Sign in to follow this
bernie
Atari Cartridge issues- some work some don't
I recently bought an atari 800 off of CL and after replacing it's CPU board it seems to be working (48k NTSC version).
It came with several (left) cartridges. I tried some and they don't see to work (frogger, wizard of war, defender, centipede) - I just get memo
Others work part of the time (after inserting/removing).
Any ideas how to diagnose?
My machine is still apart from the CPU repair, how do I remove the plastic cover so that I can clean the contacts?
Edited by bernie
best thing is to use zero residue electrical contact cleaner and some times .... i hate to post any link to evil bay...
http://www.ebay.com/itm/NAKI-Eliminator-Sega-Game-Gear-Video-Game-Cartridge-and-Console-Cleaner-/122373112187?hash=item1c7e01817b:g:ph4AAOSwSlBYs2LT
there are plenty of options but you can either make your own or modify something ready made.... often more inexpensly
brasso is a last resort for rusty destroyed stuff... only clean in the direction of the pins.. not across them of sideways....
Edited by _The Doctor__
Also try cleaning the cartridge connectors with a Q-tip and alcohol
Thanks will try to order it. I've managed to remove the plastic cover protecting the cartridge slot. Should I just pour the stuff in there or put it on a cartridge and insert it?
What % of cartridges actually go bad (electronically) I've noticed that the connectors on some are really worn.
Thanks will try! I have those :)
Ok using alcohol in sprayer and qtiis I cleaned a few that were giving me trouble and they now work kinda... they sometimes give me black screen, sometimes the graphics aren't loaded, but if I power off/on, I got them to load at least once! Is this normal with really old cartridges?
Use a pencil eraser on the cart contacts. I find that it works much better than alcohol. It's just tricky to get to both sides of the board
I have only seen 2 cartridges truly go bad in 37 or more years... and that was across more than one system....
Try cleaning the cartridge port itself too.
I sprayed some alcohol in it, but I'm guessing there is no easy way to wipe?
I think I used q-tips to get at it. Contact cleaner is better than alcohol, though; it dries quickly and cleans better, especially when you're only able to spray parts down or wipe minimally. Just make sure you use a type of contact cleaner that isn't destructive to plastics (some of them are).
Trim a used/new credit card and fold a trimmed cereal box panel to fit the cartridge connector. After spraying with cleaner insert the card and box paper into slot for drying and cleaning.
