Sign in to follow this
Swami
atari 1010 head alignment code
That's it.
I'm not sure the method described would work. Normally you should hear a minimum of the high pitched data sound since only the audio track is fed into the computer's audio out. But generally you do get it anyway due to crosstalk on the serial cable.
The tape you'd want to use is one recorded on a known good audio deck. Have a blank right track and some test audio on the left track - the ideal would probably be just a medium pitch constant tone so you could use the described method to do the alignment. Also agreed you'd be better off using audio off the monitor port than through RF.
Edited by Rybags
In the worst case, you can use a decent prerecorded music cassette and keep adjusting the head until your ears hear maximum treble. Not everyone has an oscilloscope and a reference tape on hand. But if you have a decent tape deck, then you can create a tape with a test signal easily.
Fortunately, the FSK used for standard tape records is not extremely sensitive to the head alignment.
Edited by baktra
That's it.
How would I go about creating a good test signal tape. The pre-recorded ones are going for about $50 on ebay.
Well, I meant any music cassette with pre-recorded music (rock, pop, classic). Not the real test tape.
Edited by baktra
Plenty of old tape decks have seperate L/R inputs and/or level control for both tracks.
In the modern day, I'd just use something like Audacity to create a test MP3 and record from that.
