Sign in to follow this
Gemintronic
Still dumbfounded that rB+ works out of the box this good.
So, I'm procrastinating on an immediate deadline so I thought it would be a good time to revisit rB+
I tried installing the latest rb+_install.exe into a directory with ooooold rB+ files. Went to the command line. Ran the build.bat on an example project folder and BAM!! Worked. Virtual Jag popped up and ran the example.
Next, I tried over-installing to a different directory - this time NOT as Administrator. Same result.
Do you know how hard it is for most devs to get this part right? The part that can make or break further interest in the end user is here.
You guys nailed it. THANK YOU.
  • Like 5
you realise, it doesnt even need to be installed. it will run just fine just put in a folder somewhere
if your intending to actually use it, i would look into the notepad++ add on code and syntax hilighting, i dont know if that has been added to the folder yet but i can supply that if wanted. (i have written that myself, probably not complete but its pretty much there)
Thanks! It really took a lot of effort to get it to be self contained but I'm glad people appreciate it. Hopefully this user friendliness will bring more people to the language :).
  • Like 5
If it is in there I missed it. Most likely due to lack of familiarity with notepad++ Could you post the rB+ add on please?
the actual addon can already be found in rb+, the syntax hilighting is my own creation
in the rb+ folders, goto <RB+ folder>\DOCS\Notepad++ NPPExec presets
current syntax highlight version is attached, it can be imported into notepad++ in the language creation menu
not, there are probably missing commands (that i have not used, but should be a good start. it is a work in progress
rb+ npp language hilight.xml
