Sign in to follow this
ACML
Need good recommendation for EPROM burner (USB)
I need to update my EPROM burner to the 21st century. Well, EPROMs aren't really 21st century-ish, but you know what I mean. I mainly want to burn 27C128 (16KBx8) 28 pin EPROMs. There are some really inexpensive ones on eBay and Amazon, but are they any good? Looking for personal recommendation of actual experience using them.
Thanks!
Edited by ACML
I just ordered a TL866A today! Should get here the same time my 27C128s show up.
I have had nothing but good luck with my TL-866A. Get the cheaper CS version and turn it into the A version using tools found here: http://atariage.com/forums/topic/246355-minipro-tl866-upgrade-instructions/?hl=+tl866
Can anyone verify that the TL866CS will program either of these chips?
ATF20V8B-10PC
Datasheet: h**p://www.atmel.com/Images/doc0407.pdf
GAL20v8B-10LP
Datasheet: h**p://www.alldatasheet.com/datasheet-pdf/pdf/243905/LATTICE/GAL20V8B-10LP.html
I know the GAL20v8B is listed on their website as being supported but I'd like to know if anyone has consistently programmed this chip with this programmer without issue....
I use the GQ 4x4 for eproms. It installed easily on my Windows 7 64-bit computer and utilizes USB. It programs very quickly and I've had no issues with it. My only complaint is lack of support for PLD chips and no answer from tech support on how to add it (most devices don't even have tech support so nothing lost there I guess). You do have the ability to add more devices via a text file provided you can read the datasheet for the chip.
You can read about it HERE
Supported device list is HERE
I have not yet programmed any GALs with mine yet. All I could have done was refer you to the supported device list.
Osgeld has beaten me to it.
Thank you! I've heard Atmels can be picky. I've heard some stuff on the support list isn't actually supported so I wanted to make sure.
yea I used the lattice part on a couple 32k carts I made a few Christmases ago
Good deal. All the auctions etc I see state Windows 32 bit but the website says it's compatible with 64 bit windows. Hope that's true as I ordered one....
I have used it on both 32 bit 7 and 64 bit 7 (my old shop computer had home, my newer one has pro)
