eegad #1 Posted February 26, 2017 I've found a few cheat files / trainers for Atari 8-bit games. (http://atari.panprase.cz/?action=trainery&pismeno=vse has a bunch for instance). There are a few games I'd love to find cheats/trainers for (because I can't finish them!!!), but have so far not been successful. Was wondering if anyone out there happens to have any of these : - Shamus - Necromancer - Sea Dragon - Pharoah's Curse (yes, I know the level select code...I would like unlimited lives) - Astrochase - Laser Gates - Spelunker Much thanks in advance for any help. 1 Quote Share this post Link to post Share on other sites
Mclaneinc #2 Posted February 26, 2017 How are you going to play these, on Altirra? I can help if that is the case... 1 Quote Share this post Link to post Share on other sites
+toddtmw #3 Posted February 26, 2017 I'd love a Shamus cheat on Altria! Todd Quote Share this post Link to post Share on other sites
Mclaneinc #4 Posted February 26, 2017 Well here they are for Altirra, 3 I've just done now and others from previous Atari800win cheats (I probably did those as well?) Necromancer is a bit tricky because the numbers advance you from level to level, will work on it.. All work with atr versions of games, didn't use packed versions for possible memory differences.. Just go to Altirra after the game is loaded and the cheat option on toolbar, and load in the cheat, make sure there's a value / address in the right hand box (if not double click on the one in the left window) and make sure its ticked to activate.. cheats.zip Quote Share this post Link to post Share on other sites
Mclaneinc #5 Posted February 26, 2017 Ok, a Necromancer seeds cheat...Don't want to make it too easy.. rename the file minus the .txt, added it to make it easy to post here.. Necromancer seeds.atcheats.txt Quote Share this post Link to post Share on other sites
+toddtmw #6 Posted February 26, 2017 Awesome. I'm playing Shamus now and I have more lives than I know what to do with. Thanks! Quote Share this post Link to post Share on other sites
eegad #7 Posted February 26, 2017 Mclaneinc - thanks for those cheats. I was actually looking for hacked files to play on a real Atari via Maxflash cart. But you've been a big help in finding the relevant addresses. I just loaded your Shamus cheat in Altirra, found the address $0202, then used a hex editor to search the Shamus file for 8D 02 02, which would be a "store accumulator" at that address (thankfully I still remember a little bit of assembly). Found it, along with a "load accumulator" command with value of $04 before it. I changed the $04 to $FF, saved the file, and here is the result - a hacked Shamus .xex with 256 lives. When I get time I'll try to incorporate the rest of your cheats into these games. Shamus (cheat).xex 1 Quote Share this post Link to post Share on other sites
Mclaneinc #8 Posted February 27, 2017 (edited) Glad its helped you, a bit of good news for tonight... All addresses should be totally relevant to real hardware so handy to have as a bit of assembly searching like you have done.. Oh and thanks really go to Phaeron for adding the cheat function I asked for, I'd done the same thing via Omnimon all those years ago but saved only a few of the creations I made.. Edited February 27, 2017 by Mclaneinc Quote Share this post Link to post Share on other sites
eegad #9 Posted February 27, 2017 Cracked one more, for anyone else interested. Pharaohs Curse, with unlimited lives. Pharoahs Curse (cheat).xex 2 Quote Share this post Link to post Share on other sites
Sikor #10 Posted February 27, 2017 look at atarionline.pl: http://atarionline.pl/v01/index.php?ct=katalog Quote Share this post Link to post Share on other sites
eegad #11 Posted February 28, 2017 Astro Chase with 95 lives. Astro Chase (cheat).xex 2 Quote Share this post Link to post Share on other sites
eegad #12 Posted February 28, 2017 All addresses should be totally relevant to real hardware Yes. But some .xex have been compressed from disk/cassette images and have 'loaders', so you can't just search through the file normally. Having trouble with Sea Dragon. Working on it. Quote Share this post Link to post Share on other sites
Mclaneinc #13 Posted March 1, 2017 It was part of the reason I didn't use such files in the first place but more for the fact of hitting relocated code. Quote Share this post Link to post Share on other sites
eegad #14 Posted March 1, 2017 Sea Dragon with infinite lives and unlimited air. Sea Dragon (cheat).xex 1 Quote Share this post Link to post Share on other sites
Mclaneinc #15 Posted March 2, 2017 Nicely done... Quote Share this post Link to post Share on other sites
eegad #16 Posted March 3, 2017 Laser Gates cheat. Shields will not be diminished by enemy ships, nor slamming through stationary walls. Contact with the shimmering "laser gates" will however drain the shields, so you do at least need to move around a little bit to not die. :-) And I'm pretty much giving up on Necromancer. I could do the seed cheat, but really, I never have a problem getting through the first of the 3 phases. What I really want is to have Strength to not drain during phases 2 and 3. And I can do that.....in Altirra. The problem is that you need to have strength drain in order to complete phase 1, so if I just hack the file to not ever drain strength you are stuck forever in phase 1. In Altirra, you can just play through phase 1 and then enable a cheat to put $05 into $5069 at the start of phase 2....that'll let you just walk through phases 2 & 3 to the ending. Oh well. At least I finally DID get to see the ending in Altirra, after 30+ years. Laser Gates (cheat).xex 1 Quote Share this post Link to post Share on other sites
eegad #17 Posted March 5, 2017 I took another crack at Necromancer from a different angle. Result is a version where you play through the first phase (planting trees) normally. In the second phase, the arms grabbing down from the ceiling cannot grab you or your trees. Hatched spiders can kill your trees, but will actually INCREASE your strength if they touch you (an odd side effect of what I was trying to do). In the third phase, you can mostly just walk through it....sometimes you lose a little strength, but not much. Also, another cheat version for Sea Dragon. Infinite lives, infinite air, and full invinceability. Necromancer (cheat).xex Sea Dragon (cheat2).xex Quote Share this post Link to post Share on other sites
eegad #18 Posted March 15, 2017 Fort Apocalypse with unlimited lives and fuel. Fort Apocalypse (cheat).xex 1 Quote Share this post Link to post Share on other sites
bradhig1 #19 Posted September 17, 2017 aztec challenge the columns is brutal with insane jumps anyway to turn off collisions? Quote Share this post Link to post Share on other sites
tane #20 Posted July 13, 2018 Any chance to hack some games? I was trying with an hex editor, but in some cases the value wasn't immediately near the address given. cheats 2.rar Quote Share this post Link to post Share on other sites
Mclaneinc #21 Posted July 13, 2018 Do you mean the cheats on these do not work for you? On Altirra or real hardware? Do I presume you are using the locations mentioned in the cheat files to hack other versions of the games? Quote Share this post Link to post Share on other sites
cRc_atari #22 Posted July 15, 2018 Shamus don't work on Altirra and real hardware. Shamus (1982)(Synapse Software)(US)(trn).xex Quote Share this post Link to post Share on other sites
Mclaneinc #23 Posted July 15, 2018 (edited) ?? The Original untouched Shamus needed OSB, this cheat version seems to be patched and works on both from the little I tried...The T is just for lives only, no collision removal etc... Not sure of the problem? Edited July 15, 2018 by Mclaneinc Quote Share this post Link to post Share on other sites
cRc_atari #24 Posted July 15, 2018 it seems ok, I did not notice any problems I did trainer only for lives Quote Share this post Link to post Share on other sites
Mclaneinc #25 Posted July 15, 2018 Ah, its your trainer..Sorry... Thought you were asking if its working or not.. Lives should help most people...If you like Shamus anyway look for the special version created on here with all the C64 levels added.. I did cheats for Shamus and most of the old stuff back in the day, no menu's just cheated and you played it or not.. Quote Share this post Link to post Share on other sites
