missumj #1 Posted February 7, 2017 I pressed right button here but didn't works. But according to the walkthrough video, what I did is right. drglar.bmp Quote Share this post Link to post Share on other sites
jblenkle #2 Posted February 7, 2017 Timing is everything in this game...keep trying. I pressed right button here but didn't works. But according to the walkthrough video, what I did is right. drglar.bmp Quote Share this post Link to post Share on other sites
Pixelboy #3 Posted February 7, 2017 I pressed right button here but didn't works. But according to the walkthrough video, what I did is right. drglar.bmp If I'm interpreting the screenshot correctly, you're talking about when the head comes off the statue? You're supposed to move the joystick to the right (to make Dirk get out of the way), not press the right fire button. Quote Share this post Link to post Share on other sites
missumj #4 Posted February 9, 2017 If I'm interpreting the screenshot correctly, you're talking about when the head comes off the statue? You're supposed to move the joystick to the right (to make Dirk get out of the way), not press the right fire button. Thank you. Everything is well on the CoolCV emulator. Seems that this only happens on the DOS Adamem emulator. (I always get stuck on the options menu of game when I using it) Quote Share this post Link to post Share on other sites
jblenkle #5 Posted February 9, 2017 You may need to hit F9 to toggle between joystick & keyboard mode. Thank you. Everything is well on the CoolCV emulator. Seems that this only happens on the DOS Adamem emulator. (I always get stuck on the options menu of game when I using it) Quote Share this post Link to post Share on other sites
