aftyde #1 Posted November 22, 2016 Hi All, I'd like to run 4DOS but understand that it requires a supercart. I have lots of parts and a destructive nature - where would I begin??? Quote Share this post Link to post Share on other sites
Shift838 #2 Posted November 22, 2016 (edited) Hi All, I'd like to run 4DOS but understand that it requires a supercart. I have lots of parts and a destructive nature - where would I begin??? I have made a couple using the Fetzner Super Cartridge PCB HERE Easy to assemble. You will need to re-use an editor assembler Grom from an EA cartridge. I know arcadeshopper is out of stock on the PCB's. You can always reference 8k or 4 bank x 8k supercart upgrade HERE I chose the Fetzner path as it was easier for me.. Edited November 22, 2016 by Shift838 Quote Share this post Link to post Share on other sites
+Ksarul #3 Posted November 22, 2016 I do have to order some more of those boards--or you can take the Gerbers that I put up in one of the threads here and make some of your own using Osh Park. Quote Share this post Link to post Share on other sites
+arcadeshopper #4 Posted November 22, 2016 http://www.mainbyte.com/ti99/supercart/supercart.html has the docs for mangling a munchman or ti invaders to a supercart.. mine was hideous but works.. Quote Share this post Link to post Share on other sites
+OLD CS1 #5 Posted November 22, 2016 mine was hideous but works.. Those kinds of projects are always the best. 1 Quote Share this post Link to post Share on other sites
mantadoc #6 Posted November 22, 2016 Could also be good if it was possible to use an eprom with for example Fred Kaals E/A instead of disassembling the original E/A cart , is it possible ? Quote Share this post Link to post Share on other sites
+arcadeshopper #7 Posted November 22, 2016 Could also be good if it was possible to use an eprom with for example Fred Kaals E/A instead of disassembling the original E/A cart , is it possible ? No as the eprom would be the same address as the RAM noposeble thats why a GROM works but a ROM doesn't Greg 1 Quote Share this post Link to post Share on other sites
+arcadeshopper #8 Posted November 22, 2016 Those kinds of projects are always the best. shield your eyes... 4 Quote Share this post Link to post Share on other sites
mantadoc #9 Posted November 22, 2016 No as the eprom would be the same address as the RAM noposeble thats why a GROM works but a ROM doesn't Greg Oh .... ok thanks Quote Share this post Link to post Share on other sites
+arcadeshopper #10 Posted November 22, 2016 I do have to order some more of those boards--or you can take the Gerbers that I put up in one of the threads here and make some of your own using Osh Park. I looked but not finding these do you know which post? Quote Share this post Link to post Share on other sites
