TXG/MNX #1 Posted February 8, 2017 (edited) Hi, I got an issue when I save a bmp as 8-bit and load without clut it looks the same in vj as my created graphics. But now I did save the same picture with 16 colors, tested it afterwards in xnview en paint from windows the picture looks good but VJ does display it not the same. Anyone knows what issue this is ? The attached demo.bmp is 4-bit color. I got this set in RB+ ========================= Sprite info dc.l 1 ; (REPEAT COUNTER) ; Create this many objects of this type (or 1 for a single object) dc.l is_active ; sprite_active ; sprite active flag dc.w 0,0 ; sprite_x ; 16.16 x value to position at dc.w 0,0 ; sprite_y ; 16.16 y value to position at dc.w 0,0 ; sprite_xadd ; 16.16 x addition for sprite movement dc.w 0,0 ; sprite_yadd ; 16.16 y addition for sprite movement dc.l 320 ; sprite_width ; width of sprite (in pixels) dc.l 112 ; sprite_height ; height of sprite (in pixels) dc.l is_normal ; sprite_flip ; flag for mirroring data left<>right dc.l 0 ; sprite_coffx ; x offset from center for collision box center dc.l 0 ; sprite_coffy ; y offset from center for collision box center dc.l 320/2 ; sprite_hbox ; width of collision box dc.l 112/2 ; sprite_vbox ; height of collision box dc.l BMP_water ; sprite_gfxbase ; start of bitmap data dc.l 4 ; (BIT DEPTH) ; bitmap depth (1/2/4/8/16/24) dc.l is_RGB ; (CRY/RGB) ; bitmap GFX type dc.l is_trans ; (TRANSPARENCY) ; bitmap TRANS flag dc.l 320*112/2 ; sprite_framesz ; size per frame in bytes of sprite data dc.l 320/2 ; sprite_bytewid ; width in bytes of one line of sprite data dc.l 0 ; sprite_animspd ; frame delay between animation changes dc.l 0 ; sprite_maxframe ; number of frames in animation chain dc.l ani_rept ; sprite_animloop ; repeat or play once dc.l edge_wrap ; sprite_wrap ; wrap on screen exit, or remove dc.l spr_inf ; sprite_timer ; frames sprite is active for (or spr_inf) dc.l spr_linear ; sprite_track ; use 16.16 xadd/yadd or point to 16.16 x/y table dc.l 0 ; sprite_tracktop ; pointer to loop point in track table (if used) dc.l spr_unscale ; sprite_scaled ; flag for scaleable object dc.l %00100000 ; sprite_scale_x ; x scale factor (if scaled) dc.l %00100000 ; sprite_scale_y ; y scale factor (if scaled) dc.l -1 ; sprite_was_hit ; initially flagged as not hit dc.l 1 ; sprite_CLUT ; no_CLUT (8/16/24 bit) or CLUT (1/2/4 bit) dc.l can_hit ; sprite_colchk ; if sprite can collide with another dc.l cd_keep ; sprite_remhit ; flag to remove (or keep) on collision dc.l single ; sprite_bboxlink ; single for normal bounding box, else pointer to table dc.l 1 ; sprite_hitpoint ; Hitpoints before death dc.l 2 ; sprite_damage ; Hitpoints deducted from target dc.l 320/2 ; sprite_gwidth ; GFX width (of data) Build.info Reading assets.txt line Processing ASSETS\GFX\demo.bmp Converting BMP internally into gfxdata/clut... File is 320 pixels wide, 112 pixels high and is 4 bits/pixel Asset info abs,BMP_water,gfx_clut,ASSETS\GFX\demo.bmp In main code loadclut(strptr(BMP_water_clut),1,16) demo.bmp Edited February 8, 2017 by TXG/MNX Quote Share this post Link to post Share on other sites
sh3-rg #2 Posted February 8, 2017 (edited) Your image looks weird above (corrupt palette as shown in chrome browser) but loads into psp8 fine and displays as a thumb in win7 fine. I resaved using psp8 and the header is very slightly different - this could be causing some sort of conversion problem. What tool are you using to create your 16 colour images? Some tools botch palette-based files. Here is the same image re-saved with psp8: demo2.bmp Edited February 8, 2017 by sh3-rg Quote Share this post Link to post Share on other sites
TXG/MNX #3 Posted February 8, 2017 I used paint.net with the lowcolor.plugin or maybe there is new pluging will look for it. I will test your bmp later this evening when I am using my dev laptop. I don't have psp anymore had it in the old days, seems I need to find the cd again. Quote Share this post Link to post Share on other sites
WAVE 1 GAMES #4 Posted February 8, 2017 (edited) try deleting this line dc.l 320*112/2 ; sprite_framesz ; size per frame in bytes of sprite data Also make sure you have it set to clut 1 in the LOADCLUT list in the .bas file then go in the build folder delete the water.bmp.gfxdata and water.bmp.clut files and build again Edited February 8, 2017 by Jeffrey_Bones Quote Share this post Link to post Share on other sites
TXG/MNX #5 Posted February 8, 2017 I did try everything but the demo2.bmp no success it doesnot look the sane, On windows on every program the bmp lookw good :-( Quote Share this post Link to post Share on other sites
sh3-rg #6 Posted February 8, 2017 (edited) Show some photos of what you see and what you expect. It's not really important that your other tools display the image correctly - the one that does the conversion is the one that counts. Also delete the whole build folder and contents and build again. Do some sanity checking, write the word "arse" over your image and prove that it's displaying the one you have saved. If so and it still looks wrong, your code is to blame. Are you using some 256 colour object or overwriting and killing the CLUT with that data afterwards are you? There could be all kinds of reasons for not seeing what you expect. ps Don't randomly delete lines from rapinit.s, that's nuts. Edited February 8, 2017 by sh3-rg 1 Quote Share this post Link to post Share on other sites
ggn #7 Posted February 8, 2017 I took a look at the headers of both files, and it seems like the field that specifies number of colours is zero in txg's bitmap. At least if I counted right (reference: https://en.wikipedia.org/wiki/BMP_file_format).So it probably does bad things. If you want a free and (from our experiments, working) program that can write 16 colour bmp files try xnview. 2 Quote Share this post Link to post Share on other sites
+CyranoJ #8 Posted February 8, 2017 try deleting this line dc.l 320*112/2 ; sprite_framesz ; size per frame in bytes of sprite data Don't EVER delete lines from _rapinit.s 1 Quote Share this post Link to post Share on other sites
omf #9 Posted February 8, 2017 Don't EVER delete lines from _rapinit.s rainbow! Quote Share this post Link to post Share on other sites
TXG/MNX #10 Posted February 9, 2017 I took a look at the headers of both files, and it seems like the field that specifies number of colours is zero in txg's bitmap. At least if I counted right (reference: https://en.wikipedia.org/wiki/BMP_file_format).So it probably does bad things. If you want a free and (from our experiments, working) program that can write 16 colour bmp files try xnview. Hi, After trying several programs (paint, paint.net, psp I did manage to export the picture with xnview and it displays fine now in 4-bit I only used the save function within xnview but found out that the export function did allow me to export 4-bit with or without transparancy. The exported file does display correct just like I see it in any program. Thanx for the help, I was lost by the fact that paint.net/paint/psp 8 did load and save the file and did preview fine. The properties from the file in windows did show also 4 colors. Quote Share this post Link to post Share on other sites
VladR #11 Posted February 9, 2017 Or, instead of banging your head against the wall as other tools don't do what you want, you could do what I did and spend one hour in VisualStudio.NET and write a simple function that will load the image (using MSDN .NET library) and alter/sort/adjust the palette exactly the way you want before exporting. Literally less than one screen of code. Only then you're going to have 100% consistency, not dependent on order of actions in given gfx program. Not even the old PaintShopPro 6 is 100% consistent. Keep it running for a while, load few hundred bitmaps, and it will mess your exports now and then. Quote Share this post Link to post Share on other sites
sh3-rg #12 Posted February 9, 2017 Thanx for the help, I was lost by the fact that paint.net/paint/psp 8 did load and save the file and did preview fine. The properties from the file in windows did show also 4 colors. I've only ever used PSP6 and PSP 8 to create gfx assets for rb+ and neither have ever produced a broken image. The tool chain works, but as always: GIGO. That image Iposted should have worked - the header in your original file was broken as I said. If you didn't delete your whole build folder, it could easily have missed the new image and not converted it, instead used the existing .gfxdata file and palette file and just build the same broken stuff as before. When you get issues like these, deleting the build folder is step 1 on the path to finding wtf is going wrong. As for writing your own tool to manage image conversion as suggested above... irrelevant, no place here. If you're the sort of person who writes your own tools, wtf are you doing making games in BASIC or wasting time reading threads about them? 1 Quote Share this post Link to post Share on other sites
+Sporadic #13 Posted February 9, 2017 I use psp7 with zero issues. Reinvent the wheel? No thanks lol 2 Quote Share this post Link to post Share on other sites
