mozzwald
SIO Wifi modem with esp8266
I made a first beta pcb...
I still believe I'm right with
the mirrored plug, we'll see.
Housing is being printed now.
I will attach an mini OLED
display for displaying the
connection status.
But first of all, I'll test
the circuit board.
Stefan
connection status.
the circuit board.
Stefan
Can't wait to see how it goes. Do keep us informed. ;-)
It looks great, Stefan!
I also did mine, I am little embarrassed to show my very amateur job, but I'll post a picture later, anyway.
I been having some problems, that I didn't have in the protoboard (breadboard): it works for a few minutes, and then I got "error" , "error" , "error" all over the terminal screen. When I connect to the esp-01 with linux minicom, it works perfectly. So it is the voltage, the adapter (level 3.3v 5v adapter), I don't know yet. I'll compile and update the Zimodem firmware, and try again to see if it makes any difference.
Good luck with yours.
Mauricio
Edited by manterola
Thanks for the wishes :-)
Of course I tell you the rest of the story.
@ Star Raider: I've tested mine with a nodeMCU.(esp-E12 chip).
I know I operate the chip outside of its specifications,
but it is '5V tolerant' (in the sense of it does not
explode ;-). But you can spare the level shifter.
What kind of shifter do you use?
Is it I2C (bus) compatible?
Stefan
I am using a very cheap adapter. So no idea if it is I2C, but I guess NO. I suspect it has something to do with my problems, even though it looks it is working fine because I keep getting all those "ERROR" strings correctly in BobTerm and IceTerm.
It is very convenient, as well. As you can see, you take the esp01 module and put it on top of the adapter, and then you have a 4 pin header with TX(5v), RX(5v), GND, +5V. That's it.
In the software side I have tried using the "AT" default firmware, and a precompiled Zimodem firmware. I plan to compile my own zimodem (using arduino ide), and try again, since this zimodem firmware is very nice and convenient. I have not tried nodemcu, yet.
Don't worry, cheap doesn't mean bad.
I think I spotted two (smd) Mosfet.
Behind the voltage regulator.
It should do the job.
The nodeMCUs has a lot more I/Os.
(not necessary for the Atari, but useful
for C64 with a 9600 baud hack)
My son successfully completed his 'Abitur'
(A-level) and this weekend the graduation
party takes place. I don't think, I'm able
to thinker around ;-)
Stefan
Hello manterola
That typo on the blue PCB, is that yours? :D
Sincerely
Mathy
Doesn't work for the moment...
Daisychained it with a SIO2SD
at the end of the line. The
SD2IEC device is resetting
randomly because of voltage
swing (or drop).
I'll cut off the NodeMcu and
test it again.
If the Sio2Sd works then,
I have to add a separate
power supply. Otherwise my
circuit is faulty.
Stefan
sio2sd is notorious power issue device, mine never worked properly till I made new sio cable using good gauge wires and connectors, add another SIO device without a strong power supply feeding the Atari and it sio2sd may frown on you again...
Thank you for the suggestion.
I suspect the NodeMcu (and the cable) however.
It is known, the NodeMcu may draw a peak
of 230mA. I tested this by myself during
a different project with a (high precision) 0.1 Ohm
resistor and an Oszilloskope.
But you are right. It's not a big deal to
test a different atari drive first.
Stefan
Update,
I used a separate power supply to serve the NodeMcu.
And... what a surprise, the Sio2Sd (second in the daisychain)
runs fine without any issues.
So fare, so good.
I'm searching for the correct driver however.
(And I forgot the baud rate of the WiFi modem)
Stefan
This is what I did. I also got the PCB with typo.
Manterola, would you be so kind to
send me the rverter handler you' re
using?
I tested the Esp Chip (PC) , it works fine with
2400 baud, but it is not working on the Atari.
Depeding on the driver,
with different behaviors.
So, if I had the right driver/handler,
I could exclude it from my list of
possibly problems.
Stefan
Edited by Stefan Both
Great! ;-)
Do you have a final schematic?
I know you had indicated you had used an additional power source for the NodeMCU. Is that going to be a generic need? Or only for SIO2SD use?
Great! ;-)
Err... Yes. I promise, I'll upload an PDF.
(I did the pcb the old-school way)
I will change the firmware too, because
of the... you know... its a C64 firmware...
and the OLed I'd like to use too... and...
Stefan
I forgot to answer the question...
I did the separate PSU because of the ESP8266
chip itself.
Were you able to resolve the problems you were having?
I did fix the problem with Zimodem, in which I could not save the Wifi configuration and baud rate (it is a known problem with newest esp-01 versions). I changed a file in the esp8266 support files and recomplied Zimodem from the sources. The problem with the Error messages with the original firmware and the "resets" in Zimodem persisted. The device worked for about 15 minutes, though.
I guess (just like Stefan) I am having a problem with the power supply, or at least that's the easiest next thing to check.
I have a good power supply for the computer, but the SIO c or PCB cables may be too thin. I'll "reinforce" the 5V with an independent PS for the esp-01.
If it work, my next project will be to put the esp-01 inside my new 1030 modem (the modem is a little beaten, so I need to retr0bright it and retouch with silver paint the front letters "ATARI 1030". It is a difficult case since it is OK in one side, but extremely yellow in the other side and a not very nice transition from YELLOW to less yellow on the top).
The idea is to use the matching XL case, SIO pass-thru connectors, power switch and LEDs to create "a more vintage experience". The 1030 modem needs a power supply anyways, and it has the connector, so it should be a problem adding one (not like xm301 modem).
So that is my status...
Came across this today...
ALL ELECTRONICS
WiFi MODULE - ESP8266
CAT # ESP-8266
$5.35 each
Not much more than ordering from China, and probably a lot quicker delivery here in the states.
ALL ELECTRONICS
WiFi MODULE - ESP8266...
Yes, I got mine from Amazon. Ordered 5 pcs last year.
Appart from my (our) hobby, I use it with Easy-ESP
for Home Automation. But be careful! 3.3V only!!!
Stefan
