shear_xear Posted May 14, 2017 Share Posted May 14, 2017 Hi everyone. I just recapped my The Voice unit and I found a component floating around inside. Can anyone help me identify this so I can try to replace it? It is the little blue chicklet with CSA 3.12MS printed on it. Thanks! Quote Link to comment Share on other sites More sharing options...
metarog Posted May 15, 2017 Share Posted May 15, 2017 Hi, it goes right there where you have it on Y1 facing towards C1. I hope that is what you wanted and to know. Quote Link to comment Share on other sites More sharing options...
shear_xear Posted May 15, 2017 Author Share Posted May 15, 2017 Actually, I know where it would go, but the legs snapped off, so I believe I need a replacement, but have no idea what part to look for. All searches for what is on the part gave me nothing, Thanks though! Quote Link to comment Share on other sites More sharing options...
+KylJoy Posted May 15, 2017 Share Posted May 15, 2017 I do not know right off where to get one but you can probably solder that back on. I would try to solder it back like it is but I might need to scrape away a bit of the blue coating from the legs and then solder the legs back. What have you got to lose? It's already broken. 1 Quote Link to comment Share on other sites More sharing options...
shear_xear Posted May 15, 2017 Author Share Posted May 15, 2017 I was thinking about that, but had no idea if that would work. Suppose it is worth a try. Thanks! Quote Link to comment Share on other sites More sharing options...
shear_xear Posted May 15, 2017 Author Share Posted May 15, 2017 So, that did the job. Thanks for all the help! Quote Link to comment Share on other sites More sharing options...
+KylJoy Posted May 15, 2017 Share Posted May 15, 2017 Congratulations and good work! Quote Link to comment Share on other sites More sharing options...
metarog Posted May 15, 2017 Share Posted May 15, 2017 Great news... I was going to suggest the same thing. As long as a little bit of the leg is on there it should work. Nice job. Quote Link to comment Share on other sites More sharing options...
Rolo Posted June 25, 2017 Share Posted June 25, 2017 The part you were looking for is the crystal for the clock oscillator of the speech chip. It's running at 3.12 MHz. Rolo Quote Link to comment Share on other sites More sharing options...
