danwinslow Posted September 2, 2017 Share Posted September 2, 2017 (edited) So, I managed to solder 3 wires. My first soldering attempt, went OK and I only had about 300$ of soldering equipment ('professional' soldering/desoldering station), so I was roughing it. I now have a 130xe with what appears to be a functioning rapidus in it. It boots (using RealDos). I can hit inverse key/reset to bring a menu up. It's just a panel of settings, and I'm not sure what they all mean. By jiggering around with them, I could tell that the rapidus was on (REALLY fast IO during boot and screen writes noticeably faster). but RealDos croaks just as it's finished loading. Does RealDos not function with Rapidus? Do I need to be using Sparta or some custom '816 dos? So now what? I can't seem to find any decent docs on rapidus, so if someone could point me to any I'd appreciate it. I think I need to upgrade the core, and the software is available at Lotharek's so I can handle that. I know there's several HUGE threads here but wading through them I'd like to skip if there are some kind of docs somewhere. Mostly I am looking for: What do all the settings in the setup panel mean? Found them in long thread. What DOS's work? What are the various speedup modes available? Same place. Edited September 2, 2017 by danwinslow Quote Link to comment Share on other sites More sharing options...
drac030 Posted September 4, 2017 Share Posted September 4, 2017 (edited) What DOS's work? SpartaDOS X, for example If Real.DOS serial routines use delay loops to measure time, there may be a problem. You can try to switch "RAM #3" to "No speedup", and see if it helps. I can also recommend you my website for some software. You may want to update the Rapidus OS, for example. Edited September 4, 2017 by drac030 1 Quote Link to comment Share on other sites More sharing options...
danwinslow Posted September 4, 2017 Author Share Posted September 4, 2017 Yes, thanks Draco! Quote Link to comment Share on other sites More sharing options...
