bob_er #26 Posted July 12, 2017 Thanks for the link - I checked it out and with my limited assembly skills the code seems to be doing everything I do with the exception of updating the NMI vectors - which since I'm not changing anything in the ROM, should not need to be updated.So, consider to copy ROM in some parts. To do this you will need additional routine for turning ROM on. The code you list here - it looks like it compares the value of $14 (APPMHI) with itself and then calls the routine stored at $FFFE - is that correct? If I have VBI's already disabled, is this required?No, 'system_off' should be part of your code. To FFFE you should put 'NMI' label (from code provided at atariki). During turning ROM off you must avoid any interrupts (NMI and IRQ as well). That's why I'm waiting for new value in $14. Memory at $14 is a part of system clock, changed each VBL. lda $14 - load current value of counter to Accumulator cmp $14 - compare Accumulator with current value of memory. x beq *-2 - if value is the same, compare again. That value is changed only by VBL interrupt routine, so this condition will be false just after VBL interrupt. Now you have >30k cycles to change NMI vector. So, in summary, you can resolve your issue this way: 1. Copy part of ROM to RAM. 2. Turn ROM off. 3. Copy data from 1 to final destination inside RAM under ROM. 4. Turn ROM on. 5. Jump to 1 until all done. Quote Share this post Link to post Share on other sites
jacobus #27 Posted August 9, 2017 Success!!! I rewrote the code to perform the ROM->RAM copy operation using smaller (2K) blocks as per Bob_er's excellent instructions. The code now allows the entire ROM code to be successfully copied to RAM (skipping $D000-$D7FF), flipping back and forth every 2K. The problem turned out to be my original code was trying to copy too much data at a time. A big "Thank You" to everyone involved! I have included the working QUICK code for reference. Quick-Sourcetext D1:PORTB.QIK ---------------- Length: $0DF6 Free : $6975 ---------------- ************************************ ************************************ BYTE [ RTCLOK=20 SDMA=559 CONSOL=53279 PORTB=54017 NMIEN=54286 A,C BLOCK ] WORD [ ROM ] ************************************ *** MAIN LOOP *** ************************************ MAIN BLOCK=0 ROM=49152 ;start of ROM REPEAT IF BLOCK<>2 ;copy unless D000-D7FF PORTB=255 ;turn on ROM PRINT("Copying block # ",BLOCK) .JMOVE(ROM,1536,2048) ;copy 2K *sync with VBL C=RTCLOK REPEAT UNTIL RTCLOK<>C NMIEN=0 ;turn off interrupts *issue PHP,SEI INLINE [ 8,120 ] PORTB=254 ;turn off ROM .JMOVE(1536,ROM,2048) ;restore block *issue CLI,PLP INLINE [ 88,104 ] NMIEN=192 ;restore NMIEN ENDIF ADD(ROM,2048,ROM) ;next 2K block BLOCK+ UNTIL BLOCK=8 PRINT("ROM code restore complete") *test POKE(52256,0) ;write 0 to known loc PEEK(52256,A) ;get result IF A=0 PRINT("Success!") ELSE PRINT("Failure") ENDIF ENDMAIN ************************************ ************************************ ************************************ PROC JMOVE IN WORD [ SRC,DEST,LN ] LOCAL WORD [ MEM ] BYTE [ Z ] BEGIN MEM=0 REPEAT PEEK(SRC,Z) ;read source byte POKE(DEST,Z) ;write dest byte ADD(SRC,1,SRC) ;inc source counter ADD(DEST,1,DEST) ;inc dest counter ADD(MEM,1,MEM) ;inc byte counter UNTIL MEM=LN ENDPROC 2 Quote Share this post Link to post Share on other sites
DGS-Atari #28 Posted August 16, 2017 Could jacobus please remove the Quick user guide from his post. The Quick manual is still subject to copyright and can't be distributed in this way. Anyone wanting Quick can still get it for minimal cost from my website: http://www.dgs.clara.net/ Thanks. Quote Share this post Link to post Share on other sites
jacobus #29 Posted August 28, 2017 Could jacobus please remove the Quick user guide from his post. The Quick manual is still subject to copyright and can't be distributed in this way. Anyone wanting Quick can still get it for minimal cost from my website: http://www.dgs.clara.net/ Thanks. Done! Sorry about that! Quote Share this post Link to post Share on other sites
