SainT
NeoGeo Pocket Colour Flash Cartridge
Jay Cee has done this very cool box art if anyone wanted to put their NGPSD in a case!
I like that, now only if I had a case that would fit the thing...have a spare DS case but pretty sure it would just rattle around in there.
I keep my NGPC games in the Shadowfox cases that were designed for GB/GBC/GBA. Off the top of my head, I can't remember how tight they are in the case, but I can take a picture later tonight. Those same cases also hold Lynx games really well. I also use them for Game Gear, but the case requires a little modification in order for those to fit.
What kind of cases is that sized for? The spine looks a little bigger than a DS sized case (which is what I'm used to using).
I haven't downloaded it to be sure but I imagine it's sized for a NGP clamshell case.
Looks like it's for a NGP snapcase. Packaging varies quite a bit, but many Japanese NGP releases came in a very sturdy hard plastic case with the art as an insert.
Those are nice. At this point, I feel like I'm pretty committed to the cases I'm using, but I would consider switching over if I ever got my hands on some.
Looks nice. I could see depending on cost buying one, but not for the 18-20 games I have that are all loose. I like the space savings plus the little plastic snap case works.
These are the official hard cases from snk. I've never seen a source for just those but you can find them when buying some non US games on eBay and such...usually at a premium, especially for the few English games that I think had them at one point.
Oh I know of those my original NGPC collection I somehow ended up with a UK version of a couple games like Neo Turf Masters.
Is that the white label one?
I don't think it was. I have the US version loose now, it's white label with the US golfer on the front. The EU version is green with no character. Same with Japan but it's obviously BIG Tournament Golf there.
Awesome. I just bought the cheaper one. No idea how a EU cart got to the US, but doesn't bother me which one I have, so I guess I lucked out.
Quick heads up. The ROM for Delta Warp in the MAME/MESS romset doesn't work right. It gives a save error after the first level.
I dumped my copy, and that works fine. So it's a bad dump. The MAME dump is .5m, while the real cart is 1m, so I think the second half is empty, and someone trimmed them off. But, saves go there & because the SD cart sees a 512k image, you can't write in that area.
Just thought folks would like to know.
Yeah we found this during testing. All dumped roms I had were the same way which I thought was odd... Even the NoIntro rom and the so called good dump in the good set. I didn't have a physical copy to dump but it's good to know that it should dump properly.
The fix is to pad the rom out to 1mb which 'restores' the save area on the rom and resolves the issue.
How could the original 'Delta Warp (J) [!].ngc' ROM (from GoodNGPx v3.27 Romset) be padded to 1024 KB? Any recommended utility to perform this task?
Thanks so much!
Edited by Sceptre_JLRB
Yeah, I was playtesting Delta Warp and found the issue, as said, because all the dumps were only 512k in size. You can easily make a 512k game into 1MB by going to a command prompt and typing:
COPY /B FILE1.BIN+FILE1.BIN FILE2.BIN
Oh, that's true! I forgot using that old MS-DOS command line...
It works! Now it only remains to receive my Neo-Geo Pocket SD to test it the proper way.
Thank you very much, @Mayhem ! :-)
