mizapf
New MAME release
Yes, I found the E-mail as well, and actually, nothing has changed in the last 8 years:
Quote
Some years ago when working on the existing code I tried to fix it according to what the mouse driver does. I never had the exact hardware specs, so things may still be different than what we see with the real mouse.
Have a quick look at the comments at the top of the file
http://git.redump.net/mame/tree/src/mess/machine/ti99/mecmouse.c
Edit: This is now https://github.com/mamedev/mame/blob/master/src/devices/bus/ti99/joyport/mecmouse.cpp
So there is a way to confuse the mouse, but I don't know whether and how the real mouse prevents that.
So my problem is not to fix a bug, but that I generally do not understand how to avoid the axis swap. Do you have a real Mechatronics mouse? (or anyone else?)
Edit: I noticed that TI-DOS crashes for the DDCC-1 controller and the BwG controller; it works for the HFDC and the normal TI controller. I saw that a click causes the axis swap, maybe I can do some investigation there. The problem with the mouse is that you actually cannot set anything, as everything is done via the joystick port. The only action you can do is to select stick 1 or stick 2, and by this way, the axes are swapped. If this is not done properly, X and Y remain swapped.
Edited by mizapf
I have one. It didn't do that when it worked, it stopped working a while back
Greg
I'm using bwg. You can see in my video
Sent from my LM-V600 using Tapatalk
Could it depend on single density vs. double density? I'm normally only using double density, of course. But here, I had to prepare another disk for the TI controller with SD.
Now I noticed that the SD works with BwG in TI-DOS, but not the DD.
I seem to remember a weird formatting/copy issue between Myarc and CorComp/BwG controllers BITD. It had nothing to do with the Myarc 16-sector double density--but on disk copies, data appeared corrupted on the other controller. I know this one bit me a few times back when I was still in Germany.
Since I'm almost only using DD, this seems more like an exception. Here, it smells a bit like a bug in TI-DOS. Yet another entry on my list.
Edited by mizapf
Posted (edited)
I just uploaded the recent MAME 0.231 release to WHTech:
https://ftp.whtech.com/emulators/MAME/ti99/linux/mame0231b_ti99_linux64bit.tar.gz
https://ftp.whtech.com/emulators/MAME/ti99/raspbian/mame0231b_ti99_raspbian32bit.tar.gz
https://ftp.whtech.com/emulators/MAME/ti99/windows/mame0231b_ti99_win64bit.zip
https://ftp.whtech.com/emulators/MAME/full/macos/mame0231b_macos64bit.zip
The only interesting change to previous releases is that I changed the default setting of the floppy drive step rate to 6 or 8 ms on all disk controllers (that allow setting the rate). The previous default of 20ms led to a failure on the Corcomp controller, in conjunction with a too short motor-on time. That is, if you had problems with the Corcomp controllers, you should download this release and just copy it over your existing installation.
Edit: Apart from the Corcomp problem, you will also generally notice a slightly faster floppy operation, since the floppy heads move faster now (unless you already chose a shorter step time by yourself).
Edited by mizapf
MAME 231 (and earlier versions) doesn't play nice with my new machine (using an Nvidia graphics card and the proprietary driver) in that starting MAME completely locks up the machine -- I had to log into a virtual console and kill -9 the MAME process.
I saw some error messages about ALSA in the terminal window after killing MAME (not sure if they're responsible for locking up).
Value 1 not supported for option sound - falling back to auto
ALSA lib confmisc.c:767:(parse_card) cannot find card '1'
ALSA lib conf.c:4732:(_snd_config_evaluate) function snd_func_card_driver returned error: No such file or directory
ALSA lib confmisc.c:392:(snd_func_concat) error evaluating strings
ALSA lib conf.c:4732:(_snd_config_evaluate) function snd_func_concat returned error: No such file or directory
ALSA lib confmisc.c:1246:(snd_func_refer) error evaluating name
ALSA lib conf.c:4732:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:5220:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM default
ALSA lib seq_hw.c:466:(snd_seq_hw_open) open /dev/snd/seq failed: Permission denied
Is there a way to reset or even auto-detect the mame.ini file?  Can MAME deal with pulseaudio?  Do I need additional permissions?  (I already added my user to the video group, which seems to be necessary for Nvidia.)
Yes, pulseaudio is now available (-sound pulse). You can delete the mame.ini file and let it be created by -createconfig.
Thanks, that option really helped.  I also deleted my mame.ini.  But now I got this error (after a black screen):
cassiopeia ~ > mame -sound pulse
Error opening translation file English
fpa_connect: Access denied
What is fpa?
By the way, mame -showusage lists the options for command line and mame.ini with valid values. Did you recreate the mame.ini?
As for the translation file, do you have a folder "language" in your MAME home?
I searched the MAME source code, but I cannot find a "fpa_connect". It seems as if this error message is not created inside MAME.
(Hast du eventuell Signal, dann können wir das vielleicht schneller abhandeln?)
Edited by mizapf
Well, funnily enough, if I omit -sound pulse, the error message is gone, and I still have sound.  (So, OF COURSE, the problem is with pulse.)
I re-generated a mame.init file, and everything seems to be working now.  Thanks for your guidance!
