lucifershalo #1 Posted February 9, 2017 Would love to have a collection of Starpath carts Is it possible to convert the roms to make them work on carts? thanks Quote Share this post Link to post Share on other sites
+SpiceWare #2 Posted February 9, 2017 The Harmony Cart runs the Supercharger games as is, no conversion needed. As such carts could be made using the Melody board. 3 Quote Share this post Link to post Share on other sites
Dr Manhattan #3 Posted February 10, 2017 This has always been a dream of mine as well. I know the Harmony cart can run all these games, but I've always liked the idea of having them in cartridge form. It would be especially cool if the labels used some of the original box art. There's just something so unique about the whole Starpath library. 1 Quote Share this post Link to post Share on other sites
Keatah #4 Posted February 10, 2017 Does the Supercharger provide any other function/circuitry beyond the additional RAM? 1 Quote Share this post Link to post Share on other sites
+iesposta #5 Posted February 10, 2017 I wanted Suicide Mission Prototype that was hacked into black and white, called Meteroids Black: But then Space Rocks happened! 1 Quote Share this post Link to post Share on other sites
+iesposta #6 Posted February 10, 2017 Does the Supercharger provide any other function/circuitry beyond the additional RAM? I would say no, just 3 2K RAM banks and a 2K ROM that handles the Press Play display and the analog to digital loading. Quote Share this post Link to post Share on other sites
SoundGammon #7 Posted February 10, 2017 I've always thought Supercharger games could be put on carts since carts have way more memory now than they did then! Also extra ram chips if needed! Quote Share this post Link to post Share on other sites
Mr SQL #8 Posted February 10, 2017 Does the Supercharger provide any other function/circuitry beyond the additional RAM? Yes, the SuperCharger provides a GUI operating system with screensavers and a built in help system. And games can call the SuperCharger OS functions to load more data or other games. Quote Share this post Link to post Share on other sites
+KaeruYojimbo #9 Posted February 10, 2017 It would be especially cool if the labels used some of the original box art. And if the end labels looked like the cassette spines. 1 Quote Share this post Link to post Share on other sites
+SpiceWare #10 Posted February 10, 2017 I've always thought Supercharger games could be put on carts since carts have way more memory now than they did then! Also extra ram chips if needed! The way Superchargers RAM is accessed is quite a bit more complicated than the other RAM formats used in 2600 games. The usual method involves having the RAM appear twice in memory, one range of addresses for reading and another range for writing. The Supercharger uses a control register and multiple instructions to update RAM. From Eric Ball's series SuperCharger jumpstart 1/2 and SuperCharger jumpstart 2/2: Hopefully this will help those people interested in creating a SuperCharger homebrew for Glenn's contest. Part 2 will be about the SC header (but first I have to re-learn it myself.) The SuperCharger contains 6K of RAM organized as three 2K banks. These three banks (and the 2K internal ROM) can be mapped in various combinations into the 4K cartridge address space ($1000-$1FF8) via the SuperCharger control register. (Note: Since the 6507 inside the 2600 only has 12 address lines, $1000 is equivalent to $F000.) The SuperCharger control register also controls whether write mode is enabled. Once write mode is enabled, any RAM mapped to the the cartridge address space may be written to. Unfortunately, since the 2600 cartridge slot doesn't have the necessary control signals to allow direct writes (e.g. STA) to work, writes to the SuperCharger RAM require multiple reads to implement a write. First the program generates an access to address $10xx to select the value to write. This value is then written to the fifth address bus value after the $10xx access. For example CMP $1000 CMP (PTR), Y stores $00 in the address pointed to by (PTR),Y CMP $1000,Y NOP CMP BASE,X stores the value in Y into the address BASE+X (i.e. POKE BASE+X,Y), the NOP is to generate an additional address cycle. It's very important not to store code or data which will be accessed while write mode is enabled at $10xx, since it will generate spurrious writes. So to convert a Supercharger game to one that uses one of the available cartridge formats with RAM would require finding all of those sections of code and rewriting them. Another potential problem is because the Supercharger games are loaded into RAM they can use self-modifying code - that'd be difficult to do with the game code burned onto a ROM chip. 1 Quote Share this post Link to post Share on other sites
Mr SQL #11 Posted February 10, 2017 Self-modifying code is rare, but because any memory structure can be treated as static RAM, tables that would normally be ROM only can be leveraged as RAM arrays. There is a new RAM based BASIC for the SuperCharger where unlimited array variables are made possible by this feature. Here's an awesome SuperCharger RPG demo from Papa with detailed descriptions of vwBASIC's features. I've been working on a version of vwBASIC for the Atari Portable using CBS RAM (extra 256 bytes of RAM) but unlimited array variables are one of the features that had to be dropped because they are not possible with other memory schemes. Quote Share this post Link to post Share on other sites
+SpiceWare #12 Posted February 10, 2017 Another potential problem is because the Supercharger games are loaded into RAM they can use self-modifying code - that'd be difficult to do with the game code burned onto a ROM chip. After writing that I was curious if they did use it or not, so started to look for Supercharger disassemblies. Couldn't find any online, but then remembered I have a Stella Gets a New Brain! CD - it has data along with all the audio tracks of Supercharger games. Popped it in and there's final source for 3 Supercharger programs(and pre-release code for a few other games). I took a quick look at the finished games - did not spot any self modifying code in Suicide Mission, but did in the other two! From Communist Mutants from Space: PSCOR0 TAX <--- score kernel LDA #6 STA P2CONT DIG6 LDA DA,X <--- DA overwritten by ??? (update - see next reply) STA P2 DIG1 LDA DA,X <--- DA overwritten by code below STA P1 LDY #3 DIG2 LDA DA,X <--- DA overwritten by code below STY P2CONT STA P2 DIG3 LDA DA,X <--- DA overwritten by code below STA P1 DIG4 LDY DA,X <--- DA overwritten by code below DIG5 LDA DA,X <--- DA overwritten by code below TAX PLA STY ABS+P2 STX P1 STA P2 STA P1 TSX TXA EOR #$DF BNE PSCOR0 ... UPDSCR LDX #DA <--- UPDSCR = update score, back then the compilers didn't support long labels LDA SC3 JSR DIG CMP RAM+$FF,Y CMP DIG1+1 ; R <--- replaces one of the DA above LDA SC2 JSR HIDIG CMP RAM+$FF,Y CMP DIG2+1 ; R <--- replaces one of the DA above LDA SC2 JSR DIG CMP RAM+$FF,Y CMP DIG3+1 ; R <--- replaces one of the DA above LDA SC1 JSR HIDIG CMP RAM+$FF,Y CMP DIG4+1 ; R <--- replaces one of the DA above LDA SC1 JSR DIG CMP RAM+$FF,Y CMP DIG5+1 ; R <--- replaces one of the DA above RTS The <--- denote my comments. The first bit of code is the 6 digit kernel, they used the constants P0 and P1 for the players instead of GRP0 and GRP1. The second bit of code modifies the digits to be displayed. This programmer used ; R to denote when RAM was written to. From Frogger: FLASHROW CMP RAM+$FF,Y CMP FR.2+1 ; WR <--- replaces ROW1 below LDY VVL,X CMP RAM+$FF,Y CMP FR.0+1 ; WR <--- replaces R1VAL below LDX SAVE+2 * FR.0 LDY R1VAL,X ; <--- R1VAL changed by the code above FR.2 LDA ROW1,X ; <--- ROW1 changed by the code above CMP RAM,Y TAY FR.9 CMP $FF00,Y ; WR DEX BPL FR.0 * RTS This programmer used ; WR to denote when RAM was written to. The programmer for Suicide Mission used ; RAM! 2 Quote Share this post Link to post Share on other sites
+SpiceWare #13 Posted February 10, 2017 Was wondering why the score routine in Communist Mutants only updated 5 of the digits so took a look in Stella: They have the 6 digit display aligned so the last copy of player 1 wraps around to the left side of the screen (using mid-screen changes to NUSIZ1) for use as the current player indicator. It's modified by this bit of code: LDY PLYRUP <--- player up INY TYA JSR DIG CMP RAM+$FF,Y CMP DIG6+1 ; R 1 Quote Share this post Link to post Share on other sites
AtariLeaf #14 Posted February 11, 2017 But then Space Rocks happened! 5 Quote Share this post Link to post Share on other sites
+Psionic #15 Posted February 11, 2017 CPUWIZ did a small run of Rabbit Transit cartridges several years back, although they were actually based on an Atari prototype version that was slightly different from the Starpath released version. I don't know if he has any left, or if he's in any position to make more (based on his current health situation) but I suppose you can ask him. Quote Share this post Link to post Share on other sites
Mayhem #16 Posted February 12, 2017 Yeah, I was going to mention that there's a couple of Starpath prototype games found on cartridge, so it must have been possible back at the time. On that note Pingvin, any movement on Tac-Scan? 1 Quote Share this post Link to post Share on other sites
AtariLeaf #17 Posted February 12, 2017 The Atariage store has an option where you send in the rom and artwork and Al will produce the cart. Couldn't this be done with Supercharger roms? Quote Share this post Link to post Share on other sites
maiki #18 Posted February 12, 2017 I noticed that those Supercharger games like Frogger have some sort of opening sequence in Stella (vertical borders closing) that does not happen on Harmony (I think). What exactly is that supposed to be? An illusion of tape loading? Quote Share this post Link to post Share on other sites
Thomas Jentzsch #19 Posted February 12, 2017 (edited) What exactly is that supposed to be? An illusion of tape loading? Yup. But you can disable that in Stella (Video Settings/Fast SC/AR BIOS). Edited February 12, 2017 by Thomas Jentzsch Quote Share this post Link to post Share on other sites
Frostbite Bailey #20 Posted February 14, 2017 I have Rabbit Transit proto in cartridge form...Does anyone know any other Starpath titles that are protos in cartridge form? Thanks, FB Quote Share this post Link to post Share on other sites
+Gemintronic #21 Posted February 14, 2017 To do SuperCharger games directly the Melody boards would have to have at least 6k of RAM, right? I've always had to limit myself to not using SARA RAM as everyone always had to scavenge for the chips. Is this no longer an issue? Quote Share this post Link to post Share on other sites
Thomas Jentzsch #22 Posted February 14, 2017 To do SuperCharger games directly the Melody boards would have to have at least 6k of RAM, right? I've always had to limit myself to not using SARA RAM as everyone always had to scavenge for the chips. Is this no longer an issue? Nope. The ARM based boards can emulate SARA RAM. 1 Quote Share this post Link to post Share on other sites
+SpiceWare #23 Posted February 14, 2017 To do SuperCharger games directly the Melody boards would have to have at least 6k of RAM, right? There's 8K of RAM in the Harmony/Melody. For DPC+ and BUS the Harmony/Melody driver gets loaded into RAM for performance reasons so the games only get to use 5K and 6K of RAM respectively. I cover that for DPC+ in this blog entry. I'm sure that RAM's used by all the other bankswitch drivers as well, though I don't know the specifics. The Melody can be upgraded to 64K. 1 Quote Share this post Link to post Share on other sites
