1NG #1 Posted September 16, 2016 I need your help! I have been working the past year on the cartridge of Jim Slide. But I need some levels in the next three weeks to finish it. The release date is Oct. 22nd. There will be 4 diffent difficulties in the story mode: easy, medium, hard and insane. You can use the attached level editor on a Win7 System or up with a resolution of at least 1280x800. After installing you need an emaulator for the Atari 8 Bit too and need to link the default ending XEX to the emulator. Editing is easy. Pick and draw with the left mouse button and erase with the right one. Press F5 to test a level (If that does not work, then the XEX is not started with your emulator yet. Just locate a xex like the one installed with the level editor and double click it. Now choose your emulator application like Altirra and make it permanent. Post any new level here or send it directly to me. Configuration of Altirra: Use the Atari XL OS. At least 64KB RAM are needed. Audio can be stereo. The 1MB catdridge image will be released, when it is done. Hopefully it is done on Oct. 22nd. There will also be a collectors box available (but only a few. If you are interested, then give me a hint :-) If you can help me with testing of the cartridge it is also very welcome! Just leave me a note and you get a rom image for testing soon. -> The newest images of Jim Slide on disk and cartdridge will be freely available after that release!. And this level works too :-) Thank you! SlideLevelEditor.zip level.zip 4 Quote Share this post Link to post Share on other sites
Goochman #2 Posted September 16, 2016 Ive never heard of Jim Slide - what is the game about so we can think of levels to build? Quote Share this post Link to post Share on other sites
Goochman #3 Posted September 16, 2016 I cant get the level tester to run with Altirra 2.71 - it appears I cant default Altirra 2.71 to boot without Basic and have to Shift+F5+F4 in order to remove Basic. Not sure if that is causing the problem but I just get a garbled screen with I try to test a level. Quote Share this post Link to post Share on other sites
1NG #4 Posted September 16, 2016 Sorry! Yes, Basic has to be off in that old special version of Jim Slide for the level editor. I totally forgot that. (The later versions disable Basic themself, but are incompatible due to compressed level techniques) Please disable Basic in Altirra in the Options. System - Firmware - BASIC should not have the marker. Quote Share this post Link to post Share on other sites
+orpheuswaking #5 Posted September 16, 2016 I'll take a look at this over the weekend, would love to help test (potentially purchase a collectors cart too depending on price) 1 Quote Share this post Link to post Share on other sites
Goochman #6 Posted September 16, 2016 Sorry! Yes, Basic has to be off in that old special version of Jim Slide for the level editor. I totally forgot that. (The later versions disable Basic themself, but are incompatible due to compressed level techniques) Please disable Basic in Altirra in the Options. System - Firmware - BASIC should not have the marker. Unfort it boots with basic no matter the setting I choose Quote Share this post Link to post Share on other sites
Goochman #7 Posted September 20, 2016 Ok I fixed my OS issue but adding the XL Rom which gives me the Basic disable option. That worked. I didnt have much time to work on this - making something tricky involves alot of planning so chalk this up to an easy level. halloween.zip Quote Share this post Link to post Share on other sites
Goochman #8 Posted September 20, 2016 A little more challenging breakout.zip Quote Share this post Link to post Share on other sites
Goochman #9 Posted September 21, 2016 Something familiar PacMan.zip Quote Share this post Link to post Share on other sites
+orpheuswaking #10 Posted September 21, 2016 No matter what I do I can't get these to open in Altira or atari800win - I have all the settings correct. When I open the test XEX in Altira I get a green screen and a blocky blob in the middle... Basic is off, XL OS and 64k mem Quote Share this post Link to post Share on other sites
Goochman #11 Posted September 21, 2016 I added the XL/XE OS to Altiraa and selected that as my default OS with Reverse Basic (you get that option when you add an OS other than the Altirra ones). My firmware says Atari XL/XE OS ver 2.0 I am running a XL 128K NTSC as my machine Ive added my XL ROM to this msg ATARIXL.ROM Quote Share this post Link to post Share on other sites
Mclaneinc #12 Posted September 21, 2016 There is a 'dodgy' version 2.0 out there, I have it although I don't remember which one it is but its caused stuff to not boot correctly and crash. I just tried the editor out and didn't change any settings and hit the test level button and it worked so I'm presuming its looking at file associations, in the tools section of Altirra have you associated it to the different file types? Quote Share this post Link to post Share on other sites
+orpheuswaking #13 Posted September 21, 2016 I didn't have XEX associated with anything. I had it set to Altirra last night, but no matter what I select in the level editor it never opens into Altirra. Quote Share this post Link to post Share on other sites
Mclaneinc #14 Posted September 22, 2016 Weird, looked for a config to pick where Altirra is and there's no way to config that and as my Altirra is on E: in a folder called Atari I doubt it was a lucky guess on his part so I can only imagine he's using the default program to open an XEX. Setting it in Altirra should be all you need to do but you could right click on an XEX and set the open with in there just in case. There's alwats the start menu and default programs to go for overkill Quote Share this post Link to post Share on other sites
+orpheuswaking #15 Posted September 22, 2016 (edited) Yup I did all that, but still when I hit f5 or the test button nothing happens. It's probably for the best though. My level building skills are poor at best. On the other hand I would be happy to help test the cart Edited September 22, 2016 by orpheuswaking Quote Share this post Link to post Share on other sites
Goochman #16 Posted September 22, 2016 What version of Altirra are you using? Upon installing 2.71 it assigned .xex file extensions to Altirra. If oyu havent upgraded maybe try that to see if it fixes anything. You will need to add the XL firmware afterwards to avoid using the Altirra firmware. Quote Share this post Link to post Share on other sites
Goochman #17 Posted September 22, 2016 Ho ho ho xmas.zip Quote Share this post Link to post Share on other sites
+orpheuswaking #18 Posted September 22, 2016 I'll see if I can get it to work tonight Quote Share this post Link to post Share on other sites
Mclaneinc #19 Posted September 22, 2016 Are you on Windows 10 by any chance and is Altirra on a non local drive? Quote Share this post Link to post Share on other sites
Goochman #20 Posted September 22, 2016 I am using Win10 and Altirra not on the boot drive - it is an internal drive, just not the boot drive. Quote Share this post Link to post Share on other sites
+orpheuswaking #21 Posted September 22, 2016 WIN 7 one drive Quote Share this post Link to post Share on other sites
Mclaneinc #22 Posted September 23, 2016 Bugger, I'm at a loss then..Ignoring the editor, if you double click say on an xex file does it then run Altirra fine? Quote Share this post Link to post Share on other sites
+orpheuswaking #23 Posted September 23, 2016 Yes any XEX works fine - pops right up in Altirra Quote Share this post Link to post Share on other sites
Goochman #24 Posted September 23, 2016 This is my firmware setting in case it helps Quote Share this post Link to post Share on other sites
Goochman #25 Posted October 4, 2016 I guess this has gone by the way side as no response from ING on this. Quote Share this post Link to post Share on other sites
