andrew@meler.us
Atari 800 keyboard chip
I have an Atari 800 with keyboard that is not responding at all. I tried another keyboard - same issue.
The issue is not with a keyboard - must the motherboard or the chip that controls the keyboard.
What would you check first? Computer otherwise boots fine. Start/Select/Option/Reset buttons appear to work.
The 4021 shift register/encoder chips are known to fail but they don't usually fail completely. In my case I had many bad keys and some good keys. Switching the two 4021 chips around switched the good/bad keys around. The replacements were so cheap that I didn't even bother figuring out if one chip was still good (just replaced both and have 4021s to spare).
The multiplexer/demultiplexer chips used for the keyboard are 4051, not 4021!
Thanks. Looks like I was copying an old typo after I skimmed my old thread.
Edit: actually, I looked it up, saw "4051," and then wrote "4021" anyway because I'm also familiar with the NES controller shift register.
Edited by CZroe
If it still doesn't work after changing the 4051s (mine didn't :( ) and your keyboard is a Mitsumi, there's a repair video here.
The keyboard itself is fine - I pulled a keyboard from a working 800 and installed it on the defective motherboard - the working keyboard did not respond.
I'll buy the 4051 on ebay - this should work?
https://www.ebay.com/p/Texas-Instruments-CD4051BE-Multiplexer-8-Channel-16dip/1200436875?iid=282437169279&_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D48740%26meid%3Db77ae6b4c40a4497aedc2fb862fea0bf%26pid%3D100005%26rk%3D1%26rkt%3D6%26sd%3D322795851890&_trksid=p2047675.c100005.m1851
