VicViper #1 Posted October 14, 2017 Just loaded up a bunch of files from tigameshelf that say they require XB cart, I presume it's referring to the extended basic cart, but obviously can't put in the CAB cart with my finalgrom99 plugged in. When I looked for the files they didn't show up. 1 Quote Share this post Link to post Share on other sites
+Schmitzi #2 Posted October 14, 2017 Hi VicViper, >where< did you copy the XB (yes, Extended Basic) files to ? Did you copy them onto the FG99´s SD-card ? ( ) (This will not run) And, if you try this 20 times, as I did, this will not run, too :) Or did you copy them onto a (maybe real) floppy disk, inserted to your (given) PEB (periphal expansion box) ? FG99 does not emulate a floppy drive on itself (with using the SD-card as a storage), BUT it will access all (real) floppy drives, of course, (here: with running an i.e. "Extended Basic.BIN" virtual cartridge from the FG99er´s SD-Card, as that´s what it is for) If you don´t have a real floppy drive (nor a NanoPEB´s emulated drive via the sidecar, or anything like this), you *theoretically* (just to explain here) would have to convert the XB-file into a BIN-file, for the SD-card, running this XB-program as an emulated <cartridge>. But THIS is a totally different story, and I don´t think that you "just" can convert XB programs into BIN/cartridges format. Finally, please let me tell you and know that I am not a specialist, and wait for more answers here. If you have any questions concerning hoarding, I can give you fully correct answers xXx Quote Share this post Link to post Share on other sites
Vorticon #3 Posted October 14, 2017 Just loaded up a bunch of files from tigameshelf that say they require XB cart, I presume it's referring to the extended basic cart, but obviously can't put in the CAB cart with my finalgrom99 plugged in. When I looked for the files they didn't show up. You can have the XB cart BIN file installed in a folder on the FinalGrom SD card. It's located in the image repository in the pinned post at the top of the topic list on this forum. On the other hand, you cannot run any programs that are not in cartridge format from the FinalGrom because it is not emulating a floppy or hard disk drive. Think of it as just a multi-cart holder with a selector switch like the Navarone Widget, and you can select only one cart at a time, but you will still need to have a floppy or hard drive (or RAM drive) available to access programs outside of the cart itself. Assembly language programs can be converted to cart format with some effort but it's a laborious process if the program was not designed for this. Basic and XB programs cannot be converted to cart format. I hope this is not too confusing... 1 Quote Share this post Link to post Share on other sites
VicViper #4 Posted October 14, 2017 Alright, I figured since they listed as BIN files that I could run them the same as the other files. Looks like I'm not missing any must have games being unable to run XB games, but if I don't plan on using my floppy drive, what are the other devices available that would fill this niche using either SD or some other modern storage medium? Quote Share this post Link to post Share on other sites
ralphb #5 Posted October 14, 2017 Basic and XB programs cannot be converted to cart format. Actually, I think BASIC programs can -- although I don't know of any tool right now. If I had more time, I might try to write one. Basically you'd need to move the cartridge contents to VDP RAM, and start the BASIC interpreter. Not sure if that would fit into scratchpad RAM, or if you needed 32K. For XB, however, you cannot have both XB and XB program running in the FG99 at the same time. Maybe the reload feature of the FG99 would work for that. (Everything spoken theoretically, of course.) Quote Share this post Link to post Share on other sites
mizapf #6 Posted October 14, 2017 You can execute BASIC from GROMs also. There are some cartridges that just contain a BASIC program. 1 Quote Share this post Link to post Share on other sites
Casey #7 Posted October 14, 2017 Alright, I figured since they listed as BIN files that I could run them the same as the other files. Looks like I'm not missing any must have games being unable to run XB games, but if I don't plan on using my floppy drive, what are the other devices available that would fill this niche using either SD or some other modern storage medium? A NanoPEB device has a compact flash card reader that emulates 3 disk drives. It also provides 32K memory expansion and a serial port, all on 1 card that plugs into the expansion port on the right side of the console. These are occasionally available on eBay. Between it and the FinalGROM 99, you can have pretty much everything that a TI 99/4A could run in a very compact form factor. Quote Share this post Link to post Share on other sites
Asmusr #8 Posted October 15, 2017 For XB, however, you cannot have both XB and XB program running in the FG99 at the same time. Maybe the reload feature of the FG99 would work for that. (Everything spoken theoretically, of course.) Wouldn't it be possible to patch an XB image to restore the XB program from additional ROM banks into 32K, and then start the interpreter? Quote Share this post Link to post Share on other sites
ralphb #9 Posted October 15, 2017 (edited) Wouldn't it be possible to patch an XB image to restore the XB program from additional ROM banks into 32K, and then start the interpreter? Yes, that would be possible, but only because XB is a GROM program, and GROM might be made into GRAM. Also, XB has only free GROM 7 left, so depending on the contents of GROM 6, the XB program might be limited to 8K (unless you added everything to the ROM part). For ROM programs, the GPL header would remain in the lower half ROM bank, which cannot be configured as RAM. EDIT: clarification Edited October 15, 2017 by ralphb Quote Share this post Link to post Share on other sites
Asmusr #10 Posted October 15, 2017 EDIT: clarification Well, it's not clear to me why you would need GRAM? :-) I'm not talking about patching XB on the fly. Quote Share this post Link to post Share on other sites
+RXB #11 Posted October 15, 2017 Hmm using SAMS I show in demos RXB using the SAMS with multiple XB and Assembly programs all run from SAMS memory. Quote Share this post Link to post Share on other sites
ralphb #12 Posted October 15, 2017 Well, it's not clear to me why you would need GRAM? :-) I'm not talking about patching XB on the fly. Duh, you're right. I was thinking too complicated ... Quote Share this post Link to post Share on other sites
ralphb #13 Posted October 15, 2017 I've hacked a little tool to convert TI BASIC into a GROM cart BIN that you can run in an emulator and on the FinalGROM 99. It's not perfect, because you'll have to type RUN when the prompt appears. As usual, the tool needs Python 2.x. To convert an encoded TI BASIC program into a BIN, type . bas2cart.py <basic.prg> . To generate an encoded TI BASIC program (i.e., the format as it is stored on a disk) from a listing (i.e., a text file), you can use the xbas99 program from the xdt99 suite. . xbas99.py -c <listing.txt> . As an example, I used BOMBER by Roland Schlosser. PRG is the encoded BASIC, BIN the result of bas2cart. Unrelated question: I wonder if running from GROM is slower than running from VDP RAM, as I image VDP RAM to be faster than GROM. bas2cart.zipbomber.zip 5 Quote Share this post Link to post Share on other sites
digdugnate #14 Posted October 15, 2017 I've hacked a little tool to convert TI BASIC into a GROM cart BIN that you can run in an emulator and on the FinalGROM 99. It's not perfect, because you'll have to type RUN when the prompt appears. As usual, the tool needs Python 2.x. To convert an encoded TI BASIC program into a BIN, type . bas2cart.py <basic.prg> . To generate an encoded TI BASIC program (i.e., the format as it is stored on a disk) from a listing (i.e., a text file), you can use the xbas99 program from the xdt99 suite. . xbas99.py -c <listing.txt> . As an example, I used BOMBER by Roland Schlosser. PRG is the encoded BASIC, BIN the result of bas2cart. Unrelated question: I wonder if running from GROM is slower than running from VDP RAM, as I image VDP RAM to be faster than GROM. bas2cart.zipbomber This is neat! Ostensibly I could take the TI-Basic Demos my dad wrote and convert them for use in the FinalGROM99- if I'm reading correctly this functionality does not apply to TI EB. Quote Share this post Link to post Share on other sites
ralphb #15 Posted October 15, 2017 No, not yet. In fact, this is really a hack job that has been tested with two (2) programs for far. The scratchpad usage of TI BASIC is really messy, and it could be that programs with DATA might break, among others. Also, programs cannot be larger than 7.9K -- for bigger programs I would need to include bank switching. Quote Share this post Link to post Share on other sites
Asmusr #16 Posted October 15, 2017 Unrelated question: I wonder if running from GROM is slower than running from VDP RAM, as I image VDP RAM to be faster than GROM. AFAIK you cannot tell the difference since executing the instructions takes a lot more time than reading them. To run an XB program from a cart I guess you would need to hook into XB after the system is initialized and right before the "command prompt" is shown. From the hook you would jump a machine code or GPL program that restored the scratch pad, 32K and VDP memory from a memory dump of the XB program and then returned to XB (or possibly executed a RUN command). I don't know how to do that and whether it's possible. 1 Quote Share this post Link to post Share on other sites
ralphb #17 Posted October 15, 2017 To run an XB program from a cart I guess you would need to hook into XB after the system is initialized and right before the "command prompt" is shown. From the hook you would jump a machine code or GPL program that restored the scratch pad, 32K and VDP memory from a memory dump of the XB program and then returned to XB (or possibly executed a RUN command). I don't know how to do that and whether it's possible. As long as XB programs fit the VDP RAM, i.e., they're not stored in "long" format, the same procedure as above could probably used. Just the final jump would target XB, which is a bit more complicated, as we don't have a commented disassembly for XB. BTW, I don't need to use special memory dumps, as saved BASIC programs are already VDP RAM dumps. When OLDing, the program is put low in VDP RAM and then shifted to the top of VDP RAM. My tool, however, drops it right where it belongs, but the BASIC interpreter doesn't seem to mind. Quote Share this post Link to post Share on other sites
kl99 #18 Posted October 15, 2017 (edited) There is an official way to run a TI Basic Program (non XB) from GROM and it is described in the TI Home Computer Software Development System Programmer's Guide (28pages). The Document was resurrected by Jim Fetzner and I can post it in case there is interest. In addition I remember reading about success in converting a running XB program to cartridge format. However I found nothing in The Cyc. But there is even proof about some existing tool if you load Chainlink Master Solitaire (js99er.net), which is an XB game in binary cartridge format and it is starting by showing "CART CONV BY TURSI". I guess Tursi can shed some light about his tool "MakeCart". Edited October 15, 2017 by kl99 Quote Share this post Link to post Share on other sites
Asmusr #19 Posted October 16, 2017 I just noticed that Classic99 already has a function to save TI BASIC programs in cart format (Debugger / Make / Save memory as program / Save type / TI BASIC Restore). 1 Quote Share this post Link to post Share on other sites
ralphb #20 Posted October 17, 2017 There is an official way to run a TI Basic Program (non XB) from GROM and it is described in the TI Home Computer Software Development System Programmer's Guide (28pages). The Document was resurrected by Jim Fetzner and I can post it in case there is interest. Yes please, I'd be interested in that! Quote Share this post Link to post Share on other sites
Tursi #21 Posted October 17, 2017 (edited) I just noticed that Classic99 already has a function to save TI BASIC programs in cart format (Debugger / Make / Save memory as program / Save type / TI BASIC Restore). Yep, we've released software that used it, although I can't remember any of it except my crap game contest entry. It lets you run your title to a good stopping point before you save, then backs up all of VRAM except the screen plus scratchpad (so breakpointing right before the screen is drawn is good). That lets you skip the prescan. It's just a normal 16k copy cart (which is why we lose the screen - 16k VRAM and 16k ROM... though I think there's an option to skip the disk buffers instead...) Anyway, then the emulator runs until the GPL interpreter hits its main loop, and then it saves. On restore, it then knows exactly where to jump to in order to resume. Sample output ROM: HyperRacer Crap Entry.zip Of course, this is not the same as patching the program to run natively from GROM, it's more of a savestate. Edit: There's also an option that inhibits Fctn-4 from breaking the program in the Classic99 converter -- this just works by installing a user interrupt that checks the keyboard. If FCTN-4 is pressed, it resets. Edit: the old MakeCart tool could only handle EA#5 programs -- if it's showing that banner, then the program was EA#5 before it got it. Edited October 17, 2017 by Tursi 1 Quote Share this post Link to post Share on other sites
kl99 #22 Posted October 17, 2017 Yes please, I'd be interested in that! Texas Instruments Home Computer Software Development System Programmer's Guide Software-Development-System-Programmers-Guide-1979-11-06-Reduced.pdf Texas Instruments Home Computer Software Development System Programmer's Guide Personal Computer Division 6th November 1979 Again credits go to Ksarul for purchasing the document and digitizing it to pdf format. The referred GPL Debugger Operation Guide is available as well. The referred GPL Programmer's Guide is well known. 3 Quote Share this post Link to post Share on other sites
ralphb #23 Posted October 17, 2017 It lets you run your title to a good stopping point before you save, then backs up all of VRAM except the screen plus scratchpad (so breakpointing right before the screen is drawn is good). That lets you skip the prescan. It's just a normal 16k copy cart (which is why we lose the screen - 16k VRAM and 16k ROM... though I think there's an option to skip the disk buffers instead...) Anyway, then the emulator runs until the GPL interpreter hits its main loop, and then it saves. Quite elegant, really. It pays to have your own emulator. Quote Share this post Link to post Share on other sites
