Simius Posted February 22, 2017 Author Share Posted February 22, 2017 Ely, the brown wire should be connected to pin2, not pin1. You have also make a connection between pin6 DB9 and pin16 SCART. Do it and report a result. Quote Link to comment Share on other sites More sharing options...
Ely Posted February 22, 2017 Share Posted February 22, 2017 Fair enough, thanks for looking. I didn't make this cable, it was one I bought ages ago for other purposes (for which is works fine), so I thought I'd give it a go. I think I'll make one up from scratch in that case. Quote Link to comment Share on other sites More sharing options...
commander Posted February 23, 2017 Share Posted February 23, 2017 Hi Simius, please put 5x Sophia on the List Thanks Quote Link to comment Share on other sites More sharing options...
ivop Posted February 23, 2017 Share Posted February 23, 2017 (edited) Got my cable in the mail today (1:1 DB9) and connected it to my 1084s. Sophia jumper 1 open or closed, jumper 2 open. I can see the blue background and the yellow letters, but it's rolling all over the place. Both horizontally and vertically. It seems there is no hsync/vsync. The housing of the monitor says there should be an RGB TTL/Analog switch, but there's no switch! I'm a little reluctant to open up the monitor to see if the solderpads are there :/ Edit: hmm, the 1084s without a switch should default to RGB analog (for the Amiga) It looks though as somebody dremeled a hole in the back and added the DB9 themselves. The hole looks fuzzy. Perhaps they also shorted the switch to RGB TTL for the C128? Sigh.... guess I have to open it after all or get another monitor. Measured the cable and all pins are connected correctly. Edited February 23, 2017 by ivop Quote Link to comment Share on other sites More sharing options...
Simius Posted February 23, 2017 Author Share Posted February 23, 2017 (edited) No sync because the Sophia board has the CSYNC on pin8, not pin7. HSYNC and VSYNC inputs may need a positive polarity while the Sophia board gives a negative. Edited February 23, 2017 by Simius Quote Link to comment Share on other sites More sharing options...
ivop Posted February 24, 2017 Share Posted February 24, 2017 I see. I went by what you said earlier: I have a Commodore 1084ST monitor.Which cable should I use? 2x DB9 male 1:1 Guess I have to cut the cable then and rewire Quote Link to comment Share on other sites More sharing options...
jvas Posted February 24, 2017 Share Posted February 24, 2017 OK, so what is the final pinout of Sophia? I'm confused now... Quote Link to comment Share on other sites More sharing options...
Simius Posted February 24, 2017 Author Share Posted February 24, 2017 I see. I went by what you said earlier: Guess I have to cut the cable then and rewire I only expected that according to a picture. Pinout of the Sophia DB9 connector is provide in #223 and the schematic diagrams of the cables in #227 Quote Link to comment Share on other sites More sharing options...
ivop Posted February 24, 2017 Share Posted February 24, 2017 Okay, fair enough. I have tried feeding the right signals on the right pins to the 1084S and the problem remains. It might be just my monitor though, so I'll move to my Phillips CM8802, which has a SCART connection. I'll keep you posted. Quote Link to comment Share on other sites More sharing options...
ivop Posted February 24, 2017 Share Posted February 24, 2017 I got DB9-->SCART working on that Phillips CM8802 monitor. Great picture quality! 1 Quote Link to comment Share on other sites More sharing options...
8bitbill Posted February 25, 2017 Share Posted February 25, 2017 ivop - I have been working through the same issues as you with a Commodore 1084s RGB monitor. To get it to work (Sophia to analog RGB on the 1084s) I built a test rig to be able to quickly try different sync combinations and came up with this: Both jumpers are open on the Sophia board FYI. Connected all pins straight through except no connections for pin 1, pin 6, pin 7 on either side. For pin 8 on the Sophia side (Composite sync) I wired it to pin 9 on the 1084s side (Vsync). Pin 9 on the Sophia side (Vsync) and pin 8 on the 1084s side (Hsync) are not connected to anything. Hope the makes sense. The image seems pretty stable and sharp. Seems a little 'swimmy' but my test rig is not as good as a soldered cable I'm guessing. I have to try it for a while. -Bill 1 Quote Link to comment Share on other sites More sharing options...
commander Posted February 25, 2017 Share Posted February 25, 2017 Did somebody have a spare one for me and is willing to sell it ? thanks Quote Link to comment Share on other sites More sharing options...
ivop Posted February 25, 2017 Share Posted February 25, 2017 Connected all pins straight through except no connections for pin 1, pin 6, pin 7 on either side. For pin 8 on the Sophia side (Composite sync) I wired it to pin 9 on the 1084s side (Vsync). Pin 9 on the Sophia side (Vsync) and pin 8 on the 1084s side (Hsync) are not connected to anything. Thanks! I also "breadboarded" the cable and tried all sync combinations and single sync lines, but I kept blanking connected all the time. Guess I could go back and try your suggestion, but I'm pretty content with my current setup, including audio on pin 1, too, which needs a separate connector (or even cable) on the 1084S. BTW I noticed that the Sophia PCB does not fit well in a fully socketed 800XL. It's at a bit of an angle because of the 74LS158 right above it. It only touches the IC housing though, so it doesn't make any shorts. If you add a precision socket to increase the height you can clear the '158, but then it touches the keyboard and the casing won't close properly. For now, I have it plugged in at a slight angle, but I'm thinking about removing the 158's socket. Quote Link to comment Share on other sites More sharing options...
chadwyk Posted February 25, 2017 Share Posted February 25, 2017 I got mine installed in my 5200 last night, however making a cable is out of my expertise. Would someone who knows how to make them sell me a db-9 to scart cable with the audio wired in per Simius' spec? I reached out to retro_console_accessories but I have yet to hear back from them. Quote Link to comment Share on other sites More sharing options...
robbievgb Posted February 25, 2017 Share Posted February 25, 2017 Question / Clarification about the SCART Spec : pins 2 & 7 are GND on DS9 correct? If so then what exactly is "common shield do not short to GND" mean? Is this for the Audio GND signal? What am I NOT supposed to short to GND? Sent from my SM-G920P using Tapatalk Quote Link to comment Share on other sites More sharing options...
Lilralphie Posted February 26, 2017 Share Posted February 26, 2017 I got mine installed in my 5200 last night, however making a cable is out of my expertise. Would someone who knows how to make them sell me a db-9 to scart cable with the audio wired in per Simius' spec? I reached out to retro_console_accessories but I have yet to hear back from them. I messaged her too. Hopefully if others do too the cable will be available soon! Quote Link to comment Share on other sites More sharing options...
Simius Posted February 26, 2017 Author Share Posted February 26, 2017 Question / Clarification about the SCART Spec : pins 2 & 7 are GND on DS9 correct? If so then what exactly is "common shield do not short to GND" mean? Is this for the Audio GND signal? What am I NOT supposed to short to GND? Both pins 2 and 7 on DB9 are GND. Quote Link to comment Share on other sites More sharing options...
funkwad Posted February 28, 2017 Share Posted February 28, 2017 I was hoping to make some progress for an install today, but looks like whoever did this S-Video mod to my unit did some pretty exhaustive work...I was thinking of keeping it in place, but I think I have to remove some of it since they took some of GTIA pins out....need to save the RGB install sometime during next month when I have a full day off. Quote Link to comment Share on other sites More sharing options...
ApolloBoy Posted March 3, 2017 Share Posted March 3, 2017 I got my SOPHIA boards about a week ago and today I was able to find time to install them in my 5200 and 800XL. Very impressed with the picture quality and I'm really happy to have RGB at last for my A8s. There a few things to keep in mind though. First off, the pins on the SOPHIA board are on the short side and will hardly fit in a conventional socket. I had to replace the GTIA sockets in both systems with precision sockets which fit the SOPHIA like a glove. On both systems the SOPHIA board hit the top of another chip (two in the 5200's case), so I had to remove the chips in question, desolder the sockets and then solder the chips directly to the motherboard. You could avoid this on the 5200 by stacking another socket on the SOPHIA but I think you'd run into clearance issues on the 800XL. I also ditched the DB9 connectors and instead soldered on a female 8-pin mini-DIN jack. This wasn't too hard and I avoided having to drill extra holes since both systems previously had S-video mods. However, if you're installing your video connector on the 5200's expansion port panel, you'll need to splice in some extra wires onto the wiring harness as the one included is kind of short. 1 Quote Link to comment Share on other sites More sharing options...
Lilralphie Posted March 3, 2017 Share Posted March 3, 2017 <p> I got my SOPHIA boards about a week ago and today I was able to find time to install them in my 5200 and 800XL. Very impressed with the picture quality and I'm really happy to have RGB at last for my A8s. There a few things to keep in mind though. First off, the pins on the SOPHIA board are on the short side and will hardly fit in a conventional socket. I had to replace the GTIA sockets in both systems with precision sockets which fit the SOPHIA like a glove. On both systems the SOPHIA board hit the top of another chip (two in the 5200's case), so I had to remove the chips in question, desolder the sockets and then solder the chips directly to the motherboard. You could avoid this on the 5200 by stacking another socket on the SOPHIA but I think you'd run into clearance issues on the 800XL. I also ditched the DB9 connectors and instead soldered on a female 8-pin mini-DIN jack. This wasn't too hard and I avoided having to drill extra holes since both systems previously had S-video mods. However, if you're installing your video connector on the 5200's expansion port panel, you'll need to splice in some extra wires onto the wiring harness as the one included is kind of short. Can you post pics of your 5200 install please? I'd like to take a similar approach particularly the 8 pin din. Quote Link to comment Share on other sites More sharing options...
ApolloBoy Posted March 3, 2017 Share Posted March 3, 2017 (edited) Here's an overall view of my install, you can see how I spliced in additional wires since the wiring harness wasn't long enough.This is a closeup of the 8-pin mini-DIN, it follows the same pinout as the mini-DIN on the Framemeister. Yes I know the capacitor on my audio jacks is crudely wired in but that was done many years ago...And here's my very crude layout of the output connector on the SOPHIA board. I left out the blanking signal, vertical sync and the extra ground signal since they weren't needed on my PVM. Edited March 3, 2017 by ApolloBoy 2 Quote Link to comment Share on other sites More sharing options...
commander Posted March 3, 2017 Share Posted March 3, 2017 I missed the first batch of sophia release. Is there a plan to make a 2nd production of sophia thanks Quote Link to comment Share on other sites More sharing options...
TiktaaLink Posted March 3, 2017 Share Posted March 3, 2017 (edited) DB9 to SCART cables are available now from Retro Console Accessories These are simulated stereo like the other mono cables she provides. http://www.ebay.com/itm/162417265303 Edited March 3, 2017 by TiktaaLink Quote Link to comment Share on other sites More sharing options...
robbievgb Posted March 3, 2017 Share Posted March 3, 2017 DB9 to SCART cables are available now from Retro Console Accessories These are simulated stereo like the other mono cables she provides. http://www.ebay.com/itm/162417265303 Thanks for the heads up. I picked up two! 1 Quote Link to comment Share on other sites More sharing options...
+S.D.W. Posted March 4, 2017 Share Posted March 4, 2017 I'd like to pick up one or more of these, will there be another run? If anybody has one they'd like to sell in the meantime, please PM me. Thank you. Quote Link to comment Share on other sites More sharing options...
