Firedawg
1088XEL Atari ITX Motherboard DIY Builders Thread
Something of a side note, but I just noticed in everybody's photos that they have nice blue plastic no-ears DE9 plugs on their Joy-2-PICs, and I'm wondering where they come from? @mytek's schematic for the Joy-2-PIC has a Digi-key part number for the connector, but as far as I can tell that's a normal metal plug with ears.
Those are modified versions with the metal casing removed. However with the casing removed the 2 halves of the plastic holding the terminals will naturally want to come apart, so they will need to be glued together (Super Glue).
Aha! No wonder I couldn't find a supplier. Thanks, I thought I'd lost my internet search mojo :)
I added an extern swap-button for the CF3-interface.
My first, intern solution, looked like this:
But it was a bit inconvenient, because I always have to reach behind the computer and the LED was hard to see... ;-)
On ebay, I found an illuminated switch like this:
Unfortunately, the description was somewhat ambiguous; the ordered part did not contain a button, but a switch. I replaced the switch and rewired the part so that the pushbutton and the LED are led out on their own lines to a four-pin jack plug:
I had to rework one of the holes in the housing a bit with a countersink (for M8 thread), so that I could screw the bushing tight:
The connecting cable is wired as follows:
Ground is the outer contact, so that the contacts of the connector are "grounded" first when plugged in. Also, the aluminum housing is at the same potential! The connection to "+5V" is made last to avoid short circuits when plugging in when the computer is switched on.
Sleepy
