Sign in to follow this
Ramses
Atari 800XL Memory Problem
10 minutes ago, hueyjones70 said:
I am working on a 800XL that doesn't go to self test when I boot while pressing OPTION. Any ideas of the possible cause.
Does it go to self-test when you type BYE from BASIC? If not, then look at a bad PIA or PIA socket.
It went to self-test when I typed BYE. I ran the memory test and everything was green. I rebooted with OPTION pressed and it went to self test like it should.  I decided to let it run the self test continuously for a while.
You probably have dirty contacts in the OPTION key switch if it works intermittently.
  • Like 4
I don't think the problem is with the keyboard, I used two different keyboards with similar results. Also, sometimes when I press the OPTION key I get random letters and characters displayed on the screen.
Could be an issue with your GTIA and/or its socket.
Couldn't the problem also possibly be with the socket for the keyboard's ribbon cable?  Maybe loose pins?  Just a thought.
Mine does the same. The OPTION key works fine. Typing BYE works fine, and the computer seems to have no issues. Just won't boot into test mode when pushing OPTION.
Weird. Looking forward to the replies.
Do these machines have an original OS ROM?
When you do get into self test via "BYE" from BASIC, do the start/select/option keys seem a little less responsive in they keyboard test that you would expect? Does pressing one of them generate a solid or intermittent tone?
I tried with an original ROM and one of the dual OS EPROMS. Same results. When I got in with BYE the keys all worked OK for a few tries. I am going to switch out the GTIA and maybe the PIA if nothing shows up there I will run the SALT diagnostic.
I spent a few hours on the weekend restoring this machine, one thing I did was to completely strip back the keyboard and give it a very good clean. All keys are very responsive.
I don't think it's been taken apart before, so I'm assuming the ROM is original.
Edited by nama
As hueyjones70 mentioned. If I first test the memory with 'BYE' then reset out, and then press 'OPTION' it seems to work...go figure????
Edited by nama
I have switched out the large chips and the MMU and the problem persists.  Sometimes when I boot I don't get any noise and sometimes I don't get a ready prompt and on those occasions the computer doesn't respond to any commands.
  • Confused 1
I finally figured out what was wrong, I had installed xx256 memory chips so I could do a Wiztronics memory upgrade and one of the chips was bad.
