+toddtmw #1 Posted May 21, 2017 If I am looking at a computer (like an 800XL) and I plan to hook it up using the monitor port to a composite input on a TV or monitor, does PAL or NTSC matter? What about power supply? Can an American Power Supply power a PAL computer and Vice Versa? Thanks! -Todd Quote Share this post Link to post Share on other sites
Kyle22 #2 Posted May 22, 2017 Power supply is always the same with XL/XE. Make sure you don't have the 'Ingot'. Get a monitor that works with your video system. I have a Sharp Aquos, and it displays PAL and NTSC. Quote Share this post Link to post Share on other sites
+kheller2 #3 Posted May 22, 2017 The answer is: yes it matters. Composite does not negate how the signals over that connection are generated nor interpreted by said monitor; i.e.: its not composite, NTSC, PAL... but NTSC or PAL via Composite/SV/whatever. As Kyle22 pointed out, some monitors and TV's can display both, most can not. Quote Share this post Link to post Share on other sites
Rybags #4 Posted May 22, 2017 Sometimes the monitor will handle the frame rate just fine but only do black & white because the colourburst isn't supported. You could probably get around that by using an NTSC GTIA in a PAL Atari. Not so simple for the other way around as PAL GTIA also needs the extra crystal and supporting circuitry which isn't included on NTSC machines. 1 Quote Share this post Link to post Share on other sites
Bryan #5 Posted May 22, 2017 This is what I usually use with my 8-bit stuff: http://atariage.com/forums/topic/247508-modding-the-jvc-tm-a13su-monitor 1 Quote Share this post Link to post Share on other sites
+Stephen #6 Posted May 23, 2017 This is what I usually use with my 8-bit stuff: http://atariage.com/forums/topic/247508-modding-the-jvc-tm-a13su-monitor But most mere mortals don't modify the firmware in their monitors!!! 1 Quote Share this post Link to post Share on other sites
