DIY SIO2USB
V-Cool
I think I am very close to it working.  I am using the following code in Arduino:
Spoiler
void setup() {
  Serial.begin(19200);
  Serial1.begin(19200);
void loop() {
  if (Serial.available()) {      // If anything comes in Serial (USB),
    Serial1.write(Serial.read());   // read it and send it out Serial1 (pins 0 & 1)
  if (Serial1.available()) {     // If anything comes in Serial1 (pins 0 & 1)
    Serial.write(Serial1.read());   // read it and send it out Serial (USB)
AspeQt gives a "get status" message when I turn the Atari on, but doesn't really get past that.  Cannot save (or load) anything.  I have the Ground pin connected, and the TX and RX pins connected to their respective slots in the SIO cable.
You could use one of the digital lines in the Arduino to look at the command line
then in your code you could monitor the command line, I assumed in your code
Serial is from the Atari and Serial1 is to the Atari
#define COMMAND 8
pinMode(COMMAND,INPUT_PULLUP); // may only need INPUT
void setup() {
void loop() {
  if(!digitalRead(COMMAND) // COMMAND LOW
  if(digitalRead(COMMAND) // COMMAND HIGH
