apersson850 Posted November 1, 2020 Share Posted November 1, 2020 3 hours ago, GDMike said: are we talking about this? ahh, maybe you didnt notice, i erased most of everything so i can start over. I did notice you erased part of it, to start over. But you kept the wrong PAB. And, of course, if you do improvements you don't show, then there's no way to help you to get further. 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 1, 2020 Share Posted November 1, 2020 Ahh.yes. just trying to get to that starting spot. My bad. Thx Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 2, 2020 Share Posted November 2, 2020 **************************************** * FILEM - FILE MANAGAMENT 06/04/20 * * * * LAST UPDATE: 11/01/20 * * * **************************************** TLOAD TEXT 'LOAD DSK ' *** * * SAVE DSK FILE * *** * ENTRY IS DSRS FOR SAVE ROUTINE GFERR1 B @GFERR DSRS LI R0,929 LI R2,>0001 LI R3,>3000 * "0" BLWP @VSBR * 1ST WE NEED TO GET THE LENGTH OF THE FILENAME IN R2 CB R1,R3 * ERROR! CANT BE "0 OR LESS" JLE GFERR1 * DISPLAY A MESSAGE LI R3,>3900 * IT HAS TO BE A NUMBER CB R1,R3 JGT GFERR1 * ERROR, NOT 1-9 LI R3,>2E00 * NOW ITS LEGAL, CONTINUE LOOKIN SG FOR "." PERIOD MARK INC R0 INC R2 * R2=2 BLWP @VSBR CB R1,R3 JNE GFERR1 * NOT VALID! ERROR GOTTA HAVE "." INC R0 INC R2 * R2=3 LI R3,>4100 * LOOKING FOR A CHAR VALUE UPPER A-Z BLWP @VSBR CB R1,R3 JLT GFERR1 * NOPE NOT A-Z, ERROR- WAS LESS THAN "A" LI R3,>5A00 * CHECK FOR GREATER THAN "Z" CB R1,R3 JGT GFERR1 * NOPE, NOT A-Z, WAS GREATER THAN "Z" LI R3,>2000 * CHECK FOR SPACE TO GET TOTAL COUNT KLNMH INC R0 INC R2 BLWP @VSBR CB R1,R3 * FOUND END OF NAME YET?, NO, KEEP LOOKING JNE KLNMH * KEEP LOOKING FOR NAME HERE AI R2,2 * WE ADD IN THE "DSK" 2 BYTES TO GET OUR FULL DESCRIP # MOV R2,@COUNT * SAVE THE LENGTH OF FILENAME LI R0,926 LI R1,FLNM * FILENAME BUFFER BLWP @VMBR LI R0,0 LI R1,FLNM BLWP @VMBW LI R0,120 LI R1,>2000 * CLEAR SCREEN AREA CSVA BLWP @VSBW INC R0 CI R0,960 JLT CSVA BL @BEEP LI R0,320 * MESSAGE "SAVING..." LI R1,SVMG LI R2,12 BLWP @VMBW LI R0,333 LI R1,FLNM MOV @COUNT,R2 BLWP @VMBW * the preceding code put something like * DSK2.UHOH into "FLNM" * with 9 in "COUNT" IF we are here, then * the user already created the filename. * the filename is echoed on that last * piece of code. * this next section sets up our data * INFO: SNPS1 - SNPS4 CONTAIN 860 BYTES * EACH OF DATA. BUT BANK# DECIDES WHICH * BANK TO MAKE ACTIVE. * 1ST TIME USE IS SET ABOVE, BUT WHEN * WE LOOP, WE WANT TO HAVE CODE FOR ALL * PAGES, BUT WE NEED TO PAD THE REST OF * THE BANK WITH SPACES " " TO FULLFILL * THE FOLLOWING IS JUST A PRE-SET CLR @PAGE MOV R4,@PAGE * SET EVERYTHING MOV R4,@RECONT * CLEAR RECORD COUNTER LI R1,>1100 * TO LOW CRAM MOV R1,@BANK# LI R12,>1E00 SBO 0 LI R3,>4006 MOV R1,*R3 SBZ 0 * GATHER CORRECT BANK # & PAGE HERE * GET READY TO RUMBLE! SPRCS MOV @PAGE,R4 INC R4 MOV R4,@PAGE CI R4,4 JGT NXBK * PAGE REACHED MAX, SO WE INCR BANK# CI R4,1 JGT NXP2 LI R1,S32P1 JMP NXC NXP2 CI R4,2 JGT NXP3 LI R1,S32P2 JMP NXC NXP3 CI R4,3 JGT NXP4 LI R1,S32P3 JMP NXC * AND SET PAGE TO 1 AGAIN NXP4 LI R1,S32P4 LI R0,SBUFF LI R2,860 * MOV A PAGE BLWP @VMBW * TO BUFFER LI R0,SBUFF1 LI R1,PADD LI R2,28 * PADD THE BALANCE BLWP @VMBW INC RECONT * RECORD COUNTER HERE INC @PAGE * AND PUSH ANOTHER 1000 BYTES FROM HERE! B @SPRCS NXBK MOV @BANK#,R1 AI R1,>0100 MOV R1,@BANK# CI R1,>F000 * MAX 240! JGT NXEX * EXIT! LI R12,>1E00 SBO 0 LI R3,>4006 MOV R1,*R3 SBZ 0 CLR @PAGE JMP SPRCS * GO AGAIN! * AND EXIT NXEX LI R4,>0001 MOV R4,@PAGE * SET PAGE TO 1 LI R1,>1100 * SET BANK# TO 1 OF 245! MOV R1,@BANK# LI R12,>1E00 SBO 0 LI R3,>4006 * THIS RESTORES SAMS MOV R1,*R3 * TO PAGE 1 SBZ 0 FEXITH BL @PSTPG * FILE EXIT HERE BL @CCREST * THIS RESTORES THE SCREEN LI R0,120 MOV R0,@POS B @CRTN * GFERR ERROR! AND RESTORE SCREEN AND HONK GFERR BL @HONK LI R0,920 LI R1,TER1 LI R2,40 BLWP @VMBW GFERS CLR @>837C CLR @>8375 LIMI 2 LIMI 0 BLWP @KSCAN MOVB @>837C,R0 JEQ GFERS GFEXIT BL @CCREST LI R0,120 MOV R0,@POS CLR @COUNTP B @CRTN *** * * OLD DSK.FILE * *** DSRL LI R0,533 LI R1,TLOAD LI R2,10 BLWP @VMBW B @DSRL *** * * VARIABLES AND BUFFERS *** * * SAVE FILE PAB INFORMATION DV 80 FORMAT * *** SBUFF EQU >1000 * BUFFER ADDRESS SBUFF1 EQU >1FE4 * PADDED WITH 28 SPACES PBAD EQU >79E * PAB ADDRESS FSPAB DATA >0002,SBUFF,>8000,>0000,>0009 * OP DV 128 EVEN FLNM BSS 48 COUNTP BYTE 0 STATUS EQU >837C POINT EQU >8356 READP BYTE >02 WRITE BYTE >03 CLOSP BYTE >01 EOFP DATA 0 ERRM TEXT '* I/O ERROR * ' CPUBF BSS 120 PADD TEXT ' ' RECONT DATA 0 TER1 TEXT '* INVALID DISK NUMBER * - PRESS ANY KEY ' SVMG TEXT 'SAVING FILE:' *** * * USED FOR TRACING, DEBUGGING * *** TRACE LI R0,0 LI R1,>2A00 BLWP @VSBW TRASP LIMI 2 LIMI 0 JMP TRASP DSR MOV R11,@SAVRTN LI R6,FSPAB+9 BLWP @DSRLNK DATA 8 JEQ DSRERP MOV @SAVRTN,R11 RT DSRERP INC @EOF LI R0,PBAD+1 BLWP @VSBR SRL R1,13 CI R1,5 JNE IOERP RT IOERP AI R1,>30 SLA R1,8 LI R0,288 LI R1,ERRM LI R2,14 BLWP @VMBW EOJP MOV @EOF,@EOF JNE NCLOSP MOVB @CLOSP,R1 LI R0,PBAD BLWP @VSBW BL @DSR NCLOSP DECT @RETURN MOV @RETURN,R11 RT ive got my code here that places my first 1028 bytes of data into the CRAM >1000. And it will keep moving that data as it increments forward to bank 240. That label is "HERE" The label"SPRCS" is where the loop begins. I just need to setup the DSRLNK prior to SPRCS and using "RECONT" to track the 128 byte records being written. Of course I'm still missing the DSRLNK code, I figured, if I get this process into play, maybe it would make the DSRLNK code a little simpler to insert. I've only placed code I know about. Thank you in advance. Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 2, 2020 Share Posted November 2, 2020 (edited) 1 hour ago, GDMike said: INC RECONT * RECORD COUNTER HERE INC @PAGE * AND PUSH ANOTHER 1000 BYTES FROM HERE! B @SPRCS Oops, I'll have to revisit the "INC @PAGE" here because SPRCS does this for me. And my PADD TEXT is 24 bytes. I've got to make it 28. Sorry for those typos. Edited November 2, 2020 by GDMike Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 2, 2020 Share Posted November 2, 2020 I'll review"DSRLNK" and how to setup the PAB and related but I'm still not sure how Just 128 bytes get written out of a block of vram containing 1028 bytes of data then I have to make sure that another 128 bytes get written again and so on before filling the buffer again. Quote Link to comment Share on other sites More sharing options...
Asmusr Posted November 2, 2020 Share Posted November 2, 2020 41 minutes ago, GDMike said: I'll review"DSRLNK" and how to setup the PAB and related but I'm still not sure how Just 128 bytes get written out of a block of vram containing 1028 bytes of data then I have to make sure that another 128 bytes get written again and so on before filling the buffer again. You need to update the buffer address in the PAB every time you write a new record. 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 2, 2020 Share Posted November 2, 2020 (edited) I've got my nose buried in the e/a book. And I've come to the conclusion of my PAB from what I gather. FSPAB DATA >0012, SBUFF, >8000, >0000, >0030 This is supposed to be a Display Variable 128 OUTPUT file that is set for "OPEN" for create. I'm now reading up on my creation of my "PBAD", (PAB ADDRESS.). So I have an understanding. Sorry, ? with me. Edited November 2, 2020 by GDMike Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 2, 2020 Share Posted November 2, 2020 Now I've set PBAD EQU >79E Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 2, 2020 Share Posted November 2, 2020 (edited) And now I'm ready to push the PAB into VRAM with LI R0, PBAD LI R1, FSPAB LI R2,48 And a BLWP @VMBW Does this have to be read over and over for each time I write a record? Edited November 2, 2020 by GDMike Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 2, 2020 Share Posted November 2, 2020 (edited) From what I see in the E/A manual, page 303, the DSR consists of pushing the PAB to VRAM IS always repeated, so I'll make sure mine is within a loop in a routine, DSR. Edited November 2, 2020 by GDMike Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 2, 2020 Share Posted November 2, 2020 (edited) Next in my DSR LI R6,PAB+48 MOV R6,@POINT And BLWP @DSRLNK DATA 8 This is supposed to open the FILE But I haven't set the bit for open,close etc.. yet. So I'll do that next Edited November 2, 2020 by GDMike Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 2, 2020 Share Posted November 2, 2020 As I'm just following the book.. MOVB @WRITE,R1 LI R0, PBAD BLWP @VSBW Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 2, 2020 Share Posted November 2, 2020 (edited) Next up in my DSR MOV R6,@POINT BLWP @DSRLNK DATA 8 And this would write a record So what just happened. Did it just create a filename? Edited November 2, 2020 by GDMike Quote Link to comment Share on other sites More sharing options...
Asmusr Posted November 2, 2020 Share Posted November 2, 2020 14 minutes ago, GDMike said: Next in my DSR LI R6,PAB+48 MOV R6,@POINT And BLWP @DSRLNK DATA 8 This is supposed to open the FILE But I haven't set the bit for open,close etc.. yet. So I'll do that next That should be PAB+9, not PAB+48. 1 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted November 2, 2020 Share Posted November 2, 2020 (edited) 16 minutes ago, GDMike said: As I'm just following the book.. MOVB @WRITE,R1 LI R0, PBAD BLWP @VSBW You need to open the file before you write to it. I see now that you did open it. Edited November 2, 2020 by Asmusr 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 2, 2020 Share Posted November 2, 2020 2 minutes ago, Asmusr said: You need to open the file before you write to it. It's set as open in the PAB first byte Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 2, 2020 Share Posted November 2, 2020 I see where your coming from, I'm just looking at what is in the PAB... But I understand calling each individualy.. Then I suppose I'd call the DSRLNK each time I change that operation, from open, to write. Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 2, 2020 Share Posted November 2, 2020 Ok. I'll upload just the code referring to just prior to calling the DSR and the DSR routine. Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 2, 2020 Share Posted November 2, 2020 (edited) LI R0,PBAD LI R1,FSPAB LI R2,48 BLWP @VMBW LI R6,PAB+9 MOV R6,@POINT BL @DSR MOVB @OPEN,R1 LI R0,PBAD BLWP @VSBW BL @DSR DSR LI R6,PAB+9 MOV R6,@POINT BLWP @DSRLNK DATA 8 RT I added the"open" after your statement. Can I remove this? Edited November 2, 2020 by GDMike Quote Link to comment Share on other sites More sharing options...
apersson850 Posted November 2, 2020 Share Posted November 2, 2020 You should have taken a closer look at the pseudo code I gave you. There's no point in having a buffer in VDP RAM that's larger than the record size. There's no point in moving a thousand bytes over to VDP RAM, then store them chunk by chunk. Instead, you move only 128 bytes (max) to you buffer, and write one record. Then you move another 128 bytes (max), to the same buffer, and store that in a new record. You do this in a loop, which stores one screen/page/bank, or whatever you call it. Then you make an outer loop that advances to the next screen/page/bank, until you have run out of banks. Your PAB definition still doesn't look like the one I suggested. It's still wrong, as in not functional. You move data to and from @COUNT in a few places, but it's not defined. 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 2, 2020 Share Posted November 2, 2020 9 minutes ago, apersson850 said: Your PAB definition still doesn't look like the one I suggested. It's still wrong, as in not functional. What's wrong with it? Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 2, 2020 Share Posted November 2, 2020 14 minutes ago, apersson850 said: You should have taken a closer look at the pseudo code I gave you. There's no point in having a buffer in VDP RAM that's larger than the record size. There's no point in moving a thousand bytes over to VDP RAM, then store them chunk by chunk. Instead, you move only 128 bytes (max) to you buffer, and write one record. Then you move another 128 bytes (max), to the same buffer, and store that in a new record. You do this in a loop, which stores one screen/page/bank, or whatever you call it. Then you make an outer loop that advances to the next screen/page/bank, until you have run out of banks. I can handle changing the code to do this. I just need to know what is wrong with the FSPAB layout. Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 2, 2020 Share Posted November 2, 2020 On 3/16/2018 at 11:48 AM, TheBF said: Very odd, however the PAB address must start at the position of the '.' after the device name. Ohhh...hmmm Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted November 3, 2020 Share Posted November 3, 2020 14 minutes ago, GDMike said: Ohhh...hmmm DO NOT GO THERE!—unless you fancy writing your own DSRLNK. The E/A DSRLNK expects >8356 to point to the filename length byte. DSRLNK uses that to parse the filename (read, “full pathname”) to pick out the devicename, like “DSK2”, (which is part of the filename!) to then search the DSR for that devicename. When DSRLNK calls the found devicename routine in the DSR, it has already positioned the PAB pointer to the proper spot the DSR routine needs. You do not position it anywhere but pointing at byte 9 of the PAB in VRAM just before you call DSRLNK. ...lee 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 3, 2020 Share Posted November 3, 2020 Good then that's one less issue. I'm still not resolving my PAB apparently though. I did change it again..to this FSPAB >0012,SBUFF,>8000,>0000,>0009 Open, display variable, 128 So I'm hoping it's better Quote Link to comment Share on other sites More sharing options...
