Sign in to follow this
NostAlgae37
Will the FBP accept 5V 2A via Micro USB or will it fry it?
It wouldn't matter if you had an adapter that was 5V 10,000,000A, it would not fry it. However much current the device normally pulls will be how much it will pull with a new adapter rated for higher current(provided voltage is same). The 2A in the adapter you mention is just a rating, not a constant. It is how much it is tested to be capable of. The amps flowing is dependent on the circuit it is applied to.
Edited by SignGuy81
