gfvh
Very crude raycaster
Hello. This is a very crude and horrendous raycaster I made. It is devoid of any complex math, just matrix comparisons.
The screen is rotated 90 degrees to take advantage of the Player Field graphics.
There is a little map below to show where you are and the structure of the walls in the world.
I didn't test it in Stella yet.
Source code: http://mauisland.byethost24.com/vh/ray2-6.txt
Thanks!!!
ray.bin
Edited by gfvh
I tested it in an emulator for android that I suppose it's based on Stella. It worked. But it is so horrible this raycaster that you may think it is not working :)
Thanks for verifying this.
It runs in Stella 5, too (actually, we are not currently aware of any broken ROM at all). However, your frame height seems to be inconsistent during movement --- this causes jitters on real CRTs (and on Stella if TV emulation is turned on). Also, moving backwards doesn't seem to work, either.
Yes, during movement is where the tracing occurs, so it takes some time, but I think I can fix it using a timer, I'm not using timers. I will check not being able to go backwards. But in javatari it works. I am using javatari because I can't install Stella in my workplace ;)
Didn't work for me in either Stella 4, Stella 5 or 6502.ts (provided back is 'joystick back') :) I haven't checked in real hardware though.
Edited by DirtyHairy
By the way, it works really good in 6502.ts, great emulator. It made an awful code like mine to run smoothly.
Edited by gfvh
Thanks :) I think what you are seeing is the result of 6502.ts being very (as in unrealistically) tolerant about frame timings.
I guess I know why you cannot go backwards. Maybe you are playing with the first version. It's my fault I named both ray.bin. The first version allows you to rotate left and right and moving forward but not backwards. The second version allows you to go left and right (no rotation) and forward and backwards.
Indeed, you're right. Going back works fine with the newer version. I thought I had tried that one before, but obviously, I messed up :) Sorry for the hassle!
