jedimatt42 #1326 Posted December 30, 2020 1 hour ago, RXB said: RXB SOURCE same as XB: [0149] 8345 FLAG EQU >8345 General 8-bit flag [0262] 03B9 SAPROT EQU >03B9 PROTECTION flag in SAVE [1974] 8C15 86,45 G8C15 CLR @FLAG Otherwise clear protection [2047] 8CBD 86,45 G8CBD CLR @FLAG Otherwise clear protection flag [2215] * Has to be PROTECTED option here, crunched as unquoted str [2216] 8DF4 D7,B0,2C G8DF4 DCEQ >C809,V*PGMPTR Unquoted string with length 9 8DF7 C8,09 [2217] * has to be PROTECTED [2218] 8DF9 41,09 BR ERRSYN [2219] 8DFB D7,E0,02 DCEQ >5052,[email protected](@PGMPTR) "PR" of PRotected 8DFE 2C,50,52 [2220] 8E01 41,09 BR ERRSYN If not : SYNTAX ERROR [2221] 8E03 D7,E0,04 DCEQ >4F54,[email protected](@PGMPTR) "OT" of prOTected 8E06 2C,4F,54 [2222] 8E09 41,09 BR ERRSYN If not : SYNTAX ERROR [2223] 8E0B D7,E0,06 DCEQ >4543,[email protected](@PGMPTR) "EC" of protECted 8E0E 2C,45,43 [2224] 8E11 41,09 BR ERRSYN If not : SYNTAX ERROR [2225] 8E13 D7,E0,08 DCEQ >5445,[email protected](@PGMPTR) "TE",of protecTEd 8E16 2C,54,45 [2226] 8E19 41,09 BR ERRSYN If not : SYNTAX ERROR [2227] 8E1B D6,E0,0A CEQ >44,[email protected](@PGMPTR) "D" of protecteD 8E1E 2C,44 [2228] 8E20 41,09 BR ERRSYN If not : SYNTAX ERROR [2229] 8E22 8E,E0,0B CZ [email protected](@PGMPTR) Check EOL 8E25 2C [2230] 8E26 41,09 BR ERRSYN [2231] 8E28 90,A3,B9 INC [email protected] XB protection flag is at Hex >03B9 or Decimal 953 the flag named is SAPROT also set by flag named oddly FLAG CALL POKEV(953,0) ! Unprotects file and clears SAPROT flag CALL POKEV(953,1) ! Protects file and sets SAPROT flag XB does not have a CALL POKEV command so you are screwed in XB. We are talking about the FDR attribute of a file, not the XB flag. in the manual: "TI Extended BASIC", page 163, the reference for SAVE in Chapter 4, subsection 'options', second paragraph: Quote ... This is not the same as using the protection available with the Disk Manager module. It is the protection available with the Disk Manager module that we are discussing... not the SAVE PROTECTED option that those pokes manipulate. We are trying to discuss the thing that has to do with disk controller level stuff. Well, except we are done discussing it. The summary: TIPI doesn't support the disk manager protection feature, except to set and unset it. It fails to enforce it. Enforcing it could be a good thing, which I've filed as an issue in the project github repository. Native files (things not in TIFILES format) on linux are treated as read-only ( mostly ) and it could clarify things to users, if TIPI reported them as protected ( P ) in the catalog records it generates at the disk controller level. And if it uniformly enforced the protection. Quote Share this post Link to post Share on other sites
+RXB #1327 Posted December 30, 2020 I made a upgraded version of the Disk Manager Module too. It handled RAMDISK like DSKA. or Disks 1 to 9 too. That would be a better upgraded Disk Manager Module then the one I see people use. RXB 2012 also had a routine to strip all Protections off disk files on a disk and make a unprotected disk copy sector by sector. How come TIPI does not support that option, it is only 1 byte flag? Quote Share this post Link to post Share on other sites
jedimatt42 #1328 Posted December 31, 2020 3 hours ago, RXB said: How come TIPI does not support that option, it is only 1 byte flag? See previous posts not too far up the road. 1 Quote Share this post Link to post Share on other sites
+RXB #1329 Posted December 31, 2020 On 12/28/2020 at 10:00 AM, jedimatt42 said: A nice way to tie some stuff together, would be for me to implement this protect flag properly and report all the magic native conversion type files as protected, since they are implicitly already, but the error handling is ... made up. So you need to look up the standard error handling instead of just making up you own? You could just us the TI OS it has most of those built in already. Quote Share this post Link to post Share on other sites
jedimatt42 #1330 Posted December 31, 2020 1 hour ago, RXB said: So you need to look up the standard error handling instead of just making up you own? You could just us the TI OS it has most of those built in already. If it worked that way, wouldn't that be nice... I refer you to the developers resources thread, where all the documentation and specifications for most aspects of the 4A architecture are linked. My statement about 'made up' was flippant, and not accurate. I don't think you understand what TIPI is... I have adhered to the specifications of the 'TI OS' as much as practical... but as noted earlier, my copy was missing pages. 4 Quote Share this post Link to post Share on other sites
GDMike #1331 Posted December 31, 2020 Is that the missing link!! Ohhhhh. I'm crawling back in my hole.... Just adding some spiceness with niceness. 1 Quote Share this post Link to post Share on other sites
+retroclouds #1332 Posted January 1 Don't know if this has been already reported and fixed in the past, so please ignore if necessary: The config program ("CALL TIPI") locks-up if the URL in URI1 is too long. Just verified it again. Had to ssh into the PI and edit the tipi.config manually to make it work again. After I removed the URL and restarted the TI-99/4a, the config started responding normally again. Tested with TIPCFG v10, PI-Version 1.65 The URL I used was: URI1=https://github.com/kl9900/TMS9900Family/blob/master/Consoles/TI-99/99-8/Rom/TXT 1 1 Quote Share this post Link to post Share on other sites
+arcadeshopper #1333 Posted January 1 Don't know if this has been already reported and fixed in the past, so please ignore if necessary: The config program ("CALL TIPI") locks-up if the URL in URI1 is too long. Just verified it again. Had to ssh into the PI and edit the tipi.config manually to make it work again. After I removed the URL and restarted the TI-99/4a, the config started responding normally again. Tested with TIPCFG v10, PI-Version 1.65 The URL I used was: URI1=https://github.com/kl9900/TMS9900Family/blob/master/Consoles/TI-99/99-8/Rom/TXT Holy giant url batman Sent from my LM-V600 using Tapatalk 2 Quote Share this post Link to post Share on other sites
GDMike #1334 Posted January 1 (edited) Scared me, I thought you locked up the new year there for a moment.. that was a close one, but instead, you created the first lock up of the new year... Edited January 1 by GDMike Quote Share this post Link to post Share on other sites
+arcadeshopper #1335 Posted January 1 Tiny url to the rescue?Sent from my LM-V600 using Tapatalk 1 Quote Share this post Link to post Share on other sites
jedimatt42 #1336 Posted January 1 (edited) @retroclouds, I'll add it to github issues. Along with the need to rework that. It hasn't handled long lines well - ever. You probably ran into a buffer overrun! Now can you use it to jailbreak your 4A? Back when I was writing TIPICFG, I now realize I almost never prevented buffer overruns in my 4A code. (Ah, this is already recorded: https://github.com/jedimatt42/tipi/issues/141) Edited January 1 by jedimatt42 1 Quote Share this post Link to post Share on other sites
