Sign in to follow this
orpheuswaking
Joypad test program?
Is there a joypad test program - that would also run on both port one and two?
I had my Jaguar at VCF Midwest and someone yanked the controller from port two. Everything seems to work on the two player games I ran after HOWEVER I cannot make the Tempest 2000 spinner option trigger (I'm running TK2 from the skunkboard so I have to enable it each time.) I tried the hold option on both pads, as well as the paperclip short on the correct pins. Both worked before the "incident" and not after.
I tried with four separate controllers and nothing. SO I am suspecting either the controller port is damaged inside OR a bad solder joint. I can reflow the solder joints but if it needs replaced I am at a loss.
Anyone able to fix this for me?
Well I'm stupid... It's pause not option to activate the rotary option, system is fine... Although I did enjoy testing every pad I have with the test program.
