PROJECT SOURCE:http://www.harmlesslion.com/text/atx_peb.htm
I can't seem to edit the original post so here's all the exciting photos so far. Almost ready to put the cards in and fire it up.
Getting ready.
14264011_10206900923153573_5222135061964
Cool Fan! No pun intended, that is a pretty cool looking fan.
14222176_10206901154079346_1624021361323
This guys is tough and tight. Rachet set to the rescue.
14242397_10206901269962243_7801413392044
What a pain..
14203133_10206901270682261_3686743221541
Getting there, at least I'll have spare parts for the power supply in my other PEB.
14222135_10206901271602284_6672594473691
More still...
14192502_10206901272962318_1847869808660
Dayum.
14212796_10206901273402329_4314290290167
OK...
14196189_10206901273842340_4169836649333
Gonna have to desolder this to insert it from the outside.
14199773_10206901649131722_5844231003201
Power connector didn't fit. Had to break off dine plastic and temporarily wedge mount it. Yeah, that's a new home engineering term...wedge mount.
14225372_10206901645611634_3810562619267
The infamous wedge mount.
14188539_10206901646251650_8419812608339
14138674_10206901647451680_5227213446355
Not lucky, holes don't line up. Time for the hot glue gun.
14249994_10206901788495206_3252253442358
14238302_10206901789215224_3524232370503
14225426_10206901839936492_2348558359054
14199322_10206901906858165_1504152089724
14192768_10206901909418229_3136818283045
Wiring up the external drive power. Decided to use the original internal floppy power cable of the PEB sure to its length.
14257722_10206901999140472_7612141229907
Decided to leave the original wires in place. Solder point were good. Back plane all wired up.
14225556_10206902298267950_5869835966440
Upgrade psu, include label.
14183778_10206902326468655_1081399162197
Go ahead, hate on me. Hot glue, modder's duct tape.
14124506_10206902479832489_1382754728417
14192101_10206902481192523_7358638724678
Did a quick power test. Not working. What? Syu a visual inspection of everything and find this...dammit!
14203209_10206902544274100_1748126660784
I'm going to try and fix this.
14225422_10206902777559932_5169886668047
Hardest thing I ever attempted soldering.
14192736_10206902794120346_2926173801539
Assuming that's making the connection, I think I have something to work with now.
14141572_10206902802000543_4892114402558
Let's do this...
(Video Link) - https://www.facebook.com/SExmortus/videos/10206902808080695/
(video Link)- https://www.facebook.com/SExmortus/videos/10206902883482580/
And now let's test it...
(Video Link) - https://www.facebook.com/SExmortus/videos/10206902914323351/
Let's connect and test the power switch...
(Video Link) - https://www.facebook.com/SExmortus/videos/10206903057046919/
14191986_10206903064527106_1307429426648
A dab of hot glue to reinforce the solder joint, heading ave cooling and all that jazz.
14202549_10206903149849239_3843327020345
No Loose Ends!
14222196_10206903158969467_1483872782995
Not paying attention - can't close case. Time to open up again.
14237669_10206903232491305_2351546652875
This should do it..
14199135_10206903265732136_2896556412654
Almost done. Just powered it on to double check, everything still good so far.
14188103_10206903340934016_4072617382816
Stay tuned, next update will be connected to IT with all cards and 2 drives installed.
YOU GOTTA BE KIDDING ME!?!?
14199415_10206903724303600_5772314556274
I'm not messing around.
14212794_10206903725263624_7370611547292
Done!
14212714_10206903725583632_1027535514001
SUCCESS! I mean TADA!
14199620_10206903862907065_8852333284780
Edited by Sinphaltimus
  • Like 5
Just to verify both internal (DSK2) and external (DSK3) drives are working properly. DSK1 will be my GoTek as soon as it arrives.
14203295_10206906288607706_4227950325316
14199224_10206906289007716_8223890920030
​Did I happen to mention how insanely quiet it is. Can't even tell its on until the TI gets turned on and you see the light. I may add a power LED to this just for that reason.
Nice work. Something to consider for the future. All I did was replace the fan in my PEB with a nice quiet one and change out the LEDS for blue ones. Figured if the PSU dies then I can consider the ATX route.
Yes I did this years ago with an AT PS now I have some info to use as I upgrade one of my TI systems to a ATX PS and tower case.
I'm going to put leds (not sure what color) on all the empty slots as a power light. Next up, I'm going to have to extend one of the floppy power cables, one of them is too short. I also have to find my black floppy and some face plates.
A temperature gauge looks cooler! ;)
I have a small blog entry << HERE >> on how I did mine. I've updated the links too.
Feel free to check it out.
I dunno who any one is everywhere, but Fred, if you're here, I have some questions in regards to this...
On Facebook:
Fred Kaal An disadvantage by leaving the 5v regulators intact is that they now have to consume 7volts (12-5) instead of 3volts (8-5). With the same current the expansion cards are drawing this means that the voltage regulators have to dissipate more power (P=U x I) which mean that they will get hotter. Better keep an eye on this when your pe-box is switched on for a long time.
Lenny Rivera I'm looking to install a temp monitor. One question I have is the original source article I used for the mod, appears the internal card had no case. Is that normal? Should I pull these out of the cases and maybe install another fan or two?
Also, what is the safe operating temperature for these voltage regulators? I may get one temp probe for each card.
Congrats!
Because the heat output is greater, it is imperative that your 5v regulators have proper heat sinks or clamshells to transfer the heat. Myarc cards are especially prone to heat degradation, and usually require regulator replacement at some point.
I originally modified my system back in the early 90s (or there-abouts). The prevailing method was to tie 12v to 12v and 5v, and -12v to -12v. My systems ran 24x7 for years in this configuration with no major issues so long as the heat didn't build up inside the case. Repairing burned up "jumpered" cards got old quickly, so the earlier "jumper or remove the regulators" option fell by the wayside.
The linked article here from ckoba raised some interesting points related to regulators and AT(X) power supplies as he details how he refurbished the PEB power supply. I never got a chance to really dig into it, but those here who are interested in the PEB mods might want to give it a read....
https://www.disavowed.jp/index.php?/archives/45-Refurbishing-a-TI-PEB-power-supply.html
Thanks for sharing that. OK, I ordered myself a few temp gauges. I'll research the part number when I open the peb (when the GoTek arrives).
I'll also research voltage regulators that can maybe replace the once on the card and work better with atx power?
I was chatting with a friend over his past weekend and he recommended looking at the TI LM23 voltage regulator.
If I can't replace the existing regulators with a newer more capable one for the application then I will definitely install heat sinks and micro fans in the regulators. Even if I have to cut the clamshell to do it. I have two of all these things. One set for modding, the other to keep stock. So if I have to mod my cards to protect them I will.
There wasn't anything wrong with the old power supply, I just got spooked at running 2 internal and one external drive off the thing along with 3 cards and LEDS I plan on adding. In my 80 track mod topic here: http://atariage.com/forums/topic/256550-just-completed-the-80-track-disk-controller-mod/page-2?hl=+80%20+track%20+mod Scroll down to my post :
Posted Fri Sep 2, 2016 3:58 PM
So many light bulbs today. Here's one! Recalled having an external CD rom case I might be able to use for my half height DSK3!
Now I've got other worries.
EDIT: I run all my computers on UPS battery backups to help with the protection part so there is that also. But if the PSU goes...
Very nice work and documentation :)
For me and my soldering "skills", I was a bit anxious, because of ♫ burning down da house ♪ and this things ;)
but I´ll wait a little time now, and if I still see you posting here in some weeks, maybe I´ll givem a try :grin:
thx
xXx
I believe the metal and perhaps the metal 'composite' clamshells sufficiently wick enough heat away. As a reminder to everyone they are conductive. If you move a non-TI card into one of the clamshells (or modify for a TI card) watch out for the support tabs inside the shell as they could potentially short the traces and/or power.
You can replace them, I know there's a guy on FB that likes to discuss the correct ones but updated VRs are going to generate less heat.. I sell nice little heatsyncs that fit on VRs on arcadeshopper.com if you need them for non metal clamshelled cards
Greg
Greg
Excellent, I'll search around for the replacement vr AND check out AS also. I'm not in a terrible rush as I don't run my real iron much at all and not for long periods of time (yet). But I do want to protect and preserve its functionality for as long as possible. And I'll need it to survive an outdoor stage show in July.
Also I have a typo in the vr my friend recommended. I believe it's the lm723.
http://www.ti.com/lit/ds/symlink/lm723.pdf
I didn't replace any of my regulators, and my cards are all working fine. When I first built Thierry's IDE card, that would shut down after a few minutes before I put a heat sink on the regulator, but it didn't take a very large one. Besides the fins and the size of the PCB itself, it got sufficient cooling, even when the PEB was open.
Do you know the optimal operating temp? I ordered some temp probes to stick near or on the voltage regulates but without knowing what safe temps are..... I figured I'd find the VRs when I open the clamshell and then look up whatever was stamped on it. I imagine just asking is far more efficient.
I don't, but if you get the exact part number, that information will be in the datasheet. That said, usually "too hot to touch" is too hot. ;) Datasheet will probably tell you how hot it will get, too, if you can read the tables. ;)
Just a follow up. Your comment "too hot to touch" lead me here.
http://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/20100020960.pdf
Thanks. :)
So I ran the ti for about an hour under moderate load (playing games) last night and the warmest card was the 32k card.
It got as high as 96 degrees F. But would not get any hotter.
I was able to get the disk controller up that warm as well doing disk operations on my 5 1/4" drive. The flex interface topped off at about 94 degrees F.
I'm going to guess these are optimal operating temperatures?
Also, to note, the disk controller and memory cards have 2 voltage regulators each. I put the probes at the regulators furthest from the vent holes (one probe each card).
The probes are almost touching the top of the regulators (hot air rises) so I hope it's pretty accurate.
If they ever breech 105 degrees F, I'll install fans to pull the hot air out of the vent holes.
I have micro fans I think will do the job nicely. And by micro fans I mean they are about 1 inch square for venting hdd caddies. Old school stuff I'm ripping out of old school gear.
Well, I completed the installation of an ATX power supply in my PEB, and I started experiencing strange issues. First, DSK2 stopped being accessed, only DSK1 and DSK3. Then the power supply wouldn't even start if the pcode card or the HDX modified RS232 card was in the PEB. The IDE card worked fine.
The Geneve wouldn't even start up.
I have the 5V and +12V lines both connected to the PS 12V, and the -12V line to the PS -12V. Ground to ground as well.
It seems no one else has had these issues. What gives?
I switched back to a backup PEB with the original PS and everything was back to normal...
