jwierer #1 Posted August 13, 2017 Hello Atari Age, I was going through some older projects and came across my Bentley Bear: Crystal Quest 7800 Game Editor. The back story on this one. Back in 2012, Bob had just started working on Bentley Bear. I had written a few level editors for some of his previous games (Failsafe, CrazyBrix) and some editors for 7800 Pacman and he asked if I could put something together so he wouldn't have to do all 48 levels by hand. I loved the idea of helping Bob with his most ambitious project and from about Feb to Sept I worked on the following editor that he eventually used to expedite level design. Bentley Bear has been available for purchase and it's been nearly 5 years since I stopped work on this, so with Bob's blessing I decided to share it with the community. This works with the final A78/BIN release found here. I built this using the Microsoft .Net Framework 4.0 (My Windows 7 machine and Windows 10 machines already have this, but you may need to download if you get an error running it) BentleyEd.Build31.zip Using this tool, you can completely customize Bentley bear with: Graphic (board tile editor / sprites) Level editor (create completely new levels and enemy placement) Create new parallax levels (by modifying the zone speeds) Color settings (change the color palettes for levels and graphics) I didn't write a manual for this, so you'll have to figure out how to use it via trial and error (maybe somebody in the community can write one up). Here are some screenshots if you're wondering if it's worth your time. Enjoy, Jeff 12 Quote Share this post Link to post Share on other sites
PacManPlus #2 Posted August 13, 2017 Under the 'Settings' tab, you might want to use " _SPRITECOLORLOC=135670" for the correct colors if you use the BIN pointed to above. Quote Share this post Link to post Share on other sites
gambler172 #3 Posted August 13, 2017 You know,which tool helped me to build my Asterix game??? A sound editor would make it perfect. greetings Walter Quote Share this post Link to post Share on other sites
jwierer #4 Posted August 13, 2017 Under the 'Settings' tab, you might want to use " _SPRITECOLORLOC=135670" for the correct colors if you use the BIN pointed to above. Thanks! Quote Share this post Link to post Share on other sites
gambler172 #5 Posted November 5, 2017 Hi Jeff found s bug...when you make any changes..save it and test it......sound is gone..... Quote Share this post Link to post Share on other sites
jwierer #6 Posted November 7, 2017 Yes I was able to reproduce it. I think the problem is earlier releases of the game were going to have more levels. Somehow it's writing empty levels to the area where the music resides. I'll have to look. Thanks for letting me know. -Jeff Quote Share this post Link to post Share on other sites
jwierer #7 Posted November 7, 2017 Walter, For some reason a few bytes are getting the wrong data breaking the music. I haven't figured out where it's going wrong, but in meantime I hacked in a fix at the end to path the binary with the correct values. Please see if the EXE in the attached ZIP file fixes the music issue for you. -Jeff Bentley Editor32Fix.zip 2 Quote Share this post Link to post Share on other sites
jwierer #8 Posted November 7, 2017 (edited) I think I found the actual cause of the problem. Here is a complete package that should fix the sound issue. -Jeff BentleyEd.Build33.zip Edited November 7, 2017 by jwierer 2 Quote Share this post Link to post Share on other sites
gambler172 #9 Posted November 11, 2017 Hi Jeff great.....will check tomorrow Quote Share this post Link to post Share on other sites
gambler172 #10 Posted November 11, 2017 I think I found the actual cause of the problem. Here is a complete package that should fix the sound issue. -Jeff Hi Jeff is there an actual Bentley Tia version....if i do jot want to use Pokey???? greetings Walter Quote Share this post Link to post Share on other sites
jwierer #11 Posted November 11, 2017 Hi Jeff is there an actual Bentley Tia version....if i do jot want to use Pokey???? greetings Walter Bob would have to answer that question. I would assume both TIA and Pokey are in the same bin. -Jeff Quote Share this post Link to post Share on other sites
gambler172 #12 Posted November 12, 2017 (edited) Bob would have to answer that question. I would assume both TIA and Pokey are in the same bin. -Jeff Hi Jeff checked Version 33 if i make changes and save them...for the first time......it works....but if changeing and saving several times,the titlescreen appears,Start is not visible anymore and i cannot start it.If i change the red Diamond graphic...object 0C...i cannot place it,where i want. i use the Bentley P file,which was posted greetings Walter Edited November 12, 2017 by gambler172 Quote Share this post Link to post Share on other sites
jwierer #13 Posted November 13, 2017 Hi Jeff checked Version 33 if i make changes and save them...for the first time......it works....but if changeing and saving several times,the titlescreen appears,Start is not visible anymore and i cannot start it.If i change the red Diamond graphic...object 0C...i cannot place it,where i want. i use the Bentley P file,which was posted greetings Walter Ok. I'll try to see if I can replicate the problem tomorrow. You are saying once you make multiple changes and try to save it no longer will start the game? Quote Share this post Link to post Share on other sites
gambler172 #14 Posted November 13, 2017 Ok. I'll try to see if I can replicate the problem tomorrow. You are saying once you make multiple changes and try to save it no longer will start the game? yes,the start...disappears...after multiple saves...and there are problems with object 0C...... Quote Share this post Link to post Share on other sites
jwierer #15 Posted November 13, 2017 yes,the start...disappears...after multiple saves...and there are problems with object 0C...... I was able to make multiple changes and use object 0C without any problems. Must be something you are trying to do. Perhaps you are trying to put too many objects on a screen. If I recall, Bob told me there was a limit. -Jeff Quote Share this post Link to post Share on other sites
gambler172 #16 Posted November 13, 2017 I was able to make multiple changes and use object 0C without any problems. Must be something you are trying to do. Perhaps you are trying to put too many objects on a screen. If I recall, Bob told me there was a limit. -Jeff Ok...will try at weekend... greetings Walter Quote Share this post Link to post Share on other sites
Artillory #17 Posted April 21, 2020 (edited) Bryan here, Which Bentley Bear Editor is the best to use right now for a PC running Windows 10 Home Edition? Edited April 21, 2020 by Artillory Quote Share this post Link to post Share on other sites
