Sign in to follow this
Steve Mynott
SD card fallen inside SD2SIO?
I've done something rather stupid and pushed the SD card inside the SD2SIO box itself (not even sure how I did this but it now rattles when I shake it!)
It still works with another card but I was wondering if anyone knew how to open the plastic box (which looks professionally sealed to me) so I can get the card out?
Edited by Steve Mynott
I did this as well - if you take the rubber feet off you can access the screws...!
You are a life saver Bob! Problem solved! The feet even stick back on.
The slot on the case is just tall enough that if you insert the card at a slight angle, it misses the internal slot - which is easy to do!
I actually emailed Lotharek in a panic as I thought (as you did) there was no way to open the case and I was going to have to send it back... lol...
I felt like a bit of a twit when he said you can remove the rubber feet! ;)
I have one built into an XC12 case and managed to push the whole board from its mounts, necessitating a complete disassembly and installation of an extra retaining bracket for the board.
