atari2600land
Ants (WIP)
Hello!
They were 24-bit, but I got them down to 16-bit. And I put them in ABS instead of ROM.
http://www.atari2600land.com/antsjag/
The 3 background images are now ok (on my PAL-K-Jag with CD-Player and Rev. 3 Skunkboard), but the music/sfx is still just hissing noise :(
Also: The game stucks after one play in the "Game Over" screen (with the ants moving around).
Kind regards
Matthias
You can keep adding items to RAM (abs) but at some point you will run out of RAM and have to use ROM. At that point you need to change the romwidth as I detailed in an earlier post for this to work on a Skunk. For any other cart the default RB+ rapapp.s settings are fine (eg. don't include the change). VJ doesn't seem to care what this is set to.
So if you have room, put the music in abs now too and that should fix the hissing. When the abs file gets to around 1.9MB then it will stop working unless you switch some assets to ROM.
Edited by Sporadic
Putting the music in abs makes the music all screwed up in Virtual Jag. I changed the params and it didn't help.
You're using zeroplayer. The calls in your code are currently set up for when the sound lives in the ROM.
Your SNDZEROPLAY calls need changing. Look in the docs folder of RB+, the quickref.txt . Search for the SNDZEROPLAY command and on the right you will see it says "example for playing from ram (abs).
Do that ;)
Basically you need to remove the (void*) and wrap all the address names with strptr().
Eg (To quote your code);
ROM (Your current code)
SNDZEROPLAY(3, (void *)SFX_INGAMEMUSIC, (SFX_INGAMEMUSIC_end-SFX_INGAMEMUSIC+3) and 0xfffffffc, 23084/8533, Zero_Audio_8bit_Unsigned|Zero_Audio_Looping)
RAM (abs) (When you change the sound asset to abs)
SNDZEROPLAY(3, strptr(SFX_INGAMEMUSIC), (strptr(SFX_INGAMEMUSIC_end)-strptr(SFX_INGAMEMUSIC)+3) and 0xfffffffc, 23084/8533, Zero_Audio_8bit_Unsigned|Zero_Audio_Looping)
Edited by Sporadic
That's what I tried and didn't work.
EDIT: I guess I said it was signed when it wasn't.
Edited by atari2600land
Hello!
New version up at the site. I put the site URL in my signature.
Now the music is ok, probably the sfx too.
But now there is a delay of almost 10 seconds between start of the ROM-image and the appearance of the title screen.
The target focus isn't below of the forefinger, but left of it as it would indicate the middle of the hand.
User interface: Starting a game using OPTION isn't really intuitive, neither is it to use PAUSE to leave the GameOver-screen.
Best regards
Matthias
PS: Signatures are only visible for people who are logged in.
Agreed I think mapping these functions to B would be best. If you are looking to be able to turn the bees off on the fly during gameplay, you can simply copy the code you already have and keep the OPTION function as well. But for starting up I think B would be best.
Edited by Jeffrey_Bones
Hello!
Kind regards
Matthias
Hey!!! Matthias! You are Atari-Famous!
My favorite Atari Jaguar game is Impulse-X.
I am back working on this again. I changed it to an ABS file, which decreased the time the screen is blank at the beginning very significantly. Also, I made it so you can only press B when you die after the death song has been played. It took a long time to figure out how to do this. Link to the game is (still) in my signature. The game is now 1.70 MB, so I should be OK with stuff. I don't know what to add to the game, so if anyone has any ideas, let me know.
  • Like 4
I just played this for about ten minutes. I think it is a fun little game, and a very nice first release.
If you are looking for some constructive criticism, I might suggest gussying up the graphics a bit - I find that plain white backdrop kind of bright and harsh to look at.
I also think it needs something to jazz up the gameplay a bit: maybe have levels that last a minute, pause to play some music and display a score, then move to the next level with faster moving black ants or more red ants..? Slowly ramp up the difficulty or the speed level by level?
Changed the options and game over screen. I changed the game's size, cut it back a little by making them 4-bit colors instead of the 16 they once were. Now it's 1.5MB instead of 1.7MB. I'll work on the game play elements soon.
Have you played Crimsonland ? Your game slightly reminds me of it.
There's lots of gameplay elements you could get inspired from.
I don't know why, but it took multiple attempts and multiple sessions and multiple image attempts to put a new picture in the game. I made the word "ROUND" an image instead of text.
We don't know either, because you didn't show us what you were trying.
The reason I didn't show it is because I finally got it working. If I couldn't have, then I would have asked for help (again.) I guess it just seems to like some images but not others, which is really weird.
