manterola #1 Posted January 10, 2017 Hi everyone. After more than 10 years I have started to use my Atari Computers (800xl and 65xe w/eci). I've been a reader of AtariAge for years... Anyway, I have discovered a bunch of new developments around Atari 8bit stuff, like the updated Contiki for atari8 and a lot of new hardware. I'm looking to get an Sio2Sd and the Dragon Ethernet cart. I already built an SIO2PC which is working perfectly with an rs232 USB adapter in Ubuntu (I just compiled sio2linux). I haven't found any way to get a Dragon Ethernet cart, though. Any suggestion?.. I am also thinking in expand the memory of my 65XE... But there are too many options... Thanks in advance Mauricio Quote Share this post Link to post Share on other sites
+tf_hh #2 Posted January 11, 2017 Hi Mauricio, contact the user "danwinslow" here on AtariAge. Maybe he has one to offer . There are a lot of memory expansions out there. One of the best and most easiest way to built-in is the Ultimate 1 MB. This expansion has 1 MB of extended memory, switchable operating systems, basic-roms, internal SpartaDOS X and a RTC (Real Time Clock). You don´t need to drill holes in your case for switches, it has a BIOS like you know it by modern PCs. And FJC´s new BIOS is a jewel for that - for fee. Most times the chips on an Atari XE mainboard aren´t in sockets, some solder work must be done (removal of MMU, OS-ROM). If you aren´t able to do by you yourself, some users here can help for sure - depending on the area you live. Jurgen Quote Share this post Link to post Share on other sites
manterola #3 Posted January 11, 2017 Thanks Jurgen, I'll look that expansion. I'll also check the internal of my 65XE to see if I have sockets or if I'm lucky to have the 130XE board. Thanks again. Mauricio Quote Share this post Link to post Share on other sites
