BenG76
Colecovision Expansion Module #1 problems
I picked up this expansion module to play 2600 games on my Coleco. My Coleco is modded for RGB and works very well. I have tried the module several times today with no success at all. I even cleaned the contacts well in my expansion port as well as the module. I am not sure what else to do. The seller stated that it worked. I don't have another Coleco to test it on either so I don't know for sure if the module has the issue or my Coleco. Any suggestions?
As far as I'm aware, the 2600 module won't work with an RGB modded system.
I guess that would be the issue then. LOL. I appreciate the reply.
Have you tried hooking it up the old fashioned way through the RF connector? I'm not clear if the expansion modules will work this way, but I know they won't work directly through the RGB or VGA modded systems.
I am pretty sure that you can still use the adaptor if you have an rgb mod . It will just output composite . Did you get it modded by yurkie ?
I did have it modded by Yurkie. It does not have anything but the RF and the RGB out though. Now I just hope the Super Game Module I preordered will work with it.
Mines vga out and it works with the sgm. Yurkie modded it.
Pm him and ask . I guess it is possible that your adaptor doesn't work .
