mytek #26 Posted October 2, 2016 This is pretty cool. One thing that always bothered me about Atari video is that the border shares one of your playfield colors and can't be blanked. It would have been nice to have a blackout bit. Back in the olden days of using a standard definition TV or a low resolution monitor I never saw the stuff that you see now with more modern and/or better quality monitors. Joust is rather interesting (and very distracting), with little white sparkling activity on the right side of my HDTV screen. Yes a blackout bit would have been nice, but when these systems were introduced there was no need. Anyway hopefully this little board will be the solution to that problem. - Michael 3 Quote Share this post Link to post Share on other sites
olix #27 Posted October 2, 2016 Would the board work with PAL and NTSC Systems? 1 Quote Share this post Link to post Share on other sites
Marius #28 Posted October 2, 2016 This is extremely good news!!!! Oh man how great! Let me know when I can order! Only thing we need still is a good finescroll solution for lcd screens (which is way more better on tube televisions) 1 Quote Share this post Link to post Share on other sites
Mclaneinc #29 Posted October 2, 2016 This is extremely good news!!!! Oh man how great! Let me know when I can order! Only thing we need still is a good finescroll solution for lcd screens (which is way more better on tube televisions) Its looking very good indeed, mytek strikes again...Well done that man... I also love when people show their dev version with croc clips on legs and a wiry mess, you always wonder just how it works in the first place and how there not a zillion times rf interference As for the fine scroll, isn't that to do with the transistor switching times per the screen, hence the blurry mess it can look like depending on the quality / speed of the display. All way too expensive for me hence I keep a bulky but smooth scrolling crt monitor, just a shame its 60 / 75Hz only... Good for NTSC, not so for pal.. 2 Quote Share this post Link to post Share on other sites
mytek #30 Posted October 2, 2016 Would the board work with PAL and NTSC Systems? I will have to look at the PAL system to be sure, but I suspect even if this particular version doesn't work that there may still be a way to accommodate it. This is extremely good news!!!! Oh man how great! Let me know when I can order! Only thing we need still is a good finescroll solution for lcd screens (which is way more better on tube televisions) First things first... I need to route traces, then do an initial test PCB. If all goes well, then I will put the board up on OSH Park for DIY. So if you can solder, or know someone that does, it should be a fairly simple board to put together. So what exactly is the problem with fine scroll on an LCD vs. a CRT? And is this applicable to all LCD's (i.e, HDTV's)? I also love when people show their dev version with croc clips on legs and a wiry mess, you always wonder just how it works in the first place and how there not a zillion times rf interference Funny you should bring that up, because initially I was having quite a few noise issues which as you pointed out isn't surprising for my rats nest prototype - Michael Quote Share this post Link to post Share on other sites
Marius #31 Posted October 2, 2016 I will have to look at the PAL system to be sure, but I suspect even if this particular version doesn't work that there may still be a way to accommodate it. First things first... I need to route traces, then do an initial test PCB. If all goes well, then I will put the board up on OSH Park for DIY. So if you can solder, or know someone that does, it should be a fairly simple board to put together. So what exactly is the problem with fine scroll on an LCD vs. a CRT? And is this applicable to all LCD's (i.e, HDTV's)? Funny you should bring that up, because initially I was having quite a few noise issues which as you pointed out isn't surprising for my rats nest prototype - Michael Well the problem is that fine scrolling uses a real physical vertical blank interrupt, which isn't there on LCD/TFT. I haven't seen any decent finescrolling so far on any TFT screen. Perhaps I do not have the right equipment, and perhaps my screens are too cheap to do it right, but nothing is as smooth as my old fashion tube CRT. So I was wishing for a solution for TFT/LCD screens... 2 Quote Share this post Link to post Share on other sites
Bryan #32 Posted October 2, 2016 Well the problem is that fine scrolling uses a real physical vertical blank interrupt, which isn't there on LCD/TFT. I haven't seen any decent finescrolling so far on any TFT screen. Perhaps I do not have the right equipment, and perhaps my screens are too cheap to do it right, but nothing is as smooth as my old fashion tube CRT. So I was wishing for a solution for TFT/LCD screens... The way scrolling/animation looks is a side effect of the display technology. The VBI happens inside the Atari which doesn't know/care what kind of monitor is connected. What you're seeing is the lack of phosphor persistence and possible frame blending going on in the LCD TV. 1 Quote Share this post Link to post Share on other sites
Marius #33 Posted October 2, 2016 The way scrolling/animation looks is a side effect of the display technology. The VBI happens inside the Atari which doesn't know/care what kind of monitor is connected. What you're seeing is the lack of phosphor persistence and possible frame blending going on in the LCD TV. What you describe is true, but for me it is the other way around. The Atari works this way, because back then the only screens available had these physical properties. So the Atari is designed for the use on a tube. So I would love to see a workaround to see the same effect on TFT as on CRT, but I'm afraid that will never happen... Quote Share this post Link to post Share on other sites
Bryan #34 Posted October 2, 2016 I agree that you need a CRT to get an authentic retro experience. Getting the same effect with an LCD is going to be difficult. I suppose if you had enough DSP horsepower to throw at the problem you could actually emulate some of the analog nature of CRT phosphor on a decent PC monitor by using a fast refresh rate. 2 Quote Share this post Link to post Share on other sites
mytek #35 Posted October 3, 2016 (edited) I've been playing around with the layout for the V-Gate board and due to signal locations being more accessible from the right side of the GTIA chip, I relocated the accessory support header on the right side as well. This does make for a tight fit between the board edge and the 4050 chip on the XEGS which could create a problem with the UAV board if present (I still need to confirm this on real hardware). Simulation of V-Gate board installed in an XEGS And having the trim pots and other misc componets on an overhang above GTIA maybe problematic with the cartridge connector in a 65XE, but I'll also need to confirm this as well. However for all other models including a 400/800 it looks like a good fit. BTW could someone that has a 400/800 confirm that this would indeed work and clear any card guides involved. Simulation of V-Gate board installed in a 400/800 (CPU/Video Board) I've been looking at PAL video timing vs. NTSC and so far it looks like the same solution will work in both cases. - Michael Edited October 3, 2016 by mytekcontrols 3 Quote Share this post Link to post Share on other sites
mytek #36 Posted October 4, 2016 (edited) OK I got out the hammer, and squeezed it in a vice, but I think I finally got this down to a size that will work in ALL Atari 8-Bit computers. However a sacrifice had to be made, and that was the identifying labels on the Accessory Support Header (the text would have been too small to clearly read). This was unfortunate, but certainly not a deal breaker by any means (it just means you'll have to consult the schematic to figure out which pin goes where). By leaving out the labels and pushing the header closer to the GTIA chip, I was able to get it to play friendly with Bryan's first generation UAV board sitting in the 4050 socket to the right of the GTIA in a XEGS. Hopefully Bryan hasn't encroached on this space any farther on the next generation boards (Hint...Hint ). This will still be a very tight fit in a 65XE, but so far it looks doable without modifying anything (with the possible exception of the RF shield). Silk Screen and Pads (shown larger than reality) Top Traces Bottom Traces I'll be ordering 3 of these tomorrow from OSH Park. And after I have finished evaluating them, I'll post a revised schematic and provide a public link for others to order the boards. - Michael Edited October 4, 2016 by mytekcontrols 3 Quote Share this post Link to post Share on other sites
olix #37 Posted October 4, 2016 I'll be ordering 3 of these tomorrow from OSH Park. And after I have finished evaluating them, I'll post a revised schematic and provide a public link for others to order the boards. - Michael Great work! Have I understood that correctly, that i have to order directly from OSH Park? How expensive is it? Check you still whether the board also works with PAL-Systems? Olix Quote Share this post Link to post Share on other sites
mytek #38 Posted October 4, 2016 (edited) Great work! Have I understood that correctly, that i have to order directly from OSH Park? How expensive is it? Check you still whether the board also works with PAL-Systems? Olix Hi Olix, Yes unless someone else steps in and manufactures these, the unassembled boards can be ordered from OSH Park for $4 each (minimum order 3 pieces). This price includes free shipping here in the US... not sure what the situation would be shipping overseas (note: just checked, and it appears international first class shipping is also free). I do not have the means to test on a PAL system, but perhaps I can find someone that can. However since the over scan adjustment timing is triggered on the rising edge of CSYNC, it stands to reason that it should work with PAL or NTSC. There is enough adjustment available in the OFFSET and WIDTH controls to likely compensate for any minor differences in scan line length. - Michael Edited October 4, 2016 by mytekcontrols Quote Share this post Link to post Share on other sites
mytek #39 Posted October 4, 2016 This will still be a very tight fit in a 65XE, but so far it looks doable without modifying anything (with the possible exception of the RF shield). I really need to get stronger glasses! I mistakenly thought the CPU (Atari P/N C014806) was the GTIA chip (Atari P/N C014805). Notice that the '6' on the SALLY part number almost looks like a '5' instead. Anyway long story short, thinking that the SALLY was the GTIA chip caused me all kinds of work to reduce the overhang on the V-Gate board in order to make it fit in the space available below the cartridge port and the plastic case (not shown). Once I figured out that the GTIA chip was 2 chips lower than I originally thought, suddenly I have all kinds of room - Michael 5 Quote Share this post Link to post Share on other sites
Mathy #40 Posted October 4, 2016 Hello Michael Mistaking the CPU for the GTIA is something that could happen to anybody. But squeezing a hammer using a vice... that's a different story. Sincerely Mathy Quote Share this post Link to post Share on other sites
mytek #41 Posted October 4, 2016 Hello Michael Mistaking the CPU for the GTIA is something that could happen to anybody. But squeezing a hammer using a vice... that's a different story. Sincerely Mathy Hi Mathy, Yep you are absolutely right about that being a different story Of course what I meant to say was (and left out) was that after getting out the hammer, I tapped on the board, and then placed the board into the vise for a final squeeze to compress it down to a suitable size. And this all happened in the virtual workshop in my mind . - Michael 1 Quote Share this post Link to post Share on other sites
_The Doctor__ #42 Posted October 26, 2016 That'ss okay the smaller size makes sure it does not rub elbows with other upgrades and allows for better air flow for the whole Atari.. bonus! smaller usually mean less cost in more ways than one 3 Quote Share this post Link to post Share on other sites
mytek #43 Posted October 27, 2016 (edited) New Design in the Works The first production prototype failed to meet expectations. Basically there were still some noise and repeat-ability issues to work out, and then I just had to admit to myself that this approach was not a good one. So basically what I did is toss out the whole idea of using analog RC delays to do the video gating, and popped in a PIC MCU chip to be the timing generator. The great thing about taking this new approach is that the design now requires absolutely no calibration what-so-ever. It just works right out of the box. The good thing about having a small run of boards made (3 from OSH Park), is that I was able to use one as a nice break-out board for developing my new design. I only stuffed this board with the high-speed quad AND gate (74HCT08) which is used as my Luma switch, and then ran the control line off board to be able to use an MCU to control it. And here I am prototyping the MCU circuit, which also has a high-speed analog switch (74HCT4066) to do the Chroma switching. Presently I am just using a PIC16F1847 chip (same as TK-II) for my development, but in the final design I'll be using a much smaller chip for both the MCU and the analog switch. New schematic. And what this thing looks like on a scope when it's doing its thing. Upper Trace = Composite Video, Lower Trace = VGATE signal. So in this new way of doing things, the MCU is using GTIA's 3.58 Mhz (NTSC) OSC signal, multiplying that x4 with an internal PLL, and then executing an interrupt timing routine for every time CSYNC goes from low to high. In this routine, delays are being used that are derived from the 14.318 Mhz PLL clock. So for instance, one NOP instruction = approximately 280 nano seconds to execute. So I created a little delay loop routine that takes just a little over 1 uSec for each pass, with the number of passes determined by the value of a variable that is preset before calling the delay routine. So this gives me a gross delay, which I can then further refine with a few NOP's tossed in. These calculated delays are then used to 'turn ON' or 'turn OFF' the gating signal that enables or disables video. Basically the same as what I was doing with RC delays before, but now much more precise, and locked into the Atari's master clock. Essentially you could say that the MCU is 'gen-locked' to the Atari. Here is an example of the interrupt code (it is called every time CSYNC goes low-to-high)... org 0x004 ; processor interrupt vector bsf PORTB,VGATE ; turn on video (start of color burst) movlw 01H movwf dlyloop call dly_1us btfsc PORTB,EN ; Leave video ON if Enable pin grounded bcf PORTB,VGATE ; turn off video (end of color burst) movlw 01H ; short delay before active field movwf dlyloop call dly_1us nop nop ; each 'nop' = 280 nSec bsf PORTB,VGATE ; turn on video (start of active video data) movlw 29H movwf dlyloop call dly_1us btfsc PORTB,EN ; Leave video ON if Enable pin grounded bcf PORTB,VGATE ; turn off video (end of active video data) banksel INTCON ; clear interrupt flag bcf INTCON,INTF retfie ; leave interrupt And as can be seen, there is also facility for enabling or disabling what the V-Gate board is doing to the A8's video, through the use of an enable pin on the MCU. Essentially if it is disabled (enable line = low), then no turn offs of the gating signal is allowed, so the entire video field is passed through. Since there is a pull-up resistor on this pin, the board defaults to video gating enabled. Here is Joust on an HDTV showing a rather annoying sparkling line on the right side (V-Gate Disabled). Here is what it looks like with the V-Gate enabled. Switching modes is glitch free. Anyway now I'm just waiting for the new PIC chips and analog switch to arrive. If all checks out well, then its on to laying out a 2nd board. - Michael Edited October 27, 2016 by mytekcontrols 1 Quote Share this post Link to post Share on other sites
+Stephen #44 Posted October 27, 2016 This is so far over my head, it's like trying to teach a dog to play chess. I still like following along though. 1 Quote Share this post Link to post Share on other sites
mytek #45 Posted October 27, 2016 (edited) This is so far over my head, it's like trying to teach a dog to play chess. I still like following along though. Hey don't feel bad. The original reason I took the RC delay route, was because it had been so long since I had done low level assembly on a PIC Chip that I knew it would be like starting from new (which I wasn't looking forward to). The other thing that made the process even more tedious was that I needed to setup all of the required tools like MPLAB-X IDE and get it talking to my programmer as well (this turned into a day all by itself, since the PICkit 3 borked itself). I also had to refamilirize myself with the RISC based instructions which as you can see are a bit more cryptic than 6502. But I had to do it in assembly, since the small 8-pin PICS can only go so fast, and every instruction takes 4 clock cycles, unlike a 6502 that can do it in one cycle. So to give you a feel for execution time, if you look at the scope, you'll see there is a space between the end of the A8's video sync and the VGATE signal switching on. My intention was to have it instantly turn on, but that's as fast as it can be done with a 14.318 MHz clock in the PIC. If I had try to do this in Basic, FlowCode, or even C it would not have been quick enough to even work at all. So sadly I couldn't use any of my higher level languages for this application, and I had to cook my brain to figure it out in assembly (I don't use it enough to stay fluent). Then the other problem is trying to figure out what all of the chip configuration fuses need to be set to to do what you want (that's another brain teaser). Anyway I'm now on the downhill stretch, and things are looking good. - Michael Edited October 27, 2016 by mytekcontrols 1 Quote Share this post Link to post Share on other sites
mytek #46 Posted October 27, 2016 (edited) Rev 1.5 Update Just a final tweak to the schematic (locked in the PIC model #, fixed the LED orientation, and generally just cleaned up a few things). Download: PIC12F1571 DatasheetVendors and Pricing And here's a peek of what I'm leaning towards with the new PCB layout. I'll probably start routing traces this weekend, and possibly do another small board run sometime next week. And for those that are wondering... Yes the MCU will be programmable with the JOY2PIC and a V-Gate Flashing ATR. - Michael Edited October 27, 2016 by mytekcontrols 3 Quote Share this post Link to post Share on other sites
mytek #47 Posted November 2, 2016 (edited) New Boards Are On The Way for the 'No Adjustment' Rev 1.5 version of V-Gate Board Top Placement and Silk Screen Top Layer TracesBottom Layer Traces Final tweak to schematic I have two simultaneous orders underway. One with OSH Park and the other with ALLPCB. OSH Park will take at least 2 weeks before they ship, so I thought I would also give these other guys a try as well, since they said they would ship via DHL in 4 days. I'll also be getting 10 boards for about $2.90 a piece (that price includes shipping), vs. 3 boards at nearly $4.00 a piece (also includes shipping) from OSH Park. It'll be interesting to see what the quality looks like from ALLPCB. My plans are still to have the boards hosted at OSH Park, but I'll also have the Gerbers available from my website for those that want to farm it out elsewhere. Since I am still using Rev 1.5 as I did for the last two schematic updates, and to avoid any confusion that this may cause, the previous two posted schematics will be taken down shortly. And yes that is an SMD part being used for the analog chroma switch. unfortunately I could not get a PDIP version, but at least this one only has 5 leads that need to be soldered. OPERATION Basically assuming the PIC chip has been programmed with the V-Gate firmware, plugging it into the GTIA socket and then inserting the GTIA chip into it, is all that is minimally required to have this board do it's thing. And by 'doing it's thing', I am referring to automatic deletion of video that extends into the over-scan area of the screen. The two headers have the optional V-Gate enable and LED connections, and the various GTIA logic signals for connection to other popular A8 upgrades. But these are 'optional' connections, and not required in order for V-Gate to work. - Michael Edited November 2, 2016 by mytekcontrols 2 Quote Share this post Link to post Share on other sites
mytek #48 Posted November 2, 2016 I got the new 8-pin PIC chips in today (PIC12F1571), made a quick device change to my source code, and then programmed the chip. I'm happy to say it worked on the very first attempt . Luckily this chip is very similar to the PIC16F1847 I was previously using for code development, just with less I/O and less memory, so not much needed to be changed in order to make the transition. And it turned out to be a perfect fit for what I needed, having just enough I/O to do the job (with one I/O pin left over). Check out the: PIC Assembly Source Code ;**************************************************************** ;* Name : V-Gate1571.asm * ;* Author : Michael St. Pierre * ;* Notice : Copyright (c) 2016 Mytek Controls * ;* : All Rights Reserved * ;* Date : 11/02/2016 * ;* Version : 1.0 * ;* Notes : Over-Scan Timing Generator (V-Gate Chip) * ;* : Based on Microchip PIC12F1571 * ;* : Assembled in MPLAB-X v3.35 * ;* : * ;* : Firmware for Atari V-Gate Over-Scan Delete Board * ;* : Rev 1.5 * ;**************************************************************** list p=12F1571 ;Define Processor #include <p12f1571.inc> ; Set configuration register for: ; Code protection off ; Brown-out detect off ; MCLR disabled (I/O Pin) ; Watch Dog timer disabled ; Power on reset delay enabled ; Enable External Clock Input (3.58 Mhz GTIA OSC) ; 4x PLL enabled (14.318 Mhz) ;PIC12F1571 Config Settings __CONFIG _CONFIG1, _FOSC_ECM & _WDTE_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _BOREN_OFF & _CLKOUTEN_OFF __CONFIG _CONFIG2, _WRT_OFF & _PLLEN_ON & _LVP_OFF ;********************************************************************** ;Variables and Equates ;********************************************************************** cblock 0x20 dlyloop endc #DEFINE CSYNC PORTA,2 #DEFINE VGATE PORTA,4 #DEFINE LED PORTA,1 #DEFINE ENABLE PORTA,0 ;********************************************************************** ;Start ;********************************************************************** org 0x000 ; Processor reset vector goto SetUp ; Set up Port I/O, IRQ, ect. ;---------------------------------------------------------------------- org 0x004 ; Processor interrupt vector bsf VGATE ; Turn on video (start of color burst) movlw 01H call dly_1us btfsc ENABLE ; Leave video ON if Enable pin grounded bcf VGATE ; Turn off video (end of color burst) movlw 01H call dly_1us nop bsf VGATE ; Turn on video (start of active video data) movlw 37H call dly_1us nop nop ; Each 'nop' = 279 nSec btfsc ENABLE ; Leave video ON if Enable pin grounded bcf VGATE ; Turn off video (end of active video data) banksel INTCON ; Clear interrupt flag bcf INTCON,INTF retfie ; Leave interrupt ;********************************************************************** ;Setup ;********************************************************************** SetUp ; configure Ports banksel TRISA movlw B'11101101' ; RA1 & RA4 Outputs, all others input movwf TRISA banksel WPUA movwf WPUA ; Enable individual pull-ups for PORTA inputs banksel ANSELA clrf ANSELA ; Switch PORTA from analog to digital inputs ; configure interrupts banksel OPTION_REG bsf OPTION_REG,INTEDG ; 1 = interrupt on CSYNC rising edge bcf OPTION_REG,7 ; Global enable weak pull-ups banksel INTCON bsf INTCON,INTE ; 1 = enables the GPIO port change interrupt bsf INTCON,GIE ; 1 = enables all unmasked interrupts goto Main ;********************************************************************** ;Subroutines ;********************************************************************** dly_1us movwf dlyloop dly decfsz dlyloop,1 goto dly retlw 0 ;********************************************************************** ;Main ;********************************************************************** Main btfsc ENABLE bsf LED ; Turn on LED if V-Gate enabled btfss ENABLE bcf LED ; Turn off LED if V-Gate disabled goto Main end - Michael 2 Quote Share this post Link to post Share on other sites
_The Doctor__ #49 Posted November 2, 2016 to be clear then, software that purposely uses overscan or underscan will not be cut short or reveal a mess as this now auto adjusts? Quote Share this post Link to post Share on other sites
mytek #50 Posted November 3, 2016 to be clear then, software that purposely uses overscan or underscan will not be cut short or reveal a mess as this now auto adjusts? The amount of overscan that gets deleted, is well outside of what old CRT Monitor's and older TV's were able to actually show. I opted to let as much of the video as possible to come through, while eliminating what was obviously never intended by the game or application's creator to be seen. Now I can't speak for newer software that intentionally takes advantage of HDTV's and better monitors, but in those situations you can simply turn the video gating off and reveal all of what is there to be seen. This can either be done with a toggle switch or a software switch (i.e. U1MB's additional control lines). Also keep in mind that the video gating in no way interferes or is seen by the software running on the A8. And this is a 'fixed' not dynamic (auto adjusting) video gating process based on exact timing genlocked to the GTIA's OSC input (3.58 Mhz for NTSC). - Michael Quote Share this post Link to post Share on other sites
