Serguei2 Posted August 17, 2016 Share Posted August 17, 2016 #include <coleco.h> #include <getput1.h> const byte gtsSPRITES[] = { 0x87, 0x00, 0x01, 0x07, 0x01, 0x85, 0x00, 0x0F, 0x0C, 0x1E, 0x1E, 0x3E, 0x1E, 0x0E, 0x0C, 0x1E, 0xBE, 0xFE, 0x3E, 0x1E, 0x1E, 0x1C, 0x1C, 0x3C, 0x88, 0x00, 0x00, 0x01, 0x87, 0x00, 0x07, 0x10, 0x3C, 0x1C, 0x0C, 0x0C, 0x00, 0x1C, 0xF8, 0x85, 0x00, 0xFF}; void nmi(void) {} void main(void) { screen_mode_2_text(); paper(0xc); fill_vram0(0x2000,0x1800,0xb0); duplicate_pattern(); rle2vram (gtsSPRITES,0x3800); sprites[0].x=50; sprites[0].y=50; sprites[0].colour=12; sprites[0].pattern=8; sprites[1].x=50; sprites[1].y=50; sprites[1].colour=9; sprites[1].pattern=8; update_sprites(0,2); cls(); screen_on(); pause(); } I made a mistake somewhere. Quote Link to comment Share on other sites More sharing options...
Tursi Posted August 17, 2016 Share Posted August 17, 2016 I don't know the library you are using, but if "screen_mode_2_text" means the 40 column text mode - that's the only mode in which the VDP does not display sprites. Try any other graphics mode. Quote Link to comment Share on other sites More sharing options...
Serguei2 Posted August 17, 2016 Author Share Posted August 17, 2016 (edited) Based from this video https://www.youtube.com/watch?v=a9I9mjKFmkQ Kiwi uses screen_mode_2_text in his code and his sprites show up. Edited August 17, 2016 by Serguei2 Quote Link to comment Share on other sites More sharing options...
youki Posted August 17, 2016 Share Posted August 17, 2016 (edited) the screen_mode_2_text is correct. Try to use change_spattern function to define your sprites pattern , instead of your rle2vram. and use updatesprites(0,2); instead of update_sprites. Edited August 17, 2016 by youki Quote Link to comment Share on other sites More sharing options...
Serguei2 Posted August 17, 2016 Author Share Posted August 17, 2016 Like this? #include <coleco.h> #include <getput1.h> byte gtsSPRITES[] = { 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0x8F, 0x41, 0xFF}; void nmi(void) {} void main(void) { screen_mode_2_text(); paper(0xc); fill_vram0(0x2000,0x1800,0xb0); duplicate_pattern(); change_spattern(0,gtsSPRITES,4); sprites[0].x=204; sprites[0].y=0; sprites[0].colour=9; sprites[0].pattern=15; sprites[1].x=204; sprites[1].y=0; sprites[1].colour=4; sprites[1].pattern=15; update_sprites(0,2); cls(); screen_on(); pause(); } Still not working. If I write change_spattern(gtsSPRITES,0x1800);, I'll get an error. Quote Link to comment Share on other sites More sharing options...
youki Posted August 17, 2016 Share Posted August 17, 2016 (edited) change_spattern must be used like that const byte Sprite1[] = {0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE,0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE,0x41, 0x8F, 0x41, 0xFF}; const byte Sprite2[] = {0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE,0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE,0x41, 0x8F, 0x41, 0xFF}; ..... change_spattern(0,Sprite1,4); change_spattern(4,Sprite2,4); sprites[0].x=204;sprites[0].y=0;sprites[0].colour=9;sprites[0].pattern=0;sprites[1].x=204;sprites[1].y=16;sprites[1].colour=4;sprites[1].pattern=4; updatesprites(0,2); //<= don't put the underscore between update and sprites on that command!... use updatesprites NOT update_sprites Edited August 17, 2016 by youki Quote Link to comment Share on other sites More sharing options...
Kiwi Posted August 17, 2016 Share Posted August 17, 2016 I use void main(void){ screen_mode_2_text(); paper(0xc); fill_vram0(0x2000,0x1800,0xb0); duplicate_pattern(); rle2vram (gtsSPRITES,0x3800); sprites[0].x=50; sprites[0].y=50; sprites[0].colour=12 sprites[0].pattern=0; sprites[1].x=50; sprites[1].y=50; sprites[1].colour=9; sprites[1].pattern=4; cls(); screen_on(); enable_nmi(); loop: delay(1); updatesprites(0,64); goto loop; } I added enable_nmi() so the bios function would work properly and put the delay(1);updatesprites(0,64); in a loop. Now the sprites are being updated 60 hz. updatesprites(0,64); ensure that the sprites won't start flashing due to unknown reason. More on disable_nmi(); enable_nmi(); Enable_nmi() will allow the controller to function, Colecovision sound engine to the next data, anything that is in the NMI{} will run anytime nmi occur. The downside, there is a chance for video corruption if you did too many things during a frame. Right after delay(1); I would use updatesprites(0,64); first, and if you need to draw the score, time or do small video write during the game loop do that first. Then after that, update game logic which uses the CPU and won't corrupt the VRAM. disable_nmi(); will allow you to do large video write. example: disable_nmi(); delay(1); rle2vram(levelCOLOR,0x2000); rle2vram(levelPATTERN,0x0000); duplicate_pattern(); put_vram(0x1800,hud,128); rle2vram(commonSPRITE,0x3800); put_vram(0x3A00,Slime,512); put_vram(0x3F00,itemSPRITE,160);//56 Then use enable_nmi(); if you need the controller, sound and other things to work. And delay(1) in a game loop. This is like WAIT or VSYNC in basic programming if you're running a gameloop. It wait for the vdp status to tell it that it finished drawing the screen. Quote Link to comment Share on other sites More sharing options...
Serguei2 Posted August 17, 2016 Author Share Posted August 17, 2016 change_spattern must be used like that const byte Sprite1[] = { 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0x8F, 0x41, 0xFF}; const byte Sprite2[] = { 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0x8F, 0x41, 0xFF}; ..... change_spattern(0,Sprite1,4); change_spattern(4,Sprite2,4); sprites[0].x=204; sprites[0].y=0; sprites[0].colour=9; sprites[0].pattern=0; sprites[1].x=204; sprites[1].y=16; sprites[1].colour=4; sprites[1].pattern=4; updatesprites(0,2); //<= don't put the underscore between update and sprites on that command!... use updatesprites NOT update_sprites If I need to update sprites, I will use this technique. Thanks for the tip. I use void main(void){ screen_mode_2_text(); paper(0xc); fill_vram0(0x2000,0x1800,0xb0); duplicate_pattern(); rle2vram (gtsSPRITES,0x3800); sprites[0].x=50; sprites[0].y=50; sprites[0].colour=12 sprites[0].pattern=0; sprites[1].x=50; sprites[1].y=50; sprites[1].colour=9; sprites[1].pattern=4; cls(); screen_on(); enable_nmi(); loop: delay(1); updatesprites(0,64); goto loop; } I added enable_nmi() so the bios function would work properly and put the delay(1);updatesprites(0,64); in a loop. Now the sprites are being updated 60 hz. updatesprites(0,64); ensure that the sprites won't start flashing due to unknown reason. More on disable_nmi(); enable_nmi(); Enable_nmi() will allow the controller to function, Colecovision sound engine to the next data, anything that is in the NMI{} will run anytime nmi occur. The downside, there is a chance for video corruption if you did too many things during a frame. Right after delay(1); I would use updatesprites(0,64); first, and if you need to draw the score, time or do small video write during the game loop do that first. Then after that, update game logic which uses the CPU and won't corrupt the VRAM. disable_nmi(); will allow you to do large video write. example: disable_nmi(); delay(1); rle2vram(levelCOLOR,0x2000); rle2vram(levelPATTERN,0x0000); duplicate_pattern(); put_vram(0x1800,hud,128); rle2vram(commonSPRITE,0x3800); put_vram(0x3A00,Slime,512); put_vram(0x3F00,itemSPRITE,160);//56 Then use enable_nmi(); if you need the controller, sound and other things to work. And delay(1) in a game loop. This is like WAIT or VSYNC in basic programming if you're running a gameloop. It wait for the vdp status to tell it that it finished drawing the screen. It works. Thanks again Kiwi. Other thing. I noted icvgm always writes this: byte SPRITESINIT[] = { 204, 0, 0, 15, 204, 0, 4, 15}; Is it useful? Quote Link to comment Share on other sites More sharing options...
Kiwi Posted August 17, 2016 Share Posted August 17, 2016 (edited) byte SPRITESINIT[] = { 204, 0, 0, 15, 204, 0, 4, 15}; Yours would be byte SPRITESINIT[] = { 50,50, 0, 12, 50,50, 4, 9}; I think the data format is y, x, pattern, and color You can load it to put_vram(0x1b00,SPRITESINIT, ; 0x1b00 is where the sprite's attribute goes. I mostly prefer the array format of sprite mainly to load variables and rearrange the sprites priorities to make sprite flickers when there's more than 4 on a line. Loading variable. sprites[0].x=herox; sprites[0].y=heroy; sprites[0].colour=heroc1; sprites[0].pattern=herop1; sprites[1].x=herox; sprites[1].y=heroy; sprites[1].colour=heroc2; sprites[1].pattern=herop2; Rolling up loop to save ROM space and rearrange sprite order every frame. here's an example from my game A Sparrow's Goes Flapping if (flicker==0){ sprites[0].y = birdy; sprites[0].x = birdx; sprites[0].colour =9; sprites[0].pattern =birdpattern; sprites[1].y = birdy; sprites[1].x = birdx; sprites[1].colour =11; sprites[1].pattern =birdpattern+4; sprites[10].y=223;//move bird double off screen sprites[11].y=223;//move bird double off screen for(ID=0;ID<=5;ID++){ sprites[2+ID].y = objecty[ID]; sprites[2+ID].x = objectx[ID]; sprites[2+ID].colour =objectc[ID]; sprites[2+ID].pattern =objectp[ID]; } } if (flicker==1){ sprites[10].y = birdy; sprites[10].x = birdx; sprites[10].colour =9; sprites[10].pattern =birdpattern; sprites[11].y = birdy; sprites[11].x = birdx; sprites[11].colour =11; sprites[11].pattern =birdpattern+4; sprites[0].y=223;//move bird double off screen sprites[1].y=223;//move bird double off screen for(ID=0;ID<=5;ID++){ sprites[7-ID].y = objecty[ID]; sprites[7-ID].x = objectx[ID]; sprites[7-ID].colour =objectc[ID]; sprites[7-ID].pattern =objectp[ID]; } } Edited August 17, 2016 by Kiwi Quote Link to comment Share on other sites More sharing options...
