, 2016 Share Posted December 11, 2016 Thanks for all that info. Think carefully about attaching everything to one master delay. I'm not sure how GameMaker does it, apart from triggers, the overall speed of a game is timed (maybe not entirely exposed to the programmer). 3 steps forward two steps back. Yep. When you loose control, you have to step back and rewrite stuff to make it more clear, separated and / or obvious. I'm gonna have to put all if you in the credits! It could be a long list. I think, and hope, that crediting "AtariAge" may cover tools used, useful comments etc. 1 Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted December 11, 2016 Author Share Posted December 11, 2016 There was some smaller problems here and there. Like shots starting somewhere else or not appearing at all (may be due to more than 4 sprites horizontally). Yes, this is something I've been meaning to ask about. The 4 sprite per line thing. Is that per "pixel" line? I ask because I've attempted to mitigate this. The player sprite, bullet sprite and zombi sprites share y values but as far as I can see, nothing else does. I give the loot a lower y value (raising it up a little) to try and avoid this. It's something I'm leaving more towards the end of development. I still have mechanics to compete and hopefully get music in too before I really dig in and clean up everything and troubleshoot a thousand times. 1 Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted December 11, 2016 Author Share Posted December 11, 2016 (edited) OMG! What the heck? Why in the world would the bin file be doing that and not the ea5 file?Also, not sure which delays are being an issues. I use 3 delays in the game. I'm not using a sound delay method because I don't want to cause sound issues especially if I paln to add music.EDIT1:I found a double delay in the instruction screen - that's fixed in 0.50 along with zed player COINC (typo) and I changed the jumping animation back to my original method (I changed a lot of things just for testing and some haven't been changed back). I've not yet tested the new jumping animation, if I don't get to it in a few minutes, it'll have to wait until after werk.I am using a call link delay for the title and instruction screens because when you hit enter or move the joystick to go from title to instructions or instruction to game, the sensitivity is too tight and a player can easily go from title to playing without ever seeing the instruction screen. So I put delay after title before input accepted and a delay after instructions after the instructions for input to avoid this. That's one type of delay.Then I put a delay for Zombi vs. Player COINC. This is to avoid a zombi killing a plpayer in seconds. It spreads out the timing between Zed attacks.That delay is a manual counter using variables and checking certain conditions. If the player and ZED are COINC, the timer begins and continues to count as long as they remain in COINC. When it resets the Zed attacks again. The timer is also reset as soon as there is no COINC between player and ZED. The final type of delay I put is a for next loop when the player starts a jump. This is to avoid jumping abuse because a player can traverse a level faster if they just jump instead of running.I agree the jump is too fast, yes there is an animation frame in there.In game maker, the game engine has cycles, like CPU cycles that trigger events. The event timing is under very tight control of the engine so it's important to know the order you need specific events to happen. The actual ticks that run through out control the action. Gamemaker has an actual timer function with many triggers to choose from and result to apply. I've had to pretty much unlearn gamemaker to be able to code in extended basic. There are some basic commands I wish I had in extended basic. Namely switch statements. That would make life so much easier. I also wish we had a CALL COINC(#sprtie, ALL,8,c) function. That too would maker life so much easier. But I'm for the challenge. I honestly lost hope several times during this endeavor. Performance issues, low ram issues, all of it. I had to forget all the bad habits I picked up being an extremely messy coder (programming is something I'm learning slowly as I'm primarily a digital artist (art, animation, etc..) But I've always seemed to find a way around the limitation. It's one thing to code a retro game on a new engine and to code a retro game on original hardware (or emulation of such) so I am in completely unfamiliar territory. I owe all of it to this community helping me at every bump in the road. I've never used Extended Basic prior to my joining Atari Age. As a kid in the early 80s, it was a console, a tape deck and some cartridge games and manuals. So straight up BASIC back then. All of this, all of it, have made me a lot better than I was when I came here, a lot better in thinking about how to code in gamemaker as well. Which is something I am going to do when ready. I'm going to make a modern day equivalent to ZOMBi on the PC as a free game. And since I use GameMaker for Android as well, I will also port it to Android. But that's still a bit far off in to the future. I still have a lot of work to do on Jouncey in building 2 more worlds to complete that adventure....https://play.google.com/store/apps/details?id=org.SYMMLLC.JounceyFreeOne thing I know for sure. I'm back to the TI for the long haul. I want to use it as a platform for learning assembly. I've discovered I'm no good at jumping in to the high level programming engines without intricate knowledge of the underlying processes. Mainly because, as programming goes, I'm homebrewed and not formerly educated. I often think maybe I should go for my computer science degree instead of the Game Art and Design Degree I achieved. But, my primary passion is creating art. Perhaps someday I can take a real low level programming course. Edited December 11, 2016 by Sinphaltimus Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted December 11, 2016 Share Posted December 11, 2016 Yes, this is something I've been meaning to ask about. The 4 sprite per line thing. Is that per "pixel" line? I ask because I've attempted to mitigate this. The player sprite, bullet sprite and zombi sprites share y values but as far as I can see, nothing else does. I give the loot a lower y value (raising it up a little) to try and avoid this. It's something I'm leaving more towards the end of development. I still have mechanics to compete and hopefully get music in too before I really dig in and clean up everything and troubleshoot a thousand times. Yes, is the simple answer. One horizontal line of pixels can only display up to 4 sprites. The rest is ignored. You can turn this limitation off in Classic99 and with the F18A. Could however make your game hard to play on original hardware. Having 3 sprites at horizontal line 120 and 3 sprites at 124 will still have these occupy some horizontal lines. If you operate with 8x8 pixel sprites, lines 124-127 will have 6 sprites and only 4 will show. 2 sprites will appear chopped. You could place loot in the ceiling (having to jump and only checking when high), and it wouldn't then conflict with player, zombies and bullets. Even the bullets could be background characters. Bullets move fast and you could have 1 or 2 characters define the bullet (1 character moves 8 pixels and 2 characters can move 4 pixels - per something). Phew. A lot of info. I guess, and understand, you might want to get things working, add your other ideas, and get it like done. So taking steps back is like ... not really desirable. So for this one, you should absolutely consider ignoring the sprite limit. One day you could revisit the game and make it all more streamlined etc. Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted December 11, 2016 Share Posted December 11, 2016 Also, not sure which delays are being an issues. I use 3 delays in the game. I'm not using a sound delay method because I don't want to cause sound issues especially if I paln to add music. Well, maybe Harry could add a delay routine that simply waits for the next frame update. Think I read something about having music playing in 2 channels and another channel and noise for effects ? Yeah, 3 delays should be manageable. I am using a call link delay for the title and instruction screens because when you hit enter or move the joystick to go from title to intructions or instruction to game, the sensitivity is too tight and a player can easily go from title to playing without ever seeing the instruction screen. So I put delay after title before input accepted and a delay after instructions after the instructions for input to avoid this. That's one type of delay. Yep. When you go from title to instructions, show the instruction, then test for joystick and keys not being pressed, then go to a routine that do test for joystick or key pressed. Then I put a delay for Zombi vs. Player COINC. This is to avoid a zombi killing a plpayer in seconds. It spreads out the timing between Zed attacks. I would have a counter for the player (and probably also one per zombie). When the counter hits 20, the player dies. When a counter hits 5, the zombie dies. No delay with COINC, but only COINC once per pixel move ... (per frame - shlt I said it again) Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted December 11, 2016 Author Share Posted December 11, 2016 Yes, is the simple answer. One horizontal line of pixels can only display up to 4 sprites. The rest is ignored. You can turn this limitation off in Classic99 and with the F18A. Could however make your game hard to play on original hardware. Having 3 sprites at horizontal line 120 and 3 sprites at 124 will still have these occupy some horizontal lines. If you operate with 8x8 pixel sprites, lines 124-127 will have 6 sprites and only 4 will show. 2 sprites will appear chopped. OOOOOOOOH!!!!!!!!!! - Wow, I assumed the same pixel line meant the top left pixel from which position is drawn. You could place loot in the ceiling (having to jump and only checking when high), and it wouldn't then conflict with player, zombies and bullets. Even the bullets could be background characters. Bullets move fast and you could have 1 or 2 characters define the bullet (1 character moves 8 pixels and 2 characters can move 4 pixels - per something). DULY NOTED... "Phew. A lot of info." YEAH, I'm TMI kind of guy. Too much is always better than not enough.. I guess, and understand, you might want to get things working, add your other ideas, and get it like done. So taking steps back is like ... not really desirable. So for this one, you should absolutely consider ignoring the sprite limit. One day you could revisit the game and make it all more streamlined etc. I'm not sure. I started this game on the wrong assumption about sprite lines. There are some tweaks I can pull off now that could help fix this. The bullet doesn't have to be a sprite and doesn't need COINC if I make a percentage chance to hit within a certain distance from the player. Say 5 - 11 char spaces is 100% hit rate, beyond 11 char spaces we have 50% chance to miss, closer than 5 char spaces is a miss (because we want the ranged weapon ranged only and not to replace a melee weapon). That would mean I can eliminate COINC and Sprite for bullet easily. And it just occured to me that this will be an issue when zombies are able to drop down levels later in the game. Yeah. I'm going to put this 4 sprite limit on the back burner for a while and let it remain glitchy (after I fix the bullet issue as described above) I also suck at this multi-quote thing. Obviously. LOL Phew. A lot of info. I guess, and understand, you might want to get things working, add your other ideas, and get it like done. So taking steps back is like ... not really desirable. So for this one, you should absolutely consider ignoring the sprite limit. One day you could revisit the game and make it all more streamlined etc. Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted December 11, 2016 Share Posted December 11, 2016 I'm off to visit family. One can make TI-99/4A games in Game Maker, but most often not the other way around. Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted December 11, 2016 Share Posted December 11, 2016 I am using a call link delay for the title and instruction screens because when you hit enter or move the joystick to go from title to instructions or instruction to game, the sensitivity is too tight and a player can easily go from title to playing without ever seeing the instruction screen. So I put delay after title before input accepted and a delay after instructions after the instructions for input to avoid this. That's one type of delay. How about this: 10 PRINT TITLE SCREEN 20 CALL KEY(0,K,S)::IF S<1 THEN 20 30 PRINT INTRUCTIONS 40 CALL KEY(0,K,S)::IF S<1 THEN 40 50 START GAME Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted December 11, 2016 Author Share Posted December 11, 2016 I am doing exactly that but it's too fast and sensitive so I put the call link delay before that. Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted December 11, 2016 Share Posted December 11, 2016 I am doing exactly that but it's too fast and sensitive so I put the call link delay before that. I don't think you are doing exactly that. What I have shown forces the program to wait at lines 20 and 40 until a new key is pressed. It may be that you need to have: 5 CALL KEY(0,K,S) at the beginning in case you are holding a key down when the program starts up. Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted December 11, 2016 Author Share Posted December 11, 2016 (edited) I'll have to review my code when I get home. What happens is, when you press a key to go from the title to the instruction screen, the key release isn't fast enough because the instruction screen loads so fast due to your most excellent compressor. So I drop a call link delay right before the call key to allow a couple of seconds to release the key then repress. My "merged" text file in the zip can be reviewed for that. Unfortunately, I can't from work or I'll stop working. All the lines starting at 30000 are the title screens and related delays/call keys/joyst statements. Edited December 11, 2016 by Sinphaltimus Quote Link to comment Share on other sites More sharing options...
Tursi Posted December 11, 2016 Share Posted December 11, 2016 Senior Falcon is referring to checking that the Status from CALL KEY is less than 1. There are three possible values: 0 = no key pressed -1 = same key as last time STILL pressed 1 = new key pressed Most of the time, people tend to check for <> 0, which would catch both cases. But ignoring -1 as suggested should make it stop and wait for you to release the key, and then press anew. Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted December 11, 2016 Author Share Posted December 11, 2016 Senior Falcon is referring to checking that the Status from CALL KEY is less than 1. There are three possible values: 0 = no key pressed -1 = same key as last time STILL pressed 1 = new key pressed Most of the time, people tend to check for <> 0, which would catch both cases. But ignoring -1 as suggested should make it stop and wait for you to release the key, and then press anew. Oh. Well that makes total sense. I suppose it saves some bytes so that's a good thing. I wanted to add the joyst so folks don't have to lean over to press a key. I like to play sitting back from the console a bit. Now that I'm home, this is what I use - and I'm wondering why this would be an issue or unfavorable? 30320 CALL LINK("DELAY",200) 30330 CALL KEY(0,K,S):: CALL JOYST(1,X,Y) 30340 IF K=-1 AND S=0 AND X=0 AND Y=0 THEN 30330 Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted December 11, 2016 Author Share Posted December 11, 2016 (edited) OK, this version works. New ZOMBIv050 AVAILABLE >>HERE<< V0.50 changes: Fixed player/zombi collisions. Adjusted jumping animation Fixed double delay On instruction screen. Fixed .bin file issue that would crash classic99 and real iron upon load. It was a typo that made it through the assembly process. KNOWN ISSUES: NOT ALL FUNCTIONALITY OR GAME MECHANICS HAVE BEEN DEVELOPED AS OF THIS VERSION. Player can hold jump button and skip across holes. Edited December 11, 2016 by Sinphaltimus Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted December 11, 2016 Share Posted December 11, 2016 There is no "status" for joystick position like there is for CALL KEY so if you are moving the joystick to advance through the menu you are liable to skip ahead when you don't want to. Try using the joystick fire button which is read with CALL KEY. Something like this: 10 CALL KEY(1,K,S1)::CALL KEY(2,K,S2)::IF S1<1 AND S2<1 THEN 10 Nice and neat. No need for a delay which could be annoyingly long or annoyingly short. CALL KEY(1,K,S1) scans the left side of the keyboard and the fire button on joystick #1. CALL KEY(2,K,S2) scans the right side of the keyboard and the fire button on joystick #2. (The spacebar cannot be seen with the split keyboard scan) By the way, the key value returned when you press the fire button is 18. This is hard to find in the docs. 1 Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted December 11, 2016 Author Share Posted December 11, 2016 (edited) There is no "status" for joystick position like there is for CALL KEY so if you are moving the joystick to advance through the menu you are liable to skip ahead when you don't want to. Try using the joystick fire button which is read with CALL KEY. Something like this: 10 CALL KEY(1,K,S1)::CALL KEY(2,K,S2)::IF S1<1 AND S2<1 THEN 10 Nice and neat. No need for a delay which could be annoyingly long or annoyingly short. CALL KEY(1,K,S1) scans the left side of the keyboard and the fire button on joystick #1. CALL KEY(2,K,S2) scans the right side of the keyboard and the fire button on joystick #2. (The spacebar cannot be seen with the split keyboard scan) By the way, the key value returned when you press the fire button is 18. This is hard to find in the docs. Thanks, I'll give that a shot in the next version (0.51). And yep on the button = 18. I use it for jumping/dodging. I have to write code every time that will print K on a CALL KEY for me to find these things out. Edited December 11, 2016 by Sinphaltimus Quote Link to comment Share on other sites More sharing options...
Tursi Posted December 12, 2016 Share Posted December 12, 2016 Dude, thirty years later I still write loops with CALL KEY to get key code values. 1 Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted December 12, 2016 Author Share Posted December 12, 2016 (edited) Just because I'm going to end up crediting the entire TI-99/4a community anyway... LOL Here my Source for v0.51 which is not ready for release as I'm currently working on it: //ZOMB51 - ZOMBI V 0.51 ALPHA BY LEONARD RIVERA AND THE ATARIAGE TI-99/4A CREW // NOTES: EDIT LAST FEW LINES OF MAIN PROGRAM AFTER PASTE FROM TIDBIT TO MERGE WITH ZOMBITS3-M AND UNREMARK LINES 100 AND 1040. //MUST BE LOADED WITH XB256 RUNNING IF YOU PLAN TO RUN IT IN XB. //FOR MORE SIDE NOTES AND REFERENCE SCROLL TO BOTTOM PAST THE END OF THE MAIN PROGRAM, _START: ! GOSUB 30000 //GFX AND TITLE SCREENS *ALSO EDIT THE GOSUB RIGHT AFTER _DEAD (APROX L95 IN NP++) _GAMESTART: SCORE=5 :: HEALTH=5 :: BOARD=99 :: MELEE=5 :: RANGED=5 :: BULL=1 :: MAXHEALTH=10 :: MAXZHELTH=4 ZEDPERC=20 :: ZEDSTEPL=0 :: ZEDSETPR=0 :: JDELAY = 8 :: MAXMELEE=10 :: MAXRANGED=10 ATDELAY=10 :: ZSS=3 //ZED ATTACK DELAY, ZED MAX SPEED _NEWBOARD: RANDOMIZE SLOT=10 OPTION BASE 1 DIM LO0T(2,14) //ARRAY TO STORE SPRITE NUMBER AND CHAR CODE FOR ALL 14 LOOT ITEMS SPAWNED. DIM HART(3,14) //ARRAY TO STORE SPRITE NUMBER, Y POS, X POS FOR ALL HEART ITEMS SPAWNED. DIM RANG(1,14) //ARRAY TO STORE SPRITE NUMBER FOR ALL RANGED ITEMS SPAWNED. DIM MELE(1,14) //ARRAY TO STORE SPRITE NUMBER FOR ALL MELEE ITEMS SPAWNED. DIM ZEDZ(14,6) //ARRAY TO STORE ZED SPRITE NUMBER, ZED HOLE NUMBER, ZED DIRECTION, ZED SPEED, ZED HEALTH, ZED ACTIVE //GRND = 17 BECAUSE 9=PLAYER GROUND AND 17=REAL GROUND (9 PLUS 8PIXEL BOX) LTN=1 :: LAB=1 :: SHL=2 :: GRND=17 :: ZHELTH=4 :: YP=9 :: XP=8 :: PD=1 :: PS=2 //LOOT NUMBER, LOOT LABEL, GROUND, ZOMBI HEALTH, PLAYER Y POS, PLAYER X POS, PLAYER DIRECTION, PLAYER SPEED JMP=0 :: ZOMBEZ=0 :: ZDR=1 :: HCLR=1 :: TYMER=BOARD*2 //JUMPING STATUS, ZOMBI COUNT, ZOMBI DIRECTION, HOLE COLOR RLUT=1 :: MLUT=1 :: HLUT=1 :: HARTZ=0 :: RANGZ=0 :: MELEZ=0 :: PFALLIN=O //FOR _LDS ARRAY POPULATION OF LOOT. AND PLAYER FALLING STATUS ZHOL=2 _CREATELEVEL: CALL COLOR(1,12,1,2,12,1,3,12,1,4,12,1,5,12,1,6,12,1,7,12,1,8,15,1,14,10,1) :: CALL CLEAR :: CALL SCREEN(2) GOSUB _GUI HLE=INT((RND*15)+5) :: FOR LVL=1 TO 8 :: IF LVL<>1 THEN _GSLDS ELSE _910 //HLE = HOLE COORDINATE IN X PER LEVEL. WE SKIP LOOT DISTRIBUTION ON LEVEL 1 _GSLDS: GOSUB _LDS _910: CALL VCHAR(1,1,94,24) :: CALL VCHAR(1,32,94,24) :: CALL HCHAR(LVL*3,1,94,HLE-1)//LEFT WALL, RIGHT WALL, LEFT SIDE OF HOLE FLOOR IF LVL=8 THEN _920 ELSE _915 //LAST LEVEL WE HAVE TO HIDE HOLE SO USER EXITS AT DOOR _915: CALL SPRITE(#SHL,95,HCLR,GRND-7,(HLE*+1) :: SHL=SHL+1 //SHL = SPRITE NUMBER FOR HOLE 2 AT START OF BOARD - HERE WE MAKE BLACK HOLES NHLE=INT((GRND+1)/8) CALL HCHAR(NHLE+1,HLE+1,95) //GRAPHICS TO REPLACE BLACK HOLE. _920: LASTHLE=(HLE*+1 :: CALL HCHAR(LVL*3,HLE+3,94,32-(HLE+3)) //LAST HOLE DEFINITION AND LEFT SIDE OF HOLE GROUND. IF LVL=8 THEN _970 ELSE _921 // IF THIS IS LAST HOLE WE NEED TO TREAT IT DIFFERENTLY SO PLAYER WONT FALL. _921: CALL HCHAR(LVL*3,HLE,93) :: CALL HCHAR(LVL*3,HLE+2,93) :: GRND=GRND+24 //FLOOR ON RIGHT SIDE OF HOLE _940: HOL=INT((RND*15)+5) //DETERMINES LOCATION OF NEXT HOLE IF HOL=HLE THEN _940 ELSE _945 //ENSURE NEXT HOLE IS NOT DIRECTLY NDER PREVIOUS ONE. _945: HLE=HOL _970: NEXT LVL FOR EXTX=1 TO 31 STEP 30 :: FOR EXTY=2 TO 23 STEP 3 :: CALL HCHAR(EXTY,EXTX,143) :: NEXT EXTY :: NEXT EXTX CALL HCHAR(24,1,94,31) :: GOTO _SPIDLE //CREATE GIRDER _LDS: //SIDEZ DETERMINES WHAT SIDE OF THE HOLE A PARTICULAR LOOT ITEM WILL APPEAR. NEG#=LEFT POS#=RIGHT SIDEZ=-40 //START ON LEFT SIDE OF HOLE FOR REPT=1 TO 2 //ONCE FOR LEFT, ONCE FOR RIGHT SIDE OF HOLE IF LVL=8 AND ZOMBEZ=0 THEN _DOZED LDSN=INT(RND*100)+(1+ZEDPERC) //PICK A RANDOM NUMBER FROM 1-100 -- FIRST DISTRIBUTION NUMBER TO DETERMINE //HEARTS/ZEDS VS WEAPONS. IF LDSN<BOARD THEN _MR //IF THE RANDOM NUMBER IS HIGHER THAN THE PERCENTILE (60(LDSV) AT START OF GAME) THEN WEAPONS WIN // SO GO DETERMINE IF IT IS A MELEE WEAPON OR A RANGED WEAPON (_MR) _HZL: //LDSN (RANDOMLY SELECTED NUMBER) IS NOT HIGHER THAN THE PERCENTILE THRESHOLD (LDSV) LDSN=INT(RND*100)+(1+ZEDPERC) IF LDSN>BOARD THEN _DOZED // NUMBER BY MY ZEDPERCENTAGE INCREASE. IF THIS NEW NUMBER IS GREATER THAN THE CURRENT BOARD (START AT 99 END AT 0) _DOHART: // THEN GO DO ZED (_DOZED) ELSE DO HEARTS (_DOHART) CALL SPRITE(#SLOT,90,7,GRND-9,((HLE+1)*+SIDEZ) :: CALL POSITION(#SLOT,HY,HX) :: HART(2,HLUT)=HY :: HART(3,HLUT)=HX HART(1,HLUT)=SLOT :: SLOT=SLOT+1 :: HLUT=HLUT+1 :: HARTZ=HARTZ+1 LO0T(LAB,LTN)=90 :: LAB=LAB+1 :: LO0T(LAB,LTN)=SLOT-1 :: LAB=1 :: LTN=LTN+1 GOTO _NEXLDS _DOZED: IF BOARD>=51 THEN _NOUPZHELTH _NOUPZHELTH: CALL SPRITE(#SLOT,96,4,GRND-8,((HLE+1)*+SIDEZ) //ZED TABLE POPULATION PER LEVEL ZHELTH=MAXZHELTH //SETS ZED HEALTH FOR THIS ZED ZOMBEZ=ZOMBEZ+1 //UPS THE TOTAL ZED COUNT BY 1 ZEDZ(ZOMBEZ,1)=SLOT //ZED SPRITE NUMBER FOR THIS ZED ZHOLX=((HLE+1)* ZEDZ(ZOMBEZ,2)=ZHOLX //ZED HOLE X POSITION FOR THIS ZED ZEDZ(ZOMBEZ,3)=ZDR ZS=INT((RND*ZSS)+1) //SETS RANDOM ZED SPEED ZEDZ(ZOMBEZ,4)=ZS //STORE SPEED FOR THIS ZED ZEDZ(ZOMBEZ,5)=ZHELTH //STORE HEALTH FOR THIS ZED ZEDZ(ZOMBEZ,6)=1 //MAKE THIS ZED ACTIVE (CHANGE TO -1 WHEN ZED KILLED) SLOT=SLOT+1 //MOVE TO NEXT SPRITE NUBER SLOT FOR NEXT LOOT TO SPAWN. LO0T(LAB,LTN)=96 :: LAB=LAB+1 :: LO0T(LAB,LTN)=SLOT-1 :: LAB=1 :: LTN=LTN+1 IF BOARD>33 THEN _NEXLDS GOSUB _CREATECRAWLER GOTO _NEXLDS _MR: LDSN=INT(RND*100)+1 LDSN=LDSN+ZEDPERC //REGENERATE A RANDOM NUMBER TO DETERMINE RANGE OR MELEE WEAPON SPAWN. IF LDSN<BOARD THEN _DORAN //IF THE NUMBER IS GREATER THAN LDSV (60 PERCENT AT BOARD99) THEN DO RANGED (_DORAN) ELSE DO MELEE (_DOMEL) _DOMEL: MELE(1,MLUT)=SLOT :: MLUT=MLUT+1 :: MELEZ=MELEZ+1 CALL SPRITE(#SLOT,91,8,GRND-9,((HLE+1)*+SIDEZ) :: SLOT=SLOT+1 :: LO0T(LAB,LTN)=91 :: LAB=LAB+1 :: LO0T(LAB,LTN)=SLOT-1 :: LAB=1 :: LTN=LTN+1 GOTO _NEXLDS _DORAN: RANG(1,RLUT)=SLOT :: RLUT=RLUT+1 :: RANGZ=RANGZ+1 CALL SPRITE(#SLOT,92,14,GRND-9,((HLE+1)*+SIDEZ) :: SLOT=SLOT+1 :: LO0T(LAB,LTN)=92 :: LAB=LAB+1 :: LO0T(LAB,LTN)=SLOT-1 :: LAB=1 :: LTN=LTN+1 _NEXLDS: SIDEZ=40 :: NEXT REPT //DONE WITH LEFT SIDE LOOT, BO BACK AND DO RIGHT SIDE OF HOLE. RETURN _CREATECRAWLER: //CREATE THE CRAWLEER AT THE EXIT. LOCATE A HEART IF ANY, GO FOR IT IN THE AI. IF NO HEART GO FOR THE PLAYER IN THE AI. RETURN _GUI: ////OUTPUT GUI DISPLAY AT(1,3):SCORE :: DISPLAY AT(1,10):BOARD :: DISPLAY AT(1,15):HEALTH :: DISPLAY AT(1,21):MELEE :: DISPLAY AT(1,26):RANGED CALL VCHAR(1,3,75) :: CALL VCHAR(1,4,76) :: CALL VCHAR(1,5,77) :: CALL VCHAR(1,12,79) :: CALL VCHAR(1,17,64) :: CALL VCHAR(1,23,64) CALL VCHAR(1,28,64) :: CALL VCHAR(1,11,78) :: CALL VCHAR(1,16,90) :: CALL VCHAR(1,22,91) :: CALL VCHAR(1,27,92) ::RETURN _BOARDPROG: IF BOARD<=20 THEN _ZPA //I LOWER THE ZED SPAWN PERCENTILE SINCXE THE CHANCES ARE VERY HIGH ANYWAY. _MHC: IF BOARD<=75 THEN _MXHLT //POWER UP MAX HEALTH FOR PLAYER _MRC: IF BOARD<=50 THEN _MXRNG //POWER UP MAX RANGE FOR PLAYER _MMC: IF BOARD<=25 THEN _MXMEL ELSE _BPC //POWER UP MAX MELEE FOR PLAYER _ZPA: ZEDPERC=0 :: GOTO _MHC _MXHLT: MAXHEALTH=20 :: GOTO _MRC _MXRNG: MAXRANGED=20 :: MAXZHELTH=6 :: GOTO _MMC _MXMEL: MAXMELEE=20 _BPC: CALL DELSPRITE(ALL) :: BOARD=BOARD-1 :: IF SCORE>HSCORE THEN _HSCOR ELSE _DSPLAYHS _HSCOR: HSCORE=SCORE _DSPLAYHS: CALL SCREEN(2) :: FOR CCLOR=0 TO 14 :: CALL COLOR(CCLOR,16,1) :: NEXT CCLOR :: HCLR=2 :: CALL CLEAR CALL VCHAR(11,12,47) :: CALL VCHAR(11,13,36) :: CALL VCHAR(11,14,34) :: CALL VCHAR(11,15,47) CALL VCHAR(11,16,73) :: CALL VCHAR(11,17,40) :: CALL VCHAR(11,18,66) :: CALL VCHAR(11,19,71) CALL VCHAR(11,20,72) :: DISPLAY AT(12,13):HSCORE CALL LINK("DELAY",200) _HOLDHS: CALL KEY(1,K,S) :: IF S=0 THEN _HOLDHS GOTO _NEWBOARD _DEAD: CALL SCREEN(10) :: CALL CLEAR :: CALL DELSPRITE(ALL) ! GOSUB 30270 FOR CCLOR=0 TO 14 :: CALL COLOR(CCLOR,16,10) :: NEXT CCLOR DISPLAY AT(7,13):HSCORE :: DISPLAY AT(21,13):SCORE CALL SCREEN(2) :: CALL LINK("DELAY",200) _YADINPUT: CALL KEY(1,K,S) :: CALL JOYST(1,X,Y) :: IF K<>-1 OR S<>0 OR X<>0 OR Y<>0 THEN _NEWGAME GOTO _YADINPUT _NEWGAME: CALL DELSPRITE(ALL) :: GOTO _GAMESTART _RESET: CALL DELSPRITE(ALL) :: GOTO _START _QUIT: CALL CLEAR :: END :: RETURN _SPIDLE: CALL SPRITE(#1,104,6,YP,XP) CALL COINC(ALL,C) :: IF C=0 THEN _ZKIP GOSUB _PCD IF ZOMBEZ=0 THEN _JOYCHK CALL COINC(ALL,C) :: IF C=0 THEN _ZKIP GOSUB _ZCD _ZKIP: IF ZOMBEZ=0 THEN _JOYCHK GOSUB _ZEDAI _JOYCHK: CALL JOYST(1,JX,JY) :: CALL KEY(1,K,S) :: IF K=0 AND S=-1 THEN _QUIT IF K=16 THEN _BOARDPROG //DEVELOPER CHEAT TO TEST _LDS IF K=6 THEN _RESET // :: IF K=3 THEN GOSUB _DEBUGGER IF K=18 OR K=74 OR K=106 THEN _GSJMP IF JX<>0 OR JY<>0 THEN _JOYACTION ELSE _SPIDLE _GSJMP: JMP=1 :: GOSUB _JUMP :: JMP=0 :: GOTO _JOYACTION _JOYACTION: IF JY=0 THEN _MOVEIT ELSE _ATTACKIT _ATTACKIT: GOSUB _COMBAT _MOVEIT: CALL KEY(1,K,S) :: IF K=16 THEN _BOARDPROG IF K=18 OR K=74 OR K=106 THEN _JUMPER ELSE _JOYST _JUMPER: JMP=1 :: GOSUB _JUMP :: JMP=0 // :: IF K=3 THEN GOSUB _DEBUGGER _JOYST: IF JX<>0 THEN _SPRUN IF JY<>0 THEN _GSCBT ELSE _CONT _GSCBT: GOSUB _COMBAT _CONT: GOTO _SPIDLE _SPRUN: //CHCKL - CHECK LEFT IF JX=-4 THEN _GSSPL ELSE _CHCKR _GSSPL: GOSUB _SPLEFT _CHCKR: IF JX=4 THEN _GSSPR ELSE _SPIDLE _GSSPR: GOSUB _SPRIGHT CALL KEY(1,K,S) :: IF K=16 THEN _BOARDPROG IF K=18 OR K=74 OR K=106 THEN _RJUMPER ELSE _RJOYST _RJUMPER: JMP=1 :: GOSUB _JUMP :: JMP=0 // :: IF K=3 THEN GOSUB _DEBUGGER _RJOYST: IF JX<>0 THEN _SPRUN IF JY<>0 THEN _RGSCBT ELSE _RCONT _RGSCBT: GOSUB _COMBAT _RCONT: GOTO _SPIDLE _SPRIGHT: IF XP>=250 THEN _FLIPL ELSE _RUNR _FLIPL: XP=2 _RUNR: PD=1 :: CALL SPRITE(#1,105,6,YP,XP) FOR PATR=105 TO 110 :: CALL PATTERN(#1,PATR) :: CALL SOUND(1,-2,20) :: XP=XP+PS IF XP>=250 THEN _FLIPL2 ELSE _MOVEIT2 _FLIPL2: XP=2 _MOVEIT2: CALL LOCATE(#1,YP,XP) :: CALL KEY(1,K,S)// :: IF K=3 THEN GOSUB _DEBUGGER IF K=18 THEN _GOJMP IF K=74 THEN _GOJMP IF K=106 THEN _GOJMP ELSE _NOGOJMP _GOJMP: JMP=1 :: PATR=110 :: GOTO _CHECKCOLLISIONRUNRIGHT _NOGOJMP: CALL JOYST(1,JX,JY) :: IF JY=0 THEN _KEEPRUNR ELSE _GOSCOM1 _GOSCOM1: GOSUB _COMBAT _KEEPRUNR: IF JX<>0 THEN _CHECKRUNR CALL SPRITE(#1,104,6,YP,XP) :: RETURN _CHECKRUNR: IF JX=4 THEN _CHECKCOLLISIONRUNRIGHT IF JX=-4 THEN _GORET ELSE _CHECKCOLLISIONRUNRIGHT _CHECKCOLLISIONRUNRIGHT: CALL COINC(ALL,C) :: IF C=0 THEN _ZKIP1 GOSUB _PCD IF ZOMBEZ=0 THEN _SKIPZEDZ2 CALL COINC(ALL,C) :: IF C=0 THEN _ZKIP1 GOSUB _ZCD _ZKIP1: IF ZOMBEZ=0 THEN _SKIPZEDZ2 GOSUB _ZEDAI _SKIPZEDZ2: NEXT PATR IF JMP=1 THEN _GOSUBJUMPRUNRIGHT ELSE _NOGOSUBJUMPRUNRIGHT _GOSUBJUMPRUNRIGHT: GOSUB _JUMP ::JMP=0 _NOGOSUBJUMPRUNRIGHT: IF JX=4 THEN _SPRIGHT ELSE _GORET _SPLEFT: IF XP<=1 THEN _FLIPR ELSE _RUNL _FLIPR: XP=249 _RUNL: PD=-1 :: CALL SPRITE(#1,113,6,YP,XP) FOR PATL=113 TO 118 :: CALL PATTERN(#1,PATL) :: CALL SOUND(1,-2,20) :: XP=XP-PS IF XP<=1 THEN _FLIPR2 ELSE _MOVEIT3 _FLIPR2: XP=249 _MOVEIT3: CALL LOCATE(#1,YP,XP) :: CALL KEY(1,K,S)// :: IF K=3 THEN GOSUB _DEBUGGER IF K=18 THEN _GORLJMP IF K=74 THEN _GORLJMP IF K=106 THEN _GORLJMP ELSE _NOGORLJMP _GORLJMP: JMP=1 :: PATL=118 :: GOTO _CHECKCOLLISIONRUNLEFT _NOGORLJMP: CALL JOYST(1,JX,JY) :: IF JY=0 THEN _KEEPRUNL ELSE _GOSCOM2 _GOSCOM2: GOSUB _COMBAT _KEEPRUNL: IF JX<>0 THEN _CHECKRUNL CALL SPRITE(#1,44,6,YP,XP) :: RETURN _CHECKRUNL: IF JX=-4 THEN _CHECKCOLLISIONRUNLEFT IF JX=4 THEN _GORET ELSE _CHECKCOLLISIONRUNLEFT _CHECKCOLLISIONRUNLEFT: CALL COINC(ALL,C) :: IF C=0 THEN _ZKIP2 GOSUB _PCD IF ZOMBEZ=0 THEN _SKIPZEDZ3 CALL COINC(ALL,C) :: IF C=0 THEN _ZKIP2 GOSUB _ZCD _ZKIP2: IF ZOMBEZ=0 THEN _SKIPZEDZ3 GOSUB _ZEDAI _SKIPZEDZ3: NEXT PATL IF JMP=1 THEN _GSJRUNLFT ELSE _NOGSJRUNLFT _GSJRUNLFT: GOSUB _JUMP :: JMP=0 CALL COINC(ALL,C) :: IF C=0 THEN _ZKIP3 GOSUB _PCD IF ZOMBEZ=0 THEN _NOGSJRUNLFT CALL COINC(ALL,C) :: IF C=0 THEN _ZKIP3 GOSUB _ZCD _ZKIP3: IF ZOMBEZ=0 THEN _NOGSJRUNLFT GOSUB _ZEDAI _NOGSJRUNLFT: IF JX=-4 THEN _SPLEFT ELSE _GORET _JUMP: //// ********JUMP ROUTINE CHECK******** JMP=0 IF PD<>-1 THEN _5710 S1=128 :: J1=131 :: L1=134 :: JSND=18 :: S2=130 :: J2=133 :: L2=135 :: JMPDIS=-1//JUMPLEFT GOTO _5750 _5710: IF PD<>1 THEN _GORET S1=120 :: J1=123 :: L1=126 :: JSND=10 :: S2=122 :: J2=125 :: L2=127 :: JMPDIS=1 //JUMP RIGHT _5750: CALL LOCATE(#1,YP,XP) //FROM RUNNING TO STOPPING LEFT FOR PTS=S1 TO S2 :: CALL SOUND(1,(PTS-JSND),5) :: CALL PATTERN(#1,PTS) :: NEXT PTS FOR UDELAY=1 TO JDELAY :: IF ZOMBEZ=0 THEN _SKIPZEDZ5 GOSUB _ZEDAI :: CALL COINC(ALL,C) :: IF C=0 THEN _SKIPZEDZ5 GOSUB _ZCD _SKIPZEDZ5: NEXT UDELAY // CALL COINC(ALL,C) :: IF C<>0 THEN _ZCD :: NEXT UDELAY YP=YP-3 :: CALL LOCATE(#1,YP,XP) JMP=1 FOR PTJ=J1 TO J2 //JUMP (JUMPING) FOR PTJP=1 TO 7 XP=XP+JMPDIS IF XP<=1 THEN _CREATEPLAYERRIGHT ELSE _CHECKPLAYERRIGHT _CREATEPLAYERRIGHT: XP=248 :: GOTO _NOMOREEDGES _CHECKPLAYERRIGHT: IF XP>=249 THEN _CREATEPLAYERLEFT ELSE _NOMOREEDGES _CREATEPLAYERLEFT: XP=2 _NOMOREEDGES: CALL PATTERN(#1,PTJ) :: CALL SOUND(1,(PTJ-JSND),5) :: CALL LOCATE(#1,YP,XP) NEXT PTJP NEXT PTJ YP=YP+3 :: CALL LOCATE(#1,YP,XP) FOR PTL=L1 TO L2 IF PTL=L1 THEN _NXTPTL // SKIP THE DELAY UNTIL LAST FRAME IF ZOMBEZ=0 THEN _NXTPTL GOSUB _ZEDAI :: CALL COINC(ALL,C) :: IF C=0 THEN _NXTPTL GOSUB _ZCD _NXTPTL: CALL PATTERN(#1,PTL) :: CALL SOUND(1,(PTL-JSND),5) :: NEXT PTL CALL COINC(ALL,C) :: IF C<>0 THEN _GSCOLDET ELSE _GORESET _GSCOLDET: RETURN _GORESET: ATDELAY=10 :: RETURN _COMBAT: ////*****JOYS COMBAT CHOICE***** IF JY=4 AND MELEE>=1 THEN _5360 :: IF JY=4 AND MELEE<=0 THEN _5350 IF JY=-4 THEN _5330 ELSE _GORET _5330: GOSUB _ATTACKR :: RETURN _5350: CALL SOUND(100,-3,0) :: RETURN _5360: MELEE=MELEE-1 :: GOSUB _GUI GOSUB _ATTACKM :: RETURN IF JY=-4 THEN _5400 ELSE _5405 _5405: CALL SOUND(100,-6,0) :: RETURN _5400: GOSUB _ATTACKR :: RETURN _ATTACKM: CALL PATTERN(#1,136) IF XP+8>=250 THEN _S2OTHER1 CALL SPRITE(#24,82,12,YP,XP+ :: GOTO _S2SOWND _S2OTHER1: CALL SPRITE(#24,82,12,YP,XP) _S2SOWND: CALL SOUND(125,-5,0) GOSUB _MELCOLLOO IF XP+8>=250 THEN _S2OTHER2 //SKIP TO SOUND CALL DELSPRITE(#24) :: IF XP-8<=1 THEN _S2OTHER2 CALL SPRITE(#25,82,12,YP,XP- :: GOTO _S2SOWND2 _S2OTHER2: CALL SPRITE(#25,82,12,YP,XP) _S2SOWND2: CALL SOUND(125,-6,0) GOSUB _COLCKM2 CALL DELSPRITE(#25) :: CALL PATTERN(#1,136) //:: CALL COLOR(#DET,4) RETURN _MELCOLLOO: FOR DET=10 TO 23 :: CALL COINC(#24,#DET,7,C) :: IF C<>0 THEN _5470 NEXT DET :: RETURN _COLCKM2: FOR DET=10 TO 23 :: CALL COINC(#25,#DET,7,C) :: IF C<>0 THEN _5470 NEXT DET :: RETURN _5470: TLOOP1=DET-9 _5490: IF LO0T(1,TLOOP1)<>96 THEN _LOOTCOL //NOT A ZED HIT _ZOMBIEHITMELEE: //WHAT ZOMBIE IS HIT? CALL COLOR(#DET,7) :: LSPRN=LO0T(2,TLOOP1) //GETS SPRITE NUMBER OF LOOT HIT TO CHECK FOR ZCHEK=1 TO 14 //NEED TO FIND ZOMBIE IN ZOMBIE ARRAY FOR STATS ZPRN=ZEDZ(ZCHEK,1) IF LSPRN<>ZPRN THEN _NXZCK ZHELTH=ZEDZ(ZCHEK,5) :: ZHELTH=ZHELTH-1 :: ZEDZ(ZCHEK,5)=ZHELTH //GET ZOMBIE CURRENT HEALTH - HEALTH PENALTY TO ZED FOR MELEE HIT. - STORE ZOMBIE NEW HEALTH IF ZHELTH>=1 THEN _GORET // :: IF ZOMBIE STILL STANDING END THE ATTACK ROUND OR ELSE KILL IT. SCORE=SCORE+15 :: ZEDZ(ZCHEK,6)=-1 :: CALL DELSPRITE(#LSPRN) :: ZOMBEZ=ZOMBEZ-1 :: RETURN _NXZCK: NEXT ZCHEK RETURN _LOOTCOL: //OTHER THAN ZED LOOT HIT BY MELEE IF LO0T(1,TLOOP1)<>90 THEN _5540 ELSE _5560 _5540: IF LO0T(1,TLOOP1)<>91 THEN _5550 ELSE _5560 _5550: IF LO0T(1,TLOOP1)<>92 THEN _GORET _5560: FOR LCHEK=1 TO 14 :: IF DET=LO0T(LCHEK,2) THEN _WRLC5 ELSE _NXTLCHEK4 _WRLC5: LCHEK=14 _NXTLCHEK4: NEXT LCHEK :: CALL DELSPRITE(#DET) _5570: RETURN _ATTACKR: IF RANGED<=0 THEN _CLSND ELSE _3570 _CLSND: CALL SOUND(100,-3,0) :: RETURN _3570: RANGED=RANGED-1 :: CALL SOUND(100,-6,0) :: GOSUB _GUI YB=YP //*********************************SHOOT RIGHT IF PD<>1 THEN _4210 CALL PATTERN(#1,138) BULL=1 XB=XP+32 GOTO _BULFIRE //*********************************SHOOT LEFT _4210: IF PD<>-1 THEN _GORET CALL PATTERN(#1,137) BULL=-1 XB=XP-32 //*********************************BULLET FIRE RIGHT _BULFIRE: _BVH: CALL SPRITE(#26,83,6,YB,XB) FOR BHCK=2 TO 8 _BHCKCONT: CALL COINC(#26,#BHCK,8,C) :: IF C=0 THEN _NEXTBHCK XB=XB+BULL :: CALL LOCATE(#26,YB,XB) :: IF XB<=2 OR XB>=249 THEN _ATTACKEND ELSE _BHCKCONT _NEXTBHCK: NEXT BHCK _4910: CALL COINC(ALL,C) :: IF C<>0 THEN _BULHIT _BULLCONT: XB=XB+BULL :: IF XB<=2 OR XB>=249 THEN _ATTACKEND ELSE _BVH _BULHIT: //WHAT DID THE BULLET HIT? CALL LOCATE(#26,YB,XB) :: FOR LCHECK=1 TO 14 :: LSPRN=LO0T(2,LCHECK) :: LCHKB=LO0T(1,LCHECK) //GETS SPRITE NUMBER OF LOOT HIT TO CHECK - GETS CHARCODE OF LOOT HIT TO CHECK _BUHOCK: //BULLET HOLE CHECK IF LSPRN<=9 OR LSPRN>=24 THEN _GSBULCON ELSE _CONLC //MAKE SURE IT IS A PROPER LOOT HIT AND NOT A HOLE HIT. _GSBULCON: // THIS IS MEANT TO SPEED UP THE BULLET WHEN IN COTACT WITH A HOLE SPRITE INSTEAD OF _BULLCONT XB=XB+BULL :: CALL LOCATE(#26,YB,XB) :: CALL COINC(#26,#LSPRN,8,C) :: IF C<>0 THEN _BUHOCK _CONLC: //CONTINUE LOOT CHECK (NOT A HOLE) CALL COINC(#26,#LSPRN,8,C) //CHECK FOR COLLISION WITH SAID LOOT. IF C=0 THEN _NEXTCOLCHECKLB // NO COLLISION BETWEEN THIS GUY AND THE NEXT. IF LCHKB=96 THEN _ZOMBIEHIT ELSE _LOOTHIT //IF IT EQUALS A ZOMBIE, GOTO ZOMBIE HIT _ZOMBIEHIT: //WHAT ZOMBIE IS HIT? CALL COLOR(#LSPRN,7) FOR ZCHEK=1 TO 14 :: AZED=ZEDZ(ZCHEK,6) :: IF AZED=-1 THEN _NXTZCHEK //NEED TO FIND ZOMBIE IN ZOMBIE ARRAY FOR STATS AND SKIP ON NO OR INACTIVE ZEDS ZPRN=ZEDZ(ZCHEK,1) :: IF LSPRN<>ZPRN THEN _NXTZCHEK ZHELTH=ZEDZ(ZCHEK,5) :: ZHELTH=ZHELTH-2 :: ZEDZ(ZCHEK,5)=ZHELTH //GET ZOMBIE CURRENT HEALTH - HEALTH PENALTY TO ZED FOR BULLET HIT. - STORE ZOMBIE NEW HEALTH IF ZHELTH>=1 THEN _ATTACKEND // IF ZOMBIE STILL STANDING END THE ATTACK ROUND OR ELSE KILL IT. SCORE=SCORE+15 :: ZEDZ(ZCHEK,6)=-1 :: CALL DELSPRITE(#LSPRN) :: ZOMBEZ=ZOMBEZ-1 :: GOTO _ATTACKEND _LOOTHIT: //DESTROY HIT LOOT CALL COLOR(#LSPRN,7) :: CALL DELSPRITE(#LSPRN) :: LO0T(2,LCHECK)=1 :: GOTO _ATTACKEND _NXTZCHEK: NEXT ZCHEK :: GOTO _ATTACKEND _NEXTCOLCHECKLB: NEXT LCHECK :: GOTO _BULLCONT _ATTACKEND: // ATTACK RANGED AGAIN OR END ********************* CALL DELSPRITE(#26) :: GOSUB _GUI :: CALL JOYST(1,JX,JY) :: IF JY=0 THEN _GORET IF JY-4 THEN _GSATTR ELSE _GORET _GSATTR: GOSUB _ATTACKR :: RETURN _PCD: //PLAYER COLLISION DETECTION //CHECK COLLISIONS AGAINST HEARTS IF JMP=1 THEN _GORET IF HARTZ<=0 THEN _PLMLCO FOR HCOINC=1 TO 14 AHART=HART(1,HCOINC) IF AHART=-1 THEN _NXTHCO IF AHART=0 THEN _ENDHCO CALL COINC(#1,#AHART,8,C) IF C=0 THEN _NXTHCO SCORE=SCORE+10 :: CALL SOUND(1,500,5) :: CALL SOUND(1,600,2) IF HEALTH<MAXHEALTH THEN _GSHEL ELSE _GSGUI2 _GSHEL: HEALTH=HEALTH+1 _GSGUI2: GOSUB _GUI :: CALL DELSPRITE(#AHART) :: HART(1,HCOINC)=-1 :: HARTZ=HARTZ-1 :: GOTO _NXTHCO _ENDHCO: HCOINC=14 _NXTHCO: NEXT HCOINC //CHECK MELEE COLLISIONS IF ANY _PLMLCO: IF MELEZ=0 THEN _PLRGCO FOR MCOINC=1 TO 14 AMELE=MELE(1,MCOINC) IF AMELE=-1 THEN _NXTMCO IF AMELE=0 THEN _ENDMCO CALL COINC(#1,#AMELE,8,C) IF C=0 THEN _NXTMCO SCORE=SCORE+3 :: IF MELEE<MAXMELEE THEN _COLM ELSE _CONCOLM _COLM: MELEE=MELEE+1 _CONCOLM: CALL SOUND(1,1500,5) :: CALL SOUND(1,1600,2) :: GOSUB _GUI :: CALL DELSPRITE(#AMELE) :: MELE(1,MCOINC)=-1 :: MELEZ=MELEZ-1 _ENDMCO: MCOINC=14 _NXTMCO: NEXT MCOINC //CHECK RANGED COLLISIONS IF ANY _PLRGCO: IF RANGZ=0 THEN _HOLEPCHEKR FOR RCOINC=1 TO 14 ARANG=RANG(1,RCOINC) IF ARANG=-1 THEN _NXTRCO IF ARANG=0 THEN _ENDRCO CALL COINC(#1,#ARANG,8,C) IF C=0 THEN _NXTRCO SCORE=SCORE+5 :: IF RANGED<MAXRANGED THEN _CRAN ELSE _CONCRAN _CRAN: RANGED=RANGED+1 _CONCRAN: CALL SOUND(1,1000,5) :: CALL SOUND(1,1200,2) :: GOSUB _GUI :: CALL DELSPRITE(#ARANG) :: RANG(1,RCOINC)=-1 :: RANGZ=RANGZ-1 _ENDRCO: RCOINC=14 _NXTRCO: NEXT RCOINC _HOLEPCHEKR: //THERE ARE 7 HOLES TO CHECK AGAINST. FOR HOLDET=2 TO 8 CALL COINC(#1,#HOLDET,10,C) IF C=0 THEN _NEXTHOLEDETECT FOR FALLIN=12 TO 1 STEP -1 :: YP=YP+2 :: CALL SOUND(1,FALLIN*110,5) :: CALL SPRITE(#1,104,6,YP,XP) :: PFALLIN=1 :: GOSUB _ZEDAI :: NEXT FALLIN :: PFALLIN=0 _NEXTHOLEDETECT: NEXT HOLDET _EXITCHK: CALL POSITION(#1,YP,XP) :: IF YP=177 AND XP>=235 THEN _BOARDPROG IF YP=177 AND XP<=8 THEN _BOARDPROG _GORET: RETURN _ZEDAI: //GOSUB _CRAWLERAI _ZEDCC: IF ZOMBEZ=0 THEN _GORET //NO NEED TO CHECK ANY ZEDAI IF THERE ARE NO ZEDS TZEDZ=ZEDZ(1,1) :: ZHOLX=ZEDZ(1,2) :: ZDR=ZEDZ(1,3) :: ZS=ZEDZ(1,4) :: AZED=ZEDZ(1,6) FOR ZCK=1 TO 14 //UP TO 14 ZEDS POSSIBLE TO CHECK AGAINST _ZOMB2: TZEDZ=ZEDZ(ZCK,1) :: ZHOLX=ZEDZ(ZCK,2) :: ZDR=ZEDZ(ZCK,3) :: ZS=ZEDZ(ZCK,4) :: AZED=ZEDZ(ZCK,6)//SPRITE NUMBER:NEIGHBORING HOLE X POSITION:DIRECTION:SPEED:ACTIVE OR DEAD IF AZED=-1 THEN _NEXTZED // IF A ZED IS NOT ACTIVE SKIP TO NEXT ZED CHECK. IF TZEDZ=0 THEN _ALLDONE ELSE _CONZAI // TZEDZ IS A SPRITE NUMBER. IF IT EQUALS 0 THEN IT'S THE END OF THE LIST IN THE ARRAY. _ALLDONE: ZCK=14 :: GOTO _NEXTZED //END THE LOOPED ZED CHECK. _CONZAI: CALL POSITION(#TZEDZ,ZY,ZX) // THE ONLY POINT TO THIS CALL POSITIN IS TO GET THE XY FOR THIS PARTICULAR ZED STRAIGHT. _NOGSCZ: //*************************************CHECK FOR ZED CHASE LEVEL AND CODE HERE************************ CALL POSITION(#1,YP,XP) IF BOARD>66 THEN _CONZMOV //IF LEVEL IS 66 OR LOWER, ENABLE CHASING ZEDS. IF YP<>ZY AND BOARD >33 THEN _CONZMOV // IF BOARD >33 AND ZED/PLAYER NOT SAME LEVEL, DO NOT CHASE (CHASE LEVEL 33 DOWN REGARDLESS OF ZED/PLAYER LEVEL) IF ZX<XP THEN _CHCD //IF ZED IS LEFT OF PLAYER SET POSITIVE DIR TO CHASE PLAYER ELSE KEEP GOING IN SAME DIRECTION. ZDR=-1 :: ZEDZ(ZCK,3)=-1 :: GOTO _CONZMOV _CHCD: ZDR=1 :: ZEDZ(ZCK,3)=1 //:: print "5aZDR:";ZDR _CONZMOV: GOSUB _ZEDPATTERN :: GOTO _ZEDMOVE //UPDATE ANIMATION FRAMES THEN MOVE THE ZED _ZEDPATTERN: IF ZDR=1 THEN _ZPATR ELSE _ZPATL //FIGURE OUT WHICH DIRECTION THE ZED IS MOVING _ZPATR: IF ZEDSTEPR=0 THEN _ZPRSW1 ELSE _ZPRSW2 //FIGURE OUT WHICH ANIMATION FRAME THE ZED IS CURRENTLY ON _ZPRSW1: CALL SPRITE(#TZEDZ,100,4,ZY,ZX) :: ZEDSTEPR=1 :: RETURN //CHANGE TO APPROPRIATE PATTERN AND LOCATION, RECALL SPRITE AND CHANGE PATTERN RECORD FOR NEXT CHECK _ZPRSW2: CALL SPRITE(#TZEDZ,99,4,ZY,ZX) :: ZEDSTEPR=0 :: RETURN //SAME AS PREVIOUS COMMENT _ZPATL: IF ZEDSTEPL=0 THEN _ZPLSW1 ELSE _ZPLSW2 //FIGURE OUT WHICH ANIMATION FRAME THE ZED IS CURRENTLY ON _ZPLSW1: CALL SPRITE(#TZEDZ,98,4,ZY,ZX) :: ZEDSTEPL=1 :: RETURN //CHANGE TO APPROPRIATE PATTERN AND LOCATION, RECALL SPRITE AND CHANGE PATTERN RECORD FOR NEXT CHECK _ZPLSW2: CALL SPRITE(#TZEDZ,97,4,ZY,ZX) :: ZEDSTEPL=0 :: RETURN //SAME AS PREVIOUS COMMENT _ZEDMOVE: IF ZDR=1 THEN _MOVER ELSE _MOVEL //ADVANCE THE ZED'S MOVEMENT IN THE APPROPRIATE DIRECTION _MOVER: //MOVE RIGHT ZX=ZX+ZS :: IF ZX>=250 THEN _JMPZED1 ELSE _ZEDZCONT //WRAP AROUND FROM RIGHT TO LEFT IF EDGE OF LEVEL REACHED. _JMPZED1: //RESET XP POSTION TO COMPLETE WRAP AROUND ZX=2 :: GOTO _ZEDZCONT //CONTINUE ZED ADVANCEMENT _MOVEL: //MOVE LEFT ZX=ZX-ZS :: IF ZX<=1 THEN _JMPZED2 ELSE _ZEDZCONT //WRAP AROUND FROM LEFT TO RIGHT IF EDGE OF LEVEL REACHED. _JMPZED2: ZX=249 //RESET XP POSTION TO COMPLETE WRAP AROUND _ZEDZCONT: //CONTINUE ZED ADVANCEMENT CALL LOCATE(#TZEDZ,ZY,ZX) CALL CHARPAT(97,ZPL1$) :: CALL CHARPAT(98,ZPL2$) //ZP=ZOMBIE PATTERN CALL CHARPAT(99,ZPR1$) :: CALL CHARPAT(100,ZPR2$) _NEXTZED: NEXT ZCK RETURN _ZCD: //ZOMBI COLLISION DETECTION IF ZOMBEZ<=0 THEN _GORET TZEDZ=ZEDZ(1,1) :: ZHOLX=ZEDZ(1,2) :: ZDR=ZEDZ(1,3) :: ZS=ZEDZ(1,4) :: AZED=ZEDZ(1,6) //ZOMBI TO PLAYER COINC FOR ZHCK=1 TO 14 TZEDZ=ZEDZ(ZHCK,1) :: ZHOLX=ZEDZ(ZHCK,2) :: ZDR=ZEDZ(ZHCK,3) :: ZS=ZEDZ(ZHCK,4) :: AZED=ZEDZ(ZHCK,6)//SPRITE NUMBER:ZEDHOL XPOS:DIRECTION:SPEED:ACTIVE? IF AZED=-1 THEN _NXTHCOZ IF AZED=0 or TZEDZ=0 or ZS=0 or ZDR=0 or ZHOLX=0 THEN _ENDZHCZ IF PFALLIN<>0 or JMP=1 THEN _SKIPPLAYR CALL POSITION(#1,YP,XP) :: CALL POSITION(#TZEDZ,ZY,ZX) IF YP<>ZY THEN _SKIPPLAYR CALL COINC(#TZEDZ,#1,8,C) :: IF C<>0 THEN _GSPHIT ELSE _GORESET2 //CHECK FOR ZED COLLISION WITH PLAYER. IF NO COLLISION, RESET THE ATSPEED COUNTER AND CONTINUE. _GSPHIT: //CHECK IF PLAYER DODGES FIRST AND OTHER KEYBOARD INPUTS. //print "0085ZDR:";ZDR :: CALL KEY(1,K,S) :: IF S=0 THEN _GSCZ :: IF K=0 AND S=-1 THEN _QUIT IF K=16 THEN _BOARDPROG //DEVELOPER CHEAT TO TEST _LDS IF K=6 THEN _RESET // :: IF K=3 THEN GOSUB _DEBUGGER IF K=18 OR K=74 OR K=106 THEN _GSAJMP //PLAYER DODGES/JUMPS GOTO _GSCZ _GSAJMP: JMP=1 :: GOSUB _JUMP :: JMP=0 :: GOTO _SKIPPLAYR _GSCZ: //THERE IS A COINC BETWEEN PLAYER AND ZED IF ATDELAY=10 THEN _NOATDELAY ATDELAY=ATDELAY-1 :: IF ATDELAY>=1 THEN _SKIPPLAYR ATDELAY=10 _NOATDELAY: ATDELAY=ATDELAY-1 :: CALL SOUND(100,-4,0,110,0,1000,0) :: HEALTH=HEALTH-1 :: IF HEALTH<=0 THEN _DEAD :: GOSUB _GUI GOTO _SKIPPLAYR // CHECK FOR COINC BETWEEN ZED AND HOLE _GORESET2: ATDELAY=10 //RESET ZOMBIE ATTACK DELAY //ZOMBI TO HEART COINC _SKIPPLAYR: IF ZHOL<>0 THEN _NOCALPOS //THIS IS A PATCH TO CORRECT A GLITCH WHERE ZHOL=0 TZEDZ=ZEDZ(ZHCK,1) :: IF TZEDZ=0 THEN _ENDZHCZ :: CALL POSITION(#TZEDZ,ZY,ZX) _NOCALPOS: IF ZY=33 THEN _ZY33 IF ZY=57 THEN _ZY57 IF ZY=81 THEN _ZY81 IF ZY=105 THEN _ZY105 IF ZY=129 THEN _ZY129 IF ZY=153 THEN _ZY153 IF ZY=177 THEN _ZY177 //PRINT "ZY GLITCH AT ZCD" :: BREAK _ZY33: ZLDET=10 :: ZRDET=11 :: ZHOL=3 :: GOTO _ZCOLDETS _ZY57: ZLDET=12 :: ZRDET=13 :: ZHOL=4 :: GOTO _ZCOLDETS _ZY81: ZLDET=14 :: ZRDET=15 :: ZHOL=5 :: GOTO _ZCOLDETS _ZY105: ZLDET=16 :: ZRDET=17 :: ZHOL=6 :: GOTO _ZCOLDETS _ZY129: ZLDET=18 :: ZRDET=19 :: ZHOL=7 :: GOTO _ZCOLDETS _ZY153: ZLDET=20 :: ZRDET=21 :: ZHOL=8 :: GOTO _ZCOLDETS _ZY177: ZLDET=22 :: ZRDET=23 :: ZHOL=2 :: GOTO _ZCOLDETS _ZCOLDETS: IF HDC=1 THEN _GORET AHART=HART(1,1) :: AHARTY=HART(2,1)// :: AHARTX=HART(3,1) FOR ZHCOINC=1 TO 14 :: IF HARTZ<=0 THEN _ENDHCOZ AHART=HART(1,ZHCOINC) :: AHARTY=HART(2,ZHCOINC)// :: AHARTX=HART(3,ZHCOINC) IF AHART=0 THEN _ENDHCOZ IF AHART=-1 THEN _NXTHCOZ IF AHART<>ZLDET AND AHART<>ZRDET THEN _NXTHCOZ IF ZY<>(AHARTY+1) THEN _NXTHCOZ // SET DEBUGGER HERE********************************************************************************************* CALL COINC(#TZEDZ,#AHART,8,C) :: IF C=0 THEN _NXTHCOZ CALL DELSPRITE(#AHART) :: HART(1,ZHCOINC)=-1 :: HARTZ=HARTZ-1 IF AZED=-1 THEN _NXTHCOZ IF AZED=0 or TZEDZ=0 or ZS=0 or ZDR=0 or ZHOLX=0 THEN _ENDZHCZ _ENDHCOZ: ZHCOINC=14 _NXTHCOZ: NEXT ZHCOINC //ZOMBI TO HOLE COINC _HOLZEDCHKR: HDC=1 :: GOSUB _SKIPPLAYR :: HDC=0 IF ZHOL=2 THEN _NXTZHCZ CALL COINC(#TZEDZ,#ZHOL,6,C) :: IF C=0 THEN _NXTZHCZ _CHDZEDHOL: IF BOARD<=50 AND ZY<YP THEN _GSZFALL ELSE _CZGCC //CHECK FOR FALLING ZED ENABLE ELSE CONTINUE CHECK ZED HOLE COLLISION CHECKS _GSZFALL: GOSUB _ZFALL _CZGCC: IF ZDR=1 THEN _POSH ELSE _NEGH _POSH: ZX=ZX-6 :: CALL PATTERN(#TZEDZ,96) :: ZEDZ(ZHCK,3)=-1 :: ZDR=-1 :: ZX=ZX-ZS :: CALL LOCATE(#TZEDZ,ZY,ZX) :: GOSUB _ZEDPATTERN ZS=INT((RND*ZSS)+1) :: ZEDZ(ZHCK,4)=ZS //SETS RANDOM ZED SPEED IF ZX<=1 THEN _JMPZED3 ELSE _ZEDZCONT1 _JMPZED3: ZX=249 _ZEDZCONT1: GOTO _NXTZHCZ _NEGH: ZX=ZX+6 :: CALL PATTERN(#TZEDZ,96) :: ZEDZ(ZHCK,3)=1 :: ZDR=1 :: ZX=ZX+ZS :: CALL LOCATE(#TZEDZ,ZY,ZX) :: GOSUB _ZEDPATTERN ZS=INT((RND*ZSS)+1) :: ZEDZ(ZHCK,4)=ZS //SETS RANDOM ZED SPEED IF ZX>=250 THEN _JMPZED4 ELSE _NXTZHCZ _JMPZED4: ZX=2 GOTO _NXTZHCZ _ENDZHCZ: //TRAP=14 :: GOSUB _DEBUGGER ZHCK=14 _NXTZHCZ: NEXT ZHCK RETURN _ZFALL: FOR ZFALLIN=12 TO 1 STEP -1 :: ZY=ZY+2 :: CALL SOUND(1,FALLIN*110,5) :: CALL SPRITE(#TZDEZ,96,6,ZY,ZX) :: NEXT ZFALLIN IF ZY=9 THEN _ZFY9 IF ZY=33 THEN _ZFY33 IF ZY=57 THEN _ZFY57 IF ZY=81 THEN _ZFY81 IF ZY=105 THEN _ZFY105 IF ZY=129 THEN _ZFY129 IF ZY=153 THEN _ZFY153 IF ZY=177 THEN _ZFY177 _ZFY9: NZHOL=2 :: GOTO _NEWZHOLE _ZFY33: NZHOL=3 :: GOTO _NEWZHOLE _ZFY57: NZHOL=4 :: GOTO _NEWZHOLE _ZFY81: NZHOL=5 :: GOTO _NEWZHOLE _ZFY105: NZHOL=6 :: GOTO _NEWZHOLE _ZFY129: NZHOL=7 :: GOTO _NEWZHOLE _ZFY153: NZHOL=8 :: GOTO _NEWZHOLE _ZFY177: NZHOL=2 :: GOTO _NEWZHOLE _NEWZHOLE: ZEDZ(ZHCK,2)=NZHOL :: RETURN //_CRAWLERAI: //CHASES AND DESTROYS HEARTS IF ANY, THEN GOES AFTER PLAYER. NEED CZHELTH DEFINED. MOVE CRAWLER LEVEL TO LEVEL LOOKING FOR HEARTS. LEVEL = PLAYER LEVEL THEN AGRO TO PLAYER // RETURN //_CRAWLERSPAWN: //SPAWN ONE CRAWLER AT EACH 50< LEVEL - MAKE IT 2 AT LEVEL 25 AND 3 AT LEVEL 0 !MERGE DSK2.ZOMBITS3-M !100 GOSUB 30000 !1040 GOSUB 30270 !SAVE DSK2.ZOMB50-X !SAVE DSK2.ZOMB50-M,MERGE !LIST "CLIP" !RUN // EDIT ABOVE 3 LINES BEFORE PASTING END //OFFICIAL END OF MAIN PROGRAM *************************************************************************************************************************************** // //CHARECTER CODE RECORDS //104=IDLE CG:2 //136=MAN MELEE ATTACK //137=MAN RANGED LEFT //138=MAN RANGED RIGHT //NUMBER 0-9 = 48-57 = 3,4 //105-110 RR = 6 PATTERNS //120-122 SJR = 3 PAT //123-125 JR = 3 PAT //126-127 LR = 2 PAT //104 = IDLE //113-118 RL = 6 PAT //128-130 SJL = 3 PAT //131-133 JL = 3 PAT //134-135 LL = 2 PAT //32,112,111,119,139-142: BLANK COLOR: N/A COLOR SETS: N/A //33-47:W,G,Z,I,I,+,J,C,K,Q,U,L,F,H COLOR: 12* COLOR SETS: 1, 2 //48-57: NUMBERS 0-9 COLOR: 12* COLOR SETS: 3, 4 //58-74:M,V,A,Y,V,W,X,T,O,Q,G,B,P,R,E,S,N COLOR: 12* COLOR SETS: 4, 5, 6 //75-77: SCORE CHAR COLOR: 12 COLOR SETS: 6 //78-79:LEVEL CHAR. COLOR: 12 COLOR SETS: 6 //80-89:*, ~, MELEE ATTACK, BULLET, :, &, (, ), =, .CLR: 12*6 COLOR SETS: 7, 8 //90:HEART. COLOR: 7 COLOR SETS: 8 //91:MELEE WEAPON. COLOR: 8 COLOR SETS: 8 //92:RANGED WEAPON. COLOR: 8 COLOR SETS: 8 //93:BAD GIRDER. COLOR: 15 COLOR SETS: 8 //94:GIRDER. COLOR: 15* COLOR SETS: 8 //95:THE HOLE. ASSIGNED VARIABLE HCLR COLOR: 15 COLOR SETS: 8 //96:ZOMBIE. COLOR: 4 COLOR SETS: 9 //97-98: ZOMBIE RUN LEFT COLOR: 4 COLOR SETS: 9 //99-100: ZOMBIE RUN RIGHT COLOR: 4 COLOR SETS: 9 //101-102&103:ZOMBIE CRAWLER&ZCRAWLER IDLE COLOR: 13 COLOR SETS: 9 //104:PLAYER IDLE COLOR: 6 COLOR SETS: 10 //105-110:PLAYER RUN RIGHT COLOR: 6 COLOR SETS: 10 //113-118:PLAYER RUN LEFT COLOR: 6 COLOR SETS: 11 //120-127:PLAYER STOP,JUMP,LAND RIGHT COLOR: 6 COLOR SETS: 12 //128-135:PLAYER STOP,JUMP,LAND LEFT COLOR: 6 COLOR SETS: 13 //136: PLAYER MELEE ATTACK COLOR: 6 COLOR SETS: 14 //137-138:PLAYER RANGED ATTACK LEFT AND RIGHT. COLOR: 6 COLOR SETS: 14 //143:THE EXIT. COLOR: 10* COLOR SETS: 14 //*USE CALL COLOR - THE REST ARE SPRITES AND GET ASSIGNED UPON CREATION. And how V0.50 looks after TidBit translation and merged with the title screens.don't attempt to run this, it won't work. The compressed data gets corrupted once copied/pasted. 100 GOSUB 30000 110 SCORE=5 :: HEALTH=5 :: BOARD=99 :: MELEE=5 :: RANGED=5 :: BULL=1 :: MAXHEALTH=10 :: MAXZHELTH=4 120 ZEDPERC=20 :: ZEDSTEPL=0 :: ZEDSETPR=0 :: JDELAY=8 :: MAXMELEE=10 :: MAXRANGED=10 130 ATDELAY=10 :: ZSS=3 140 RANDOMIZE 150 SLOT=10 160 OPTION BASE 1 170 DIM LO0T(2,14) 180 DIM HART(3,14) 190 DIM RANG(1,14) 200 DIM MELE(1,14) 210 DIM ZEDZ(14,6) 220 LTN=1 :: LAB=1 :: SHL=2 :: GRND=17 :: ZHELTH=4 :: YP=9 :: XP=8 :: PD=1 :: PS=2 230 JMP=0 :: ZOMBEZ=0 :: ZDR=1 :: HCLR=1 :: TYMER=BOARD*2 240 RLUT=1 :: MLUT=1 :: HLUT=1 :: HARTZ=0 :: RANGZ=0 :: MELEZ=0 :: PFALLIN=O 250 ZHOL=2 260 CALL COLOR(1,12,1,2,12,1,3,12,1,4,12,1,5,12,1,6,12,1,7,12,1,8,15,1,14,10,1):: CALL CLEAR :: CALL SCREEN(2) 270 GOSUB 830 280 HLE=INT((RND*15)+5):: FOR LVL=1 TO 8 :: IF LVL<>1 THEN 290 ELSE 300 290 GOSUB 440 300 CALL VCHAR(1,1,94,24):: CALL VCHAR(1,32,94,24):: CALL HCHAR(LVL*3,1,94,HLE-1) 310 IF LVL=8 THEN 350 ELSE 320 320 CALL SPRITE(#SHL,95,HCLR,GRND-7,(HLE*+1):: SHL=SHL+1 330 NHLE=INT((GRND+1)/8) 340 CALL HCHAR(NHLE+1,HLE+1,95) 350 LASTHLE=(HLE*+1 :: CALL HCHAR(LVL*3,HLE+3,94,32-(HLE+3)) 360 IF LVL=8 THEN 410 ELSE 370 370 CALL HCHAR(LVL*3,HLE,93):: CALL HCHAR(LVL*3,HLE+2,93):: GRND=GRND+24 380 HOL=INT((RND*15)+5) 390 IF HOL=HLE THEN 380 ELSE 400 400 HLE=HOL 410 NEXT LVL 420 FOR EXTX=1 TO 31 STEP 30 :: FOR EXTY=2 TO 23 STEP 3 :: CALL HCHAR(EXTY,EXTX,143):: NEXT EXTY :: NEXT EXTX 430 CALL HCHAR(24,1,94,31):: GOTO 1130 440 SIDEZ=-40 450 FOR REPT=1 TO 2 460 IF LVL=8 AND ZOMBEZ=0 THEN 550 470 LDSN=INT(RND*100)+(1+ZEDPERC) 480 IF LDSN<BOARD THEN 720 490 LDSN=INT(RND*100)+(1+ZEDPERC) 500 IF LDSN>BOARD THEN 550 510 CALL SPRITE(#SLOT,90,7,GRND-9,((HLE+1)*+SIDEZ):: CALL POSITION(#SLOT,HY,HX):: HART(2,HLUT)=HY :: HART(3,HLUT)=HX 520 HART(1,HLUT)=SLOT :: SLOT=SLOT+1 :: HLUT=HLUT+1 :: HARTZ=HARTZ+1 530 LO0T(LAB,LTN)=90 :: LAB=LAB+1 :: LO0T(LAB,LTN)=SLOT-1 :: LAB=1 :: LTN=LTN+1 540 GOTO 800 550 IF BOARD>=51 THEN 560 560 CALL SPRITE(#SLOT,96,4,GRND-8,((HLE+1)*+SIDEZ) 570 ZHELTH=MAXZHELTH 580 ZOMBEZ=ZOMBEZ+1 590 ZEDZ(ZOMBEZ,1)=SLOT 600 ZHOLX=((HLE+1)* 610 ZEDZ(ZOMBEZ,2)=ZHOLX 620 ZEDZ(ZOMBEZ,3)=ZDR 630 ZS=INT((RND*ZSS)+1) 640 ZEDZ(ZOMBEZ,4)=ZS 650 ZEDZ(ZOMBEZ,5)=ZHELTH 660 ZEDZ(ZOMBEZ,6)=1 670 SLOT=SLOT+1 680 LO0T(LAB,LTN)=96 :: LAB=LAB+1 :: LO0T(LAB,LTN)=SLOT-1 :: LAB=1 :: LTN=LTN+1 690 IF BOARD>33 THEN 800 700 GOSUB 820 710 GOTO 800 720 LDSN=INT(RND*100)+1 730 LDSN=LDSN+ZEDPERC 740 IF LDSN<BOARD THEN 780 750 MELE(1,MLUT)=SLOT :: MLUT=MLUT+1 :: MELEZ=MELEZ+1 760 CALL SPRITE(#SLOT,91,8,GRND-9,((HLE+1)*+SIDEZ):: SLOT=SLOT+1 :: LO0T(LAB,LTN)=91 :: LAB=LAB+1 :: LO0T(LAB,LTN)=SLOT-1 :: LAB=1 :: LTN=LTN+1 770 GOTO 800 780 RANG(1,RLUT)=SLOT :: RLUT=RLUT+1 :: RANGZ=RANGZ+1 790 CALL SPRITE(#SLOT,92,14,GRND-9,((HLE+1)*+SIDEZ):: SLOT=SLOT+1 :: LO0T(LAB,LTN)=92 :: LAB=LAB+1 :: LO0T(LAB,LTN)=SLOT-1 :: LAB=1 :: LTN=LTN+1 800 SIDEZ=40 :: NEXT REPT 810 RETURN 820 RETURN 830 DISPLAY AT(1,3):SCORE :: DISPLAY AT(1,10):BOARD :: DISPLAY AT(1,15):HEALTH :: DISPLAY AT(1,21):MELEE :: DISPLAY AT(1,26):RANGED 840 CALL VCHAR(1,3,75):: CALL VCHAR(1,4,76):: CALL VCHAR(1,5,77):: CALL VCHAR(1,12,79):: CALL VCHAR(1,17,64):: CALL VCHAR(1,23,64) 850 CALL VCHAR(1,28,64):: CALL VCHAR(1,11,78):: CALL VCHAR(1,16,90):: CALL VCHAR(1,22,91):: CALL VCHAR(1,27,92):: RETURN 860 IF BOARD<=20 THEN 900 870 IF BOARD<=75 THEN 910 880 IF BOARD<=50 THEN 920 890 IF BOARD<=25 THEN 930 ELSE 940 900 ZEDPERC=0 :: GOTO 870 910 MAXHEALTH=20 :: GOTO 880 920 MAXRANGED=20 :: MAXZHELTH=6 :: GOTO 890 930 MAXMELEE=20 940 CALL DELSPRITE(ALL):: BOARD=BOARD-1 :: IF SCORE>HSCORE THEN 950 ELSE 960 950 HSCORE=SCORE 960 CALL SCREEN(2):: FOR CCLOR=0 TO 14 :: CALL COLOR(CCLOR,16,1):: NEXT CCLOR :: HCLR=2 :: CALL CLEAR 970 CALL VCHAR(11,12,47):: CALL VCHAR(11,13,36):: CALL VCHAR(11,14,34):: CALL VCHAR(11,15,47) 980 CALL VCHAR(11,16,73):: CALL VCHAR(11,17,40):: CALL VCHAR(11,18,66):: CALL VCHAR(11,19,71) 990 CALL VCHAR(11,20,72):: DISPLAY AT(12,13):HSCORE 1000 CALL LINK("DELAY",200) 1010 CALL KEY(1,K,S):: IF S=0 THEN 1010 1020 GOTO 140 1030 CALL SCREEN(10):: CALL CLEAR :: CALL DELSPRITE(ALL) 1040 GOSUB 30270 1050 FOR CCLOR=0 TO 14 :: CALL COLOR(CCLOR,16,10):: NEXT CCLOR 1060 DISPLAY AT(7,13):HSCORE :: DISPLAY AT(21,13):SCORE 1070 CALL SCREEN(2):: CALL LINK("DELAY",200) 1080 CALL KEY(1,K,S):: CALL JOYST(1,X,Y):: IF K<>-1 OR S<>0 OR X<>0 OR Y<>0 THEN 1100 1090 GOTO 1080 1100 CALL DELSPRITE(ALL):: GOTO 110 1110 CALL DELSPRITE(ALL):: GOTO 100 1120 CALL CLEAR :: END :: RETURN 1130 CALL SPRITE(#1,104,6,YP,XP) 1140 GOSUB 3080 :: GOSUB 3540 :: GOSUB 3860 1150 CALL JOYST(1,JX,JY):: CALL KEY(1,K,S):: IF K=0 AND S=-1 THEN 1120 1160 IF K=16 THEN 860 1170 IF K=6 THEN 1110 1180 IF K=18 OR K=74 OR K=106 THEN 1200 1190 IF JX<>0 OR JY<>0 THEN 1210 ELSE 1130 1200 JMP=1 :: GOSUB 1930 :: JMP=0 :: GOTO 1210 1210 IF JY=0 THEN 1230 ELSE 1220 1220 GOSUB 2250 1230 CALL KEY(1,K,S):: IF K=16 THEN 860 1240 IF K=18 OR K=74 OR K=106 THEN 1250 ELSE 1260 1250 JMP=1 :: GOSUB 1930 :: JMP=0 1260 IF JX<>0 THEN 1300 1270 IF JY<>0 THEN 1280 ELSE 1290 1280 GOSUB 2250 1290 GOTO 1130 1300 IF JX=-4 THEN 1310 ELSE 1320 1310 GOSUB 1660 1320 IF JX=4 THEN 1330 ELSE 1130 1330 GOSUB 1410 1340 CALL KEY(1,K,S):: IF K=16 THEN 860 1350 IF K=18 OR K=74 OR K=106 THEN 1360 ELSE 1370 1360 JMP=1 :: GOSUB 1930 :: JMP=0 1370 IF JX<>0 THEN 1300 1380 IF JY<>0 THEN 1390 ELSE 1400 1390 GOSUB 2250 1400 GOTO 1130 1410 IF XP>=250 THEN 1420 ELSE 1430 1420 XP=2 1430 PD=1 :: CALL SPRITE(#1,105,6,YP,XP) 1440 FOR PATR=105 TO 110 :: CALL PATTERN(#1,PATR):: CALL SOUND(1,-2,20):: XP=XP+PS 1450 IF XP>=250 THEN 1460 ELSE 1470 1460 XP=2 1470 CALL LOCATE(#1,YP,XP):: CALL KEY(1,K,S) 1480 IF K=18 THEN 1510 1490 IF K=74 THEN 1510 1500 IF K=106 THEN 1510 ELSE 1520 1510 JMP=1 :: PATR=110 :: GOTO 1580 1520 CALL JOYST(1,JX,JY):: IF JY=0 THEN 1540 ELSE 1530 1530 GOSUB 2250 1540 IF JX<>0 THEN 1560 1550 CALL SPRITE(#1,104,6,YP,XP):: RETURN 1560 IF JX=4 THEN 1580 1570 IF JX=-4 THEN 3530 ELSE 1580 1580 CALL COINC(ALL,C):: IF C=0 THEN 1600 1590 GOSUB 3080 1600 IF ZOMBEZ=0 THEN 1620 1610 GOSUB 3540 :: GOSUB 3860 1620 NEXT PATR 1630 IF JMP=1 THEN 1640 ELSE 1650 1640 GOSUB 1930 :: JMP=0 1650 IF JX=4 THEN 1410 ELSE 3530 1660 IF XP<=1 THEN 1670 ELSE 1680 1670 XP=249 1680 PD=-1 :: CALL SPRITE(#1,113,6,YP,XP) 1690 FOR PATL=113 TO 118 :: CALL PATTERN(#1,PATL):: CALL SOUND(1,-2,20):: XP=XP-PS 1700 IF XP<=1 THEN 1710 ELSE 1720 1710 XP=249 1720 CALL LOCATE(#1,YP,XP):: CALL KEY(1,K,S) 1730 IF K=18 THEN 1760 1740 IF K=74 THEN 1760 1750 IF K=106 THEN 1760 ELSE 1770 1760 JMP=1 :: PATL=118 :: GOTO 1830 1770 CALL JOYST(1,JX,JY):: IF JY=0 THEN 1790 ELSE 1780 1780 GOSUB 2250 1790 IF JX<>0 THEN 1810 1800 CALL SPRITE(#1,44,6,YP,XP):: RETURN 1810 IF JX=-4 THEN 1830 1820 IF JX=4 THEN 3530 ELSE 1830 1830 CALL COINC(ALL,C):: IF C=0 THEN 1850 1840 GOSUB 3080 1850 IF ZOMBEZ=0 THEN 1870 1860 GOSUB 3540 :: GOSUB 3860 1870 NEXT PATL 1880 IF JMP=1 THEN 1890 ELSE 1920 1890 GOSUB 1930 :: JMP=0 :: GOSUB 3080 1900 IF ZOMBEZ=0 THEN 1920 1910 GOSUB 3540 :: GOSUB 3860 1920 IF JX=-4 THEN 1660 ELSE 3530 1930 JMP=0 1940 IF PD<>-1 THEN 1970 1950 S1=128 :: J1=131 :: L1=134 :: JSND=18 :: S2=130 :: J2=133 :: L2=135 :: JMPDIS=-1 1960 GOTO 1990 1970 IF PD<>1 THEN 3530 1980 S1=120 :: J1=123 :: L1=126 :: JSND=10 :: S2=122 :: J2=125 :: L2=127 :: JMPDIS=1 1990 CALL LOCATE(#1,YP,XP) 2000 FOR PTS=S1 TO S2 :: CALL SOUND(1,(PTS-JSND),5):: CALL PATTERN(#1,PTS):: NEXT PTS 2010 FOR UDELAY=1 TO JDELAY :: IF ZOMBEZ=0 THEN 2030 2020 GOSUB 3540 :: GOSUB 3860 2030 NEXT UDELAY 2040 YP=YP-3 :: CALL LOCATE(#1,YP,XP) 2050 JMP=1 2060 FOR PTJ=J1 TO J2 2070 FOR PTJP=1 TO 7 2080 XP=XP+JMPDIS 2090 IF XP<=1 THEN 2100 ELSE 2110 2100 XP=248 :: GOTO 2130 2110 IF XP>=249 THEN 2120 ELSE 2130 2120 XP=2 2130 CALL PATTERN(#1,PTJ):: CALL SOUND(1,(PTJ-JSND),5):: CALL LOCATE(#1,YP,XP) 2140 NEXT PTJP 2150 NEXT PTJ 2160 YP=YP+3 :: CALL LOCATE(#1,YP,XP) 2170 FOR PTL=L1 TO L2 2180 IF PTL=L1 THEN 2210 2190 IF ZOMBEZ=0 THEN 2210 2200 GOSUB 3540 :: GOSUB 3860 2210 CALL PATTERN(#1,PTL):: CALL SOUND(1,(PTL-JSND),5):: NEXT PTL 2220 CALL COINC(ALL,C):: IF C<>0 THEN 2230 ELSE 2240 2230 RETURN 2240 ATDELAY=10 :: RETURN 2250 IF JY=4 AND MELEE>=1 THEN 2290 :: IF JY=4 AND MELEE<=0 THEN 2280 2260 IF JY=-4 THEN 2270 ELSE 3530 2270 GOSUB 2700 :: RETURN 2280 CALL SOUND(100,-3,0):: RETURN 2290 MELEE=MELEE-1 :: GOSUB 830 2300 GOSUB 2340 :: RETURN 2310 IF JY=-4 THEN 2330 ELSE 2320 2320 CALL SOUND(100,-6,0):: RETURN 2330 GOSUB 2700 :: RETURN 2340 CALL PATTERN(#1,136) 2350 IF XP+8>=250 THEN 2370 2360 CALL SPRITE(#24,82,12,YP,XP+:: GOTO 2380 2370 CALL SPRITE(#24,82,12,YP,XP) 2380 CALL SOUND(125,-5,0) 2390 GOSUB 2480 2400 IF XP+8>=250 THEN 2430 2410 CALL DELSPRITE(#24):: IF XP-8<=1 THEN 2430 2420 CALL SPRITE(#25,82,12,YP,XP-:: GOTO 2440 2430 CALL SPRITE(#25,82,12,YP,XP) 2440 CALL SOUND(125,-6,0) 2450 GOSUB 2500 2460 CALL DELSPRITE(#25):: CALL PATTERN(#1,136) 2470 RETURN 2480 FOR DET=10 TO 23 :: CALL COINC(#24,#DET,7,C):: IF C<>0 THEN 2520 2490 NEXT DET :: RETURN 2500 FOR DET=10 TO 23 :: CALL COINC(#25,#DET,7,C):: IF C<>0 THEN 2520 2510 NEXT DET :: RETURN 2520 TLOOP1=DET-9 2530 IF LO0T(1,TLOOP1)<>96 THEN 2630 2540 CALL COLOR(#DET,7):: LSPRN=LO0T(2,TLOOP1) 2550 FOR ZCHEK=1 TO 14 2560 ZPRN=ZEDZ(ZCHEK,1) 2570 IF LSPRN<>ZPRN THEN 2610 2580 ZHELTH=ZEDZ(ZCHEK,5):: ZHELTH=ZHELTH-1 :: ZEDZ(ZCHEK,5)=ZHELTH 2590 IF ZHELTH>=1 THEN 3530 2600 SCORE=SCORE+15 :: ZEDZ(ZCHEK,6)=-1 :: CALL DELSPRITE(#LSPRN):: ZOMBEZ=ZOMBEZ-1 :: RETURN 2610 NEXT ZCHEK 2620 RETURN 2630 IF LO0T(1,TLOOP1)<>90 THEN 2640 ELSE 2660 2640 IF LO0T(1,TLOOP1)<>91 THEN 2650 ELSE 2660 2650 IF LO0T(1,TLOOP1)<>92 THEN 3530 2660 FOR LCHEK=1 TO 14 :: IF DET=LO0T(LCHEK,2)THEN 2670 ELSE 2680 2670 LCHEK=14 2680 NEXT LCHEK :: CALL DELSPRITE(#DET) 2690 RETURN 2700 IF RANGED<=0 THEN 2710 ELSE 2720 2710 CALL SOUND(100,-3,0):: RETURN 2720 RANGED=RANGED-1 :: CALL SOUND(100,-6,0):: GOSUB 830 2730 YB=YP 2740 IF PD<>1 THEN 2790 2750 CALL PATTERN(#1,138) 2760 BULL=1 2770 XB=XP+32 2780 GOTO 2830 2790 IF PD<>-1 THEN 3530 2800 CALL PATTERN(#1,137) 2810 BULL=-1 2820 XB=XP-32 2830 CALL SPRITE(#26,83,6,YB,XB) 2840 FOR BHCK=2 TO 8 2850 CALL COINC(#26,#BHCK,8,C):: IF C=0 THEN 2870 2860 XB=XB+BULL :: CALL LOCATE(#26,YB,XB):: IF XB<=2 OR XB>=249 THEN 3050 ELSE 2850 2870 NEXT BHCK 2880 CALL COINC(ALL,C):: IF C<>0 THEN 2900 2890 XB=XB+BULL :: IF XB<=2 OR XB>=249 THEN 3050 ELSE 2830 2900 CALL LOCATE(#26,YB,XB):: FOR LCHECK=1 TO 14 :: LSPRN=LO0T(2,LCHECK):: LCHKB=LO0T(1,LCHECK) 2910 IF LSPRN<=9 OR LSPRN>=24 THEN 2920 ELSE 2930 2920 XB=XB+BULL :: CALL LOCATE(#26,YB,XB):: CALL COINC(#26,#LSPRN,8,C):: IF C<>0 THEN 2910 2930 CALL COINC(#26,#LSPRN,8,C) 2940 IF C=0 THEN 3040 2950 IF LCHKB=96 THEN 2960 ELSE 3020 2960 CALL COLOR(#LSPRN,7) 2970 FOR ZCHEK=1 TO 14 :: AZED=ZEDZ(ZCHEK,6):: IF AZED=-1 THEN 3030 2980 ZPRN=ZEDZ(ZCHEK,1):: IF LSPRN<>ZPRN THEN 3030 2990 ZHELTH=ZEDZ(ZCHEK,5):: ZHELTH=ZHELTH-2 :: ZEDZ(ZCHEK,5)=ZHELTH 3000 IF ZHELTH>=1 THEN 3050 3010 SCORE=SCORE+15 :: ZEDZ(ZCHEK,6)=-1 :: CALL DELSPRITE(#LSPRN):: ZOMBEZ=ZOMBEZ-1 :: GOTO 3050 3020 CALL COLOR(#LSPRN,7):: CALL DELSPRITE(#LSPRN):: LO0T(2,LCHECK)=1 :: GOTO 3050 3030 NEXT ZCHEK :: GOTO 3050 3040 NEXT LCHECK :: GOTO 2890 3050 CALL DELSPRITE(#26):: GOSUB 830 :: CALL JOYST(1,JX,JY):: IF JY=0 THEN 3530 3060 IF JY-4 THEN 3070 ELSE 3530 3070 GOSUB 2700 :: RETURN 3080 IF JMP=1 THEN 3530 3090 IF HARTZ<=0 THEN 3220 3100 FOR HCOINC=1 TO 14 3110 AHART=HART(1,HCOINC) 3120 IF AHART=-1 THEN 3210 3130 IF AHART=0 THEN 3200 3140 CALL COINC(#1,#AHART,8,C) 3150 IF C=0 THEN 3210 3160 SCORE=SCORE+10 :: CALL SOUND(1,500,5):: CALL SOUND(1,600,2) 3170 IF HEALTH<MAXHEALTH THEN 3180 ELSE 3190 3180 HEALTH=HEALTH+1 3190 GOSUB 830 :: CALL DELSPRITE(#AHART):: HART(1,HCOINC)=-1 :: HARTZ=HARTZ-1 :: GOTO 3210 3200 HCOINC=14 3210 NEXT HCOINC 3220 IF MELEZ=0 THEN 3340 3230 FOR MCOINC=1 TO 14 3240 AMELE=MELE(1,MCOINC) 3250 IF AMELE=-1 THEN 3330 3260 IF AMELE=0 THEN 3320 3270 CALL COINC(#1,#AMELE,8,C) 3280 IF C=0 THEN 3330 3290 SCORE=SCORE+3 :: IF MELEE<MAXMELEE THEN 3300 ELSE 3310 3300 MELEE=MELEE+1 3310 CALL SOUND(1,1500,5):: CALL SOUND(1,1600,2):: GOSUB 830 :: CALL DELSPRITE(#AMELE):: MELE(1,MCOINC)=-1 :: MELEZ=MELEZ-1 3320 MCOINC=14 3330 NEXT MCOINC 3340 IF RANGZ=0 THEN 3460 3350 FOR RCOINC=1 TO 14 3360 ARANG=RANG(1,RCOINC) 3370 IF ARANG=-1 THEN 3450 3380 IF ARANG=0 THEN 3440 3390 CALL COINC(#1,#ARANG,8,C) 3400 IF C=0 THEN 3450 3410 SCORE=SCORE+5 :: IF RANGED<MAXRANGED THEN 3420 ELSE 3430 3420 RANGED=RANGED+1 3430 CALL SOUND(1,1000,5):: CALL SOUND(1,1200,2):: GOSUB 830 :: CALL DELSPRITE(#ARANG):: RANG(1,RCOINC)=-1 :: RANGZ=RANGZ-1 3440 RCOINC=14 3450 NEXT RCOINC 3460 FOR HOLDET=2 TO 8 3470 CALL COINC(#1,#HOLDET,10,C) 3480 IF C=0 THEN 3500 3490 FOR FALLIN=12 TO 1 STEP -1 :: YP=YP+2 :: CALL SOUND(1,FALLIN*110,5):: CALL SPRITE(#1,104,6,YP,XP):: PFALLIN=1 :: GOSUB 3540 :: NEXT FALLIN :: PFALLIN=0 3500 NEXT HOLDET 3510 CALL POSITION(#1,YP,XP):: IF YP=177 AND XP>=235 THEN 860 3520 IF YP=177 AND XP<=8 THEN 860 3530 RETURN 3540 IF ZOMBEZ=0 THEN 3530 3550 TZEDZ=ZEDZ(1,1):: ZHOLX=ZEDZ(1,2):: ZDR=ZEDZ(1,3):: ZS=ZEDZ(1,4):: AZED=ZEDZ(1,6) 3560 FOR ZCK=1 TO 14 3570 TZEDZ=ZEDZ(ZCK,1):: ZHOLX=ZEDZ(ZCK,2):: ZDR=ZEDZ(ZCK,3):: ZS=ZEDZ(ZCK,4):: AZED=ZEDZ(ZCK,6) 3580 IF AZED=-1 THEN 3840 3590 IF TZEDZ=0 THEN 3600 ELSE 3610 3600 ZCK=14 :: GOTO 3840 3610 CALL POSITION(#TZEDZ,ZY,ZX) 3620 CALL POSITION(#1,YP,XP) 3630 IF BOARD>66 THEN 3680 3640 IF YP<>ZY AND BOARD>33 THEN 3680 3650 IF ZX<XP THEN 3670 3660 ZDR=-1 :: ZEDZ(ZCK,3)=-1 :: GOTO 3680 3670 ZDR=1 :: ZEDZ(ZCK,3)=1 3680 GOSUB 3690 :: GOTO 3760 3690 IF ZDR=1 THEN 3700 ELSE 3730 3700 IF ZEDSTEPR=0 THEN 3710 ELSE 3720 3710 CALL SPRITE(#TZEDZ,100,4,ZY,ZX):: ZEDSTEPR=1 :: RETURN 3720 CALL SPRITE(#TZEDZ,99,4,ZY,ZX):: ZEDSTEPR=0 :: RETURN 3730 IF ZEDSTEPL=0 THEN 3740 ELSE 3750 3740 CALL SPRITE(#TZEDZ,98,4,ZY,ZX):: ZEDSTEPL=1 :: RETURN 3750 CALL SPRITE(#TZEDZ,97,4,ZY,ZX):: ZEDSTEPL=0 :: RETURN 3760 IF ZDR=1 THEN 3770 ELSE 3790 3770 ZX=ZX+ZS :: IF ZX>=250 THEN 3780 ELSE 3810 3780 ZX=2 :: GOTO 3810 3790 ZX=ZX-ZS :: IF ZX<=1 THEN 3800 ELSE 3810 3800 ZX=249 3810 CALL LOCATE(#TZEDZ,ZY,ZX) 3820 CALL CHARPAT(97,ZPL1$):: CALL CHARPAT(98,ZPL2$) 3830 CALL CHARPAT(99,ZPR1$):: CALL CHARPAT(100,ZPR2$) 3840 NEXT ZCK 3850 RETURN 3860 IF ZOMBEZ<=0 THEN 3530 3870 TZEDZ=ZEDZ(1,1):: ZHOLX=ZEDZ(1,2):: ZDR=ZEDZ(1,3):: ZS=ZEDZ(1,4):: AZED=ZEDZ(1,6) 3880 FOR ZHCK=1 TO 14 3890 TZEDZ=ZEDZ(ZHCK,1):: ZHOLX=ZEDZ(ZHCK,2):: ZDR=ZEDZ(ZHCK,3):: ZS=ZEDZ(ZHCK,4):: AZED=ZEDZ(ZHCK,6) 3900 IF AZED=-1 THEN 4370 3910 IF AZED=0 OR TZEDZ=0 OR ZS=0 OR ZDR=0 OR ZHOLX=0 THEN 4540 3920 IF PFALLIN<>0 OR JMP=1 THEN 4080 3930 CALL POSITION(#1,YP,XP):: CALL POSITION(#TZEDZ,ZY,ZX) 3940 IF YP<>ZY THEN 4080 3950 CALL COINC(#TZEDZ,#1,8,C):: IF C<>0 THEN 3960 ELSE 4070 3960 CALL KEY(1,K,S):: IF S=0 THEN 4020 :: IF K=0 AND S=-1 THEN 1120 3970 IF K=16 THEN 860 3980 IF K=6 THEN 1110 3990 IF K=18 OR K=74 OR K=106 THEN 4010 4000 GOTO 4020 4010 JMP=1 :: GOSUB 1930 :: JMP=0 :: GOTO 4080 4020 IF ATDELAY=10 THEN 4050 4030 ATDELAY=ATDELAY-1 :: IF ATDELAY>=1 THEN 4080 4040 ATDELAY=10 4050 ATDELAY=ATDELAY-1 :: CALL SOUND(100,-4,0,110,0,1000,0):: HEALTH=HEALTH-1 :: IF HEALTH<=0 THEN 1030 :: GOSUB 830 4060 GOTO 4080 4070 ATDELAY=10 4080 IF ZHOL<>0 THEN 4100 4090 TZEDZ=ZEDZ(ZHCK,1):: IF TZEDZ=0 THEN 4540 :: CALL POSITION(#TZEDZ,ZY,ZX) 4100 IF ZY=33 THEN 4170 4110 IF ZY=57 THEN 4180 4120 IF ZY=81 THEN 4190 4130 IF ZY=105 THEN 4200 4140 IF ZY=129 THEN 4210 4150 IF ZY=153 THEN 4220 4160 IF ZY=177 THEN 4230 4170 ZLDET=10 :: ZRDET=11 :: ZHOL=3 :: GOTO 4240 4180 ZLDET=12 :: ZRDET=13 :: ZHOL=4 :: GOTO 4240 4190 ZLDET=14 :: ZRDET=15 :: ZHOL=5 :: GOTO 4240 4200 ZLDET=16 :: ZRDET=17 :: ZHOL=6 :: GOTO 4240 4210 ZLDET=18 :: ZRDET=19 :: ZHOL=7 :: GOTO 4240 4220 ZLDET=20 :: ZRDET=21 :: ZHOL=8 :: GOTO 4240 4230 ZLDET=22 :: ZRDET=23 :: ZHOL=2 :: GOTO 4240 4240 IF HDC=1 THEN 3530 4250 AHART=HART(1,1):: AHARTY=HART(2,1) 4260 FOR ZHCOINC=1 TO 14 :: IF HARTZ<=0 THEN 4360 4270 AHART=HART(1,ZHCOINC):: AHARTY=HART(2,ZHCOINC) 4280 IF AHART=0 THEN 4360 4290 IF AHART=-1 THEN 4370 4300 IF AHART<>ZLDET AND AHART<>ZRDET THEN 4370 4310 IF ZY<>(AHARTY+1)THEN 4370 4320 CALL COINC(#TZEDZ,#AHART,8,C):: IF C=0 THEN 4370 4330 CALL DELSPRITE(#AHART):: HART(1,ZHCOINC)=-1 :: HARTZ=HARTZ-1 4340 IF AZED=-1 THEN 4370 4350 IF AZED=0 OR TZEDZ=0 OR ZS=0 OR ZDR=0 OR ZHOLX=0 THEN 4540 4360 ZHCOINC=14 4370 NEXT ZHCOINC 4380 HDC=1 :: GOSUB 4080 :: HDC=0 4390 IF ZHOL=2 THEN 4550 4400 CALL COINC(#TZEDZ,#ZHOL,6,C):: IF C=0 THEN 4550 4410 IF BOARD<=50 AND ZY<YP THEN 4420 ELSE 4430 4420 GOSUB 4570 4430 IF ZDR=1 THEN 4440 ELSE 4490 4440 ZX=ZX-6 :: CALL PATTERN(#TZEDZ,96):: ZEDZ(ZHCK,3)=-1 :: ZDR=-1 :: ZX=ZX-ZS :: CALL LOCATE(#TZEDZ,ZY,ZX):: GOSUB 3690 4450 ZS=INT((RND*ZSS)+1):: ZEDZ(ZHCK,4)=ZS 4460 IF ZX<=1 THEN 4470 ELSE 4480 4470 ZX=249 4480 GOTO 4550 4490 ZX=ZX+6 :: CALL PATTERN(#TZEDZ,96):: ZEDZ(ZHCK,3)=1 :: ZDR=1 :: ZX=ZX+ZS :: CALL LOCATE(#TZEDZ,ZY,ZX):: GOSUB 3690 4500 ZS=INT((RND*ZSS)+1):: ZEDZ(ZHCK,4)=ZS 4510 IF ZX>=250 THEN 4520 ELSE 4550 4520 ZX=2 4530 GOTO 4550 4540 ZHCK=14 4550 NEXT ZHCK 4560 RETURN 4570 FOR ZFALLIN=12 TO 1 STEP -1 :: ZY=ZY+2 :: CALL SOUND(1,FALLIN*110,5):: CALL SPRITE(#TZDEZ,96,6,ZY,ZX):: NEXT ZFALLIN 4580 IF ZY=9 THEN 4660 4590 IF ZY=33 THEN 4670 4600 IF ZY=57 THEN 4680 4610 IF ZY=81 THEN 4690 4620 IF ZY=105 THEN 4700 4630 IF ZY=129 THEN 4710 4640 IF ZY=153 THEN 4720 4650 IF ZY=177 THEN 4730 4660 NZHOL=2 :: GOTO 4740 4670 NZHOL=3 :: GOTO 4740 4680 NZHOL=4 :: GOTO 4740 4690 NZHOL=5 :: GOTO 4740 4700 NZHOL=6 :: GOTO 4740 4710 NZHOL=7 :: GOTO 4740 4720 NZHOL=8 :: GOTO 4740 4730 NZHOL=2 :: GOTO 4740 4740 ZEDZ(ZHCK,2)=NZHOL :: RETURN 30000 CALL CLEAR :: CALL SCREEN(13) 30010 RESTORE 30360 !// SPRITESHEETS 30020 READ A$ 30030 IF A$="" THEN 30060 30040 CALL LINK("CWRITE",A$) 30050 GOTO 30020 30060 RESTORE 30450 !//TITLE SCREEN 30070 READ B$ 30080 IF B$="" THEN 30110 30090 CALL LINK("CWRITE",B$) 30100 GOTO 30070 30110 CALL CHAR(93,"D58027A282F72A21FFAAFFAAAAFFAAFFD25B810180000000"):: CALL LINK("DELAY",200) 30120 CALL KEY(0,K,S):: CALL JOYST(1,X,Y) 30130 IF K=-1 AND S=0 AND X=0 AND Y=0 THEN 30120 30140 CALL SCREEN(3) 30150 RESTORE 30560 !//INSTRUCTION SCREEN 30160 READ C$ 30170 IF C$="" THEN 30200 30180 CALL LINK("CWRITE",C$) 30190 GOTO 30160 30200 CALL CHAR(93,"D58027A282F72A21FFAAFFAAAAFFAAFFD25B810180000000"):: CALL LINK("DELAY",200) 30210 CALL KEY(0,K,S):: CALL JOYST(1,X,Y) 30220 IF K=-1 AND S=0 AND X=0 AND Y=0 THEN 30210 30260 RETURN 30270 RESTORE 30700 !//YOU ARE DEAD SCREEN 30280 READ D$ 30290 IF D$="" THEN 30320 30300 CALL CHAR(93,"D58027A282F72A21FFAAFFAAAAFFAAFFD25B810180000000"):: CALL LINK("CWRITE",D$) 30310 GOTO 30280 30320 CALL LINK("DELAY",200) 30330 CALL KEY(0,K,S):: CALL JOYST(1,X,Y) 30340 IF K=-1 AND S=0 AND X=0 AND Y=0 THEN 30330 30350 RETURN 30360 DATA " 30370 DATA " 30380 DATA " 30390 DATA "² @xDD8 30400 DATA "S dTLLDp€€cƒã„ 30410 DATA "ýƒ 30420 DATA "š<zX̘~8N‚ 30430 DATA "9 <<ÿ~<<üL<(l00 ?2<6 30440 DATA "" 30450 DATA " 30460 DATA " 30470 DATA " ²†€¦§¨©©€¨ª¡¨§€¡¢€¥¨¤„ª®€‡¢©¡„ˆ‰€§¨£‹„§¨Œ¯€¨Ž¡€µ€§„‚¡€š¢›¨ª€‹¦€¸€š¨¨¨€°€Œ¢ª€¸€§œª¤¨Œ¨€¥‹¡¡¢ª€¡¢€‡‹š¦€µ€Œ¢Œ‚¨¥€" 30480 DATA " 30490 DATA " 30500 DATA "² @xDD8 30510 DATA "S dTLLDp€€cƒã„ 30520 DATA "ýƒ 30530 DATA "š<zX̘~8N‚ 30540 DATA "9 <<ÿ~<<üL<(l00 ?2<6 30550 DATA "" 30560 DATA " 30570 DATA ">¤€¼ƒ¹ †‘€§œª¤¨Œ‡¹•€¦¢„ª¡©¤€»ƒ¹†‘€š¨¨¨ˆ¹“€¦¢„ª¡©¤€š¨¨¨€Œ„©¡œªˆ¨€¸€‘€©¦œˆ¨€²è²„€§œª¤¨Œ€Œ„©¡œªˆ¨©€¸€•†€©¦œˆ¨©¢€‹³„€éê„€‹³¢€ €¸€Š‹„¡‰€§€¸€§¨©¡œ§¡©€" 30580 DATA "Ǧ§¨©©€¨ª¡¨§€¡¢€¦œ¦€" 30590 DATA " 30600 DATA "" 30610 DATA " 30620 DATA " 30630 DATA " 30640 DATA "° 30650 DATA "QDddTLLDp€€cƒã„ 30660 DATA "ü€ƒ 30670 DATA "˜X<zX̘~8N‚ 30680 DATA "7! 30690 DATA "" 30700 DATA " 30710 DATA " 30720 DATA " 30730 DATA "° 30740 DATA "QDddTLLDp€€cƒã„ 30750 DATA "ü€ƒ 30760 DATA "˜X<zX̘~8N‚ 30770 DATA "7! 30780 DATA "" In case you felt like having a look/see. Edited December 13, 2016 by Sinphaltimus Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted December 13, 2016 Share Posted December 13, 2016 Much better. Zombies sometimes get stuck over a hole (going back and forth). 1 zombie down to level 94. 3 zombies at level 93 through 88, and everything runs slow (feels like an uncompiled XB game - sorry). Especially the jump starts out with a long freeze frame (like he's taking time on the loo), and that's a problem when I try to avoid contact with the zombies (in which case I sometimes loose health). Zombies often disappear upon contact without me loosing health (mostly walking as in not standing still). Generally I did not concentrate on picking up anything. I stopped going further at level 86 (3 zombies again after level 87 with 2 zombies). Quote Link to comment Share on other sites More sharing options...
